Tip & How-To about Garden
Riding Lawn Mower Common Issues
I have come across a lot of questions for Riding Lawn Mowers of late. Here are some common issues. When the mower cranks but will not start check the Operator presence switch to make sure it is working properly. This is normally located under the seat and is activated when the operator sits in the seat. Most mowers will not crank or start unless the operator is in the seat. Make sure you are pressing the brake Pedal all the way down. If this switch checks out and you still have no fire check for spark at the Spark Plug. If you have spark then your problem is in the fuel system. It takes a very short time for gas to gum up the fuel lines or carburetor in higher temperatures and bad gas will cause this problem. If you can look in the tank and see blobs of a dark fluid then you have water in your gas, change it. If none of this solves the issue and you post on Fixya for further assistance please be sure to post the Make, Model and Year of manufacture in your post. Part locations and electrical system design vary by all these factors. Good Luck
Garden Logo
will not crank DEAD but lights come on
Riding Lawn Mower Won't Start ' ThriftyFun
www.thriftyfun.com/tf666549.tip.html
Question: Lawn Tractor Won't Start. I have a John Deere LA125. I bought it new in 2009. After sitting unused in the garage for the winter (5 months) I couldn't get ...
Craftsman Riding Mower Won't Start ' ThriftyFun
www.thriftyfun.com/tf68077908.tip.html
Why will my Craftsman lawn tractor not start with a new battery, new spark plugs, new gas, gas filter, .... Question: 18.5 hp Craftsman Lawn Tractor Won't Start.
Riding lawn mower will not start - Household Repair Series ...
? 3:41
https://www.youtube.com/watch?v=DFDSvWtXwBk
Jun 21, 2013 - Uploaded by Robert DIY
This video will explain how I got a riding lawn mower started. Always check the basics. ... Lawn Tractor Won't Start--Any Ideas? - Duration: 2:04.
Jan 21, 2016 | Garden
i have a cub cadet lt104 and we replaced the battery and solenoid and it won't start
wont crank or wont start. 2 different things...
wont crank, in this order: check fuse, brake switch ( adjustment and operation ) and then ignition switch
wont start but does crank: check for spark, yes then check fuel shut off solenoid. no, disconnect kill wire to coil and check again, still no, coil is issue, if yes after disconnecting kill wire suspect a safety switch
May 16, 2014 | Yard Machines 155 Torque Briggs Stratton...
Husqvarna YTH20K46 Lawn Tractor Will not Crank due to battery issue
Check the start fuse, under dash and back side of engine.
Jun 02, 2012 | Husqvarna Garden
Lawn mower will not stay cranked unless you keep pouring gas into
common problems to all older lawnmower, lots of dirt and dust the mower goes through and ages. I would first start by taking the carb apart and clean the filter with soap and water, allow it to air dry. also carburetor prob need rebuilding or replacing. Pick up some Carburetor cleaner at any auto part store and spay it down the carb, dont be afraid to spray allot in there and let it dry for 1/2 and hours. carb tend wear and parts need replacing just like any engines. 99% of the time lawn mower carb goes out before the engine will and common problems with all lawn mower. If you not mechanical incline or dont want to rebuilt it, just buy the whole new carb and replace it, fairly cheap easy to replace and will last you another 10 + years or more. www.briggsandstratton.com
Sep 01, 2009 | Omega Rear Drive Wheel Snapper Mowers
1,238 people viewed this tip
Top Garden Experts
Dennis Key
Dennis Key
john h
