Tip & How-To about Computers & Internet
How to set timer for shutdown in windows os
Step 1: click start menu button
step 2: click on the 'run' button
step 3: in the box that appears,type in the command ''shutdown -t 01"
the computer will start shutting down in 01 seconds
Note: By changing the value after the letter 't' in step three, u can set timer to shutdown for the specified value
for eg: the command ''shutdown -t 15" will set the timer for shutdown to 15 seconds.
Computers & Internet Logo
I want to factory restore my Compaq Presario V5000 and I can't find the advanced settings to do this what do I do if it doesn't have an F11 option?
THis is from the HP tech chat thing, and it seems to be working. I did method 2 and browsed to the file:
_________________
1. Click Start 2. Click Shutdown 3. The "Shut Down Windows" dialog box will be displayed 4. Select "Shut Down" from the me 5.
Start the system again. 6. When the Red Compaq logo appears press F8 repeatedly until prompted with the "Windows Startup
Menu" 7. Select option 6 (Safemode Command Prompt) by pressing the down arrow key until Safe Mode Command Prompt is
highlighted 8. Press Enter 9. At the C:\ prompt type D: and press Enter 10.At the D:\ prompt type CD CPQS and press Enter
11.At the D:\CPQS prompt type XQR press Enter
Method 2:
1. Click Start 2. Click Run 3. In the "Open" box type C:\CPQS\QUICKSR\FRESTORE.EXE Performing these steps should resolve this
issue.
Aug 15, 2013 | HP Compaq Presario V5000Z Notebook
Can i restore my compact presario sr1503wn with out a disc?
Hi
1. Click Start
2. Click Shutdown/
3. The "Shut Down Windows" dialog box will be displayed/
5.Start the system again.
Menu"
7. Select option 6 (Safemode Command Prompt) by pressing the down arrow key until Safe Mode Command Prompt is highlighted
8. Press Enter
Method 2:
1. Click Start 2. Click Run 3. In the "Open" box type C:\CPQS\QUICKSR\FRESTORE.EXE Performing these steps should resolve this issue.
Also check his link if it helps:-
http://social.microsoft.com/forums/en-US/genuinewindowsxp/thread/95860a8d-3a44-43a3-b26f-2436bdf2bfc6/
Pease get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
Jul 04, 2011 | HP Compaq Presario SR1503wm PC Desktop
how to disable the right click on my desktop
Follow this Steps to Disable Right Click
Step 1 :
Click on "Start" and select "Run." Type "regedit" into the textbox and hit "OK." This command will open the "Registry Editor" window.
Step 2:
Select "HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Policies\Explorer."
Step 3:
Open the "Edit" menu and choose "New" then "DWORD Value." A new file will appear on the right side of your screen with the file name highlighted. Type in "NoViewContextMenu" for the new file name.
Step 4: Double click to open and type in "1" into the Value data box. Hit the "OK" button.
Step 5: Close the Registry Editor by selecting "Exit" from the "File" menu. Restart your computer for the change to go into effect and you have now disabled your right-click feature
Jul 05, 2010 | Microsoft Windows Xp Home Edition Sp2...
How to restrict user's to access shutdown button
Follow the given steps to hide system shutdown button from start menu:
To use this feature, you will need to be logged into your computer with administrative rights.
1. Click Start button and type regedit in Run option then press Enter for next.
2. Here locate the location to:
HKEY_CURRENT_USER\Software\Microsoft\Windows\Curre ntVersion \Policies\Explorer
3. Here in right side panel, right click to create a new DWORD value with name NoClose.
4. Now assign number 1 to its value data box. Now close the registry editor and restart your computer after any changes to go into effect.
5. But next time, if you want to unhide the shutdown button then simply change the value data box to 0 or delete this DWORD item.
6. Again close the registry editor and restart your computer after any changes to go into effect.
Jul 10, 2009 | Microsoft Windows Server 2003 Enterprise...
252 people viewed this tip
David Payne
David Payne
