Tip & How-To about Computers & Internet
Locate the serial number, RAM size, Processor name
How to locate the serial number, RAM size, Processor name of your HP notebook:
* Just try the following key combination "fn"+"esc", the resulting screen/pop-up Window includes all those details.
Computers & Internet Logo
Can't get wi-fi connection
There are a number of reasons why you may not get a wi-fi connection:
  1. No connection available
  2. Poor signal strength
  3. Wi-fi on device not turned on
  4. Faulty wi-fi driver in device
  5. Using wrong wi-fi security password
  6. Router has your MAC address blocked
  7. Faulty wi-fi module in device
If you can give specifics on what you have tried and what the results are we may be able to narrow down the possibilities.
Oct 25, 2015 | Computers & Internet
fn+esc not working
TRy fn then esc or ctrl or windows esc. Is it even loaded onto your computer? Does your function key work with other things?
Aug 24, 2014 | HP Pavilion g6-2210us 15.6" Notebook PC
Fn (function) key not working in my new hp elitebook 8440p laptop. It is running windows XP SP3.
A good check of whether the Fn key is working is to display the system information as follows...
1. briefly press Fn key, and then briefly press the Esc key
or alternatively...
2. Press and hold down the Fn key, briefly press the Esc key, and then release both at the same time.
This should display the version of the system BIOS as the BIOS date or system ROM version number.
If this doesn't happen, then either one or both Fn and Esc keys are not working. In any case since your laptop is new, it should be covered by a 30-day exchange policy from the place of purchase and you should just take it back for an exchange. If you can't get it exchanged and the purchase was on your credit card, you should have purchase coverage from the credit card company as well.
Mar 22, 2011 | HEWLETT-PACKARD HP EliteBook Notebook
upgrade this notebook
Yes you can upgrade that notebook.
The notebook is sold with 1GB DDR SDRAM which is upgradable to 2GB RAM, 2 slots 1x1GB in each slot.
The hard drive is usually 120GB SATA which you can put any drive in up to 320GB or 500GB (if you can get on of that size)
The processor is a core duo. It is upgradable but i wouldn't bother with that as 1.6GHz is more than sufficient.
Regards.
Sep 21, 2009 | HP Pavilion Dv5220us Notebook
which function key allows to switch to tv
You need to press hold the FN key and press the F4 function key once which toggles the display to the External Display source like the television connected along with the LCD of the Notebook.
If the FN and F4 key combination is pressed again, the display will dissappear from the LCD of the Notebook and remain only on the external source.
If the FN and F4 key combination is pressed third time, the display will be back on the LCD of the Notebook and will not remain on the External display source.
Here are these details in other way :
First time pressing FN + F4    ---> Display on LCD and External display
Second time pressing FN + F4 ---> Display not on LCD but on the External Display
Third time pressing FN + F4 ---> Display back on the LCD and not available on External Display (Normal position).
Below are the details of what the Function keys in your DV1000 Notebook work :
fn + f1 Opens Help and Support Center fn + f2 Opens print options window fn + f3 Opens default Internet browser fn + f4 Switches the image among displays fn + f5 Initiates Standby fn + f6 Initiates QuickLock fn + f7 Decreases screen brightness fn + f8 Increases screen brightness fn + f9 Plays, pauses, or resumes an audio CD or DVD fn + f10 Stops an audio CD or DVD fn + f11 Plays the previous track or chapter on an audio CD or DVD fn + f12 Plays the next track or chapter on an audio CD or DVD fn + esc Displays system information.* (*To clear the system information display, press esc.)
Hope this helps...
Oct 11, 2008 | HP Pavilion dv1000 Notebook
349 people viewed this tip
David Payne
David Payne
