Tip & How-To about Soyo GVNL3268AB 32 in. LCD Television
Power no picture
Just replaced power supply and hdtv comes on with no screen, and can't turn off the tv . Soyo GVNL3268AB. Is their a reset button?
Soyo GVNL3268AB 32 in. LCD Television Logo
soyo tv Mode MT-SYTPT3227AB will not turn on
It might be the power supply board. There is a repair service which addresses any problem with the power supply board, not just bad capacitors: http://www.coppelltvrepair.com/p/783/soyo-mt-sytpt3227ab-power-supply-board-repair-service-no-power-shutdown-etc
Jul 11, 2012 | Soyo SYTPT3227AB 32 in. LCD TV
My Soyo DYLT032 has power but no picture or sound
I HAVE FOUND 2 2200uf CAPS ON THE POWER SUPPLY BOARD THAT ARE PUFFED UP. CHANGING THEM USUALLY SOLVES THE PROBLEM. THERE'S ALSO A RESET BUTTON ON THE MAIN BOARD YOU MAY NEED TO RESET AFTER CHANGING THE CAPS.
May 30, 2009 | Soyo DYLT032C 32 in. LCD Television
Long story short:
Had the same problem with my Soyo.
Thought it was the power supply board problem that everyone else was reporting.
ordered one.  Plugged it in.  Did not work.
Inspected the Main/Logic board and found what looked like a black button that could be depressed.  It is located to the right of main processor on the board.  You can't really miss it.
With the TV plugged in, I pressed the suspect button.  The TV made a buzzing/clicking noise for a few moments and the stuck blue illuminated power button faded away.
Curious by this, I pressed the power button and low and behold the TV comes to life!
Looks like I found a "reset" button which seems to have fixed my problem.
Thanks Soyo for not bothering to mention that such a button exists.
I hope the rest of you have the same good luck.  In the event you are still in need of a power supply board, email me.  I have a spare now it seems.  ;)
Dec 28, 2008 | Soyo DYLT032C 32 in. LCD Television
Problems with Soyo DYLT032C 32 in. LCD Television. The TV will not turn on, I have un-plugged it and plugged it back in, in hopes it would re-set the tv. Do you have any suggestions?
Long story short:
Dec 10, 2008 | Soyo DYLT032C 32 in. LCD Television
1,557 people viewed this tip
Top Soyo Televison & Video Experts
ted dux
Are you a Soyo Televison and Video Expert? Answer questions, earn points and help others
