Tip & How-To about Computers & Internet
How do I unlock iPod Screen Lock if you forget your password?
The lock screen on an iPod can be a blessing and a curse. The function does a great job of keeping unauthorized users from snooping in your files, but if you forget the password, it does a great job of poking around you and in your files, too. Forgetting a password is automatically locked iPod into a worthless piece of plastic and circuits, however. You have two options: a quick and painless, and if that fails, the other is slow and clean everything off your iPod ... but you will regain control of the device at the end.
1. Sync your iPod with your main computer, linking the equipment with the supplied USB cable and then open iTunes. Synchronize the two, and open the iPod in some cases. If you do not have access to the main computer - the computer that you used for the initial setup of the iPod to run - you need to restore iPod to factory settings.
2. Connect your iPod to any computer that has iTunes.
3. Open the iTunes software.
4. Click the list to your iPod in "Devices" in the left pane of iTunes. It may take a few moments for the software needed to register the device is connected, so be patient if you do not see in the first place.
5. Click "Restore" in iTunes main window. The first phase of the recovery process takes place; progress can be seen in iTunes. After the first step is completed, iTunes, or instruct you to disconnect the iPod and the battery or asks you to leave it on to complete the process. Do what is asked.
6. Wait for the second phase of the recovery process occurs. This time, the progress bar on the iPod itself.
7. Run the installation process for your iPod after the second phase is completed. The procedure is the same as the first time you sync your iPod. After installation is complete, you'll find the iPod screen lock off
Computers & Internet Logo
Can you unlock my ipod nano
In the Apple Support Site, Apple notes that the "Screen Lock" function:
Allows you to set a 4-digit combination to prevent someone else from using your iPod while it is not attached to a computer. When an iPod is locked, you must enter the combination to unlock the screen. This feature is different from the Hold switch in that the Hold switch only prevents iPod from turning on accidentally -- not keeping snoops out.
Screen Lock only locks users out of the user interface. It does not encrypt data on your iPod. For example, if you use Screen Lock and then connect your iPod to a computer, you'll be able to manage music on your iPod with iTunes and access all data on it in disk mode (contacts, notes, and any other files you have stored on the iPod).
This support document also provides additional information on locking and unlocking the iPod. According to Apple, if you have forgotten the code, you can unlock the iPod by doing the following:
Connect your iPod to the primary computer you use it with (the first one iPod synced with), and open iTunes
. When you disconnect iPod from the computer, it will no longer be locked.
If you can't unlock iPod using either [the code or connecting it to the computer you use to manage its songs]. . . you can restore your iPod to factory settings using iPod Updater. Please note that this will erase all data on your iPod. Afterwards, you can add your music and data back to your iPod.
If you want to change the primary computer that your iPod is associated with, do this:
1. Restore your iPod. Warning: The restore process cannot be undone. All of your songs and files will be deleted. Always make a backup of your important data.
2. Connect your iPod to the computer that you want to be the primary computer.
3. Open iTunes and synchronize.
Apple also notes that company "representatives cannot unlock an iPod if you forget your combination. If you can't unlock your iPod and you don't have access to the primary computer, your only option is to restore the iPod, which will erase all music and data."
Oct 21, 2010 | Apple iPod nano
How can i unlock my ipod nano 4GB
"Screen Lock" is provided by the iPod nano, iPod (5G), and subsequently released iPod models. Earlier iPods do not offer this feature.
Allows you to set a 4-digit combination to prevent someone else from using your iPod while it is not attached to a computer . When an iPod is locked, you must enter the combination to unlock the screen. This feature is different from the Hold switch in that the Hold switch only prevents iPod from turning on accidentally -- not keeping snoops out. Screen Lock only locks users out of the user interface. It does not encrypt data on your iPod. For example, if you use Screen Lock and then connect your iPod to a computer, you'll be able to manage music on your iPod with iTunes and access all data on it in disk mode (contacts, notes, and any other files you have stored on the iPod). This support document also provides additional information on locking and unlocking the iPod. According to Apple, if you have forgotten the code, you can unlock the iPod by doing the following:
Connect your iPod to the primary computer you use it with (the first one iPod synced with), and open iTunes. When you disconnect iPod from the computer, it will no longer be locked. If you can't unlock iPod using either [the code or connecting it to the computer you use to manage its songs]. . . you can restore your iPod to factory settings using iPod Updater. Please note that this will erase all data on your iPod. Afterwards, you can add your music and data back to your iPod. If you want to change the primary computer that your iPod is associated with, do this: 1. Restore your iPod. Warning: The restore process cannot be undone. All of your songs and files will be deleted. Always make a backup of your important data. 2. Connect your iPod to the computer that you want to be the primary computer. 3. Open iTunes and synchronize. Apple also notes that company "representatives cannot unlock an iPod if you forget your combination. If you can't unlock your iPod and you don't have access to the primary computer, your only option is to restore the iPod, which will erase all music and data."
May 18, 2010 | Apple iPod nano
i forgot my passcode for my ipod nano 2 gb. How do i unlock it with out plugging the ipod into the computer
reposting again..
how to unluck my ipod nano
Allows you to set a 4-digit combination to prevent someone else from using your iPod while it is not attached to a computer. When an iPod is locked, you must enter the combination to unlock the screen. This feature is different from the Hold switch in that the Hold switch only prevents iPod from turning on accidentally -- not keeping snoops out. Screen Lock only locks users out of the user interface. It does not encrypt data on your iPod. For example, if you use Screen Lock and then connect your iPod to a computer, you'll be able to manage music on your iPod with iTunes and access all data on it in disk mode (contacts, notes, and any other files you have stored on the iPod). This support document also provides additional information on locking and unlocking the iPod. According to Apple, if you have forgotten the code, you can unlock the iPod by doing the following:
Jan 26, 2010 | Apple iPod nano
ipod is open but i cant play any song..its lock .What will I do?
Allows you to set a 4-digit combination to prevent someone else from using your iPod while it is not attached to a computer. When an iPod is locked, you must enter the combination to unlock the screen. This feature is different from the Hold switch in that the Hold switch only prevents iPod from turning on accidentally--not keeping snoops out. Screen Lock only locks users out of the user interface. It does not encrypt data on your iPod. For example, if you use Screen Lock and then connect your iPod to a computer, you'll be able to manage music on your iPod with iTunes and access all data on it in disk mode (contacts, notes, and any other files you have stored on the iPod). This support document also provides additional information on locking and unlocking the iPod. According to Apple, if you have forgotten the code, you can unlock the iPod by doing the following:
Jan 03, 2008 | Apple iPod nano
198 people viewed this tip
David Payne
David Payne
