Tip & How-To about Computers & Internet
How to Sync your iPod Nano 5th generation without iTunes
While you can enhance your 5G iPod Nano, you're not a fan of iTunes. Fortunately, many companies offer free web-based software that lets you sync an iPod without the Apple Software. If you are looking for software compatible with 5G iPod Nano, you can use CopyTrans, FloolaDesktop or MediaMonkey. Each program allows you to easily synchronize your music collection from your computer to iPod. Depending on the program you choose, you may be able to sync music from your iPod to your computer.
Using CopyTrans
1. Download and install CopyTrans. When installation is complete, the program will open automatically.
2. Connect your iPod to your computer using the USB cable. CopyTrans import files from your iPod to your program and a list of your music and videos are shown on the screen.
3. Click the "add tracks to playlist" icon on the toolbar to add other media files in the program. Navigate through your folders and select the files you want to import.
4. Select the songs you want to sync with iPod.
5. Click the "Update" icon on the toolbar to your files synchronized.
Using FloolaDesktop
1. Download and install FloolaDesktop. Open the program when installation is complete.
2. Connect your iPod to your computer using the USB cable. After connecting your iPod, Floola will automatically synchronize files from your iPod to the program.
3. Click the "Item" and select the tab "Add to Library" option for additional songs, videos, podcasts, or import into the program. Select the songs you want to import and click the Add button. After importing your files to Floola, the program will automatically synchronize the files to your iPod.
Using MediaMonkey
1. Download and install MediaMonkey. Start the program when installation is complete. You will be prompted for your music and media files to import.
2. Select any folder you want to import and click "OK". Media files in each of the selected folders will be added to your MediaMonkey library.
3. Connect your iPod to your computer using the USB device.
4. Click the "Library" option in the navigation pane on the left of the screen. A list of your files is displayed on the screen.
5. Select any music, video, podcast or playlist you want to synchronize with the iPod and then click the "Send to Handheld" button, which is indicated by an iPod icon. MediaMonkey synchronize the selected files to your iPod.
Computers & Internet Logo
what is wrong with my ipod ao 5th generation
Flip the iPod Nano's "Hold" switch to "OFF."
The iPod Nano cannot be turn on if the switch is set to "ON."
Reset the iPod Nano. Move the "Hold" switch to "ON" and then "OFF."
Then, press down the "Select" and "Menu" buttons on the Nano. Hold those buttons for about eight seconds.
The Apple logo will then become visible on the iPod Nano. Once this occurs, try turning the iPod Nano on once again.
Connect the iPod Nano to an iPod charger or a computer that is turned on via the iPod Nano's USB cord. Charge the Nano for at least 30 minutes.
Then, try to turn the Nano on.
Update the iPod Nano's software.
Connect the Nano to your computer via the player's USB cable. Open iTunes, and click the iPod Nano's name on the left part of iTunes.
Click the "Summary" option at the top of iTunes. Then, click on the "Check for Updates" button that's positioned in the middle of iTunes.
Follow the instructions that appear inside iTunes in order to install the updates on the Nano.
hope this helps
Sep 23, 2012 | Audio Players & Recorders
How can i unlock my ipod 5g
to unlock the ipod you have to remember the password that is set. Unless it is a ipod that has a slide switch on the top or side. If you do not remember the password that is not a problem. Follow the steps that i have outlined below. If this does not completely help your situation please let me know and i will be glad to assist you. According to Apple, if you have forgotten the code, you can unlock the IPod by doing the following: 1 If you can't unlock IPod using either [the code or connecting it to the computer you use to manage
its songs. . . Plug the iPod USB cable into the bottom of the iPod Nano. 2 Plug the other end of the iPod USB cable into a free USB port on a Mac or PC computer. 3 Open the iTunes application by clicking on the Dock icon on a Mac or using the Start menu on a PC. 4 Click on the name of your iPod Nano under the "Devices" list in the iTunes window. 5 Click on the "Sync" button to establish a connection between your iPod and the computer. 6 Click on the eject symbol next to your iPod's name after the syncing process has finished. 7 Unplug your iPod Nano. The device will be unlocked and you will be able to access all normal features again. if that does not work you can restore your iPod to factory settings using iPod Updater. Please note that this will erase all data on your iPod. Afterwards, you can add your music and data back to your iPod. If you want to change the primary computer that your IPod is associated with, do this: 1. Restore your iPod. WARNING: The restore process cannot be undone. All of your songs and files will be deleted. Always make a backup of your important data. 2. Connect your iPod to the computer that you want to be the primary computer. 3. Open iTunes and synchronize. Apple also notes that company "representatives cannot unlock an iPod if you forget your combination.
If you can't unlock your iPod and you don't have access to the primary computer, your only option is to restore the IPod, which will erase all music and data." If you need further assistance please feel free to follow up with a comment and i will be here to assist you. If this assisted you please feel free to rate the comment. thanks and have a great day.
May 05, 2010 | Apple iPod MA446LL/A MP3 Player
it wont let me add music only charges up any solutions for that then many thanks mike ipod nano 4gb
do you have itunes for ipods you need an up todate itunes software its free to download @ itunes.com then it should work! :)
Aug 10, 2009 | Apple iPod nano
prroblem with itunes for ipod nano
How have you formatted it? You can try and first format it using Windows (and do a Quick format) and then format it with iTunes. Let us know exactly so we can provide more advice.
If that does not work, then please consider the FREE Diagnostic Testing that we offer through our website. It will cost you virtually nothing to have us diagnose your issue. Our company is staffed with formed Apple Techs and we are an Accredited Business with the Southern Colorado Better Business Bureau (BBB).
Regards,
Rick
EverGreen Electronics
'Eco-Friendly iPod Service, Sales & Recycling'
E-Mail: sales@evergreenelectronics.com
Website: http://www.EverGreenElectronics.com
FREE Apple iPod Technical Support - http://www.iRepairGuide.com
Jun 15, 2008 | Apple iPod nano 3rd Generation
496 people viewed this tip
David Payne
David Payne
