If you are getting lens error then follow some of the tips it may solve...
By
dileep007
Rank: Guru
Rating: 87%, 1082 votes
posted on Aug 28, 2008
#1: Remove the batteries from the camera, wait a few
minutes. Put a fresh set of batteries back in and turn the camera on.
#2: Remove the batteries, then remove the memory card.
Then install the new batteries, when you turn it on it should come back
to life. Error E30 means you don't have a memory card installed, so
turn it off, slip in the memory card and turn it on one last time.
#3: Insert the cameras Audio/Video (AV) cable, and
turn the camera on. Inserting this cable ensures that the camera's LCD
screen remains off during the start process. Thus extra battery power
is available to the camera's lens motor during start up. This extra
power can be useful in overcoming grit or sand particles that may be
jamming the lens.
#4: Place the camera flat on its back on a table,
pointed at the ceiling. Press and hold the shutter button down, and at
the same time press the power-on button. The idea is that the camera
will try to autofocus while the lens is extending, hopefully seating
the lens barrel guide pins in their slots.
#5: Blow compressed air in the gaps around the lens
barrels with the idea of blowing out any sand or grit that may be in
there jamming the lens. Other variations include blowing with a hair
dryer in “no heat” setting, or sucking the gaps with a vacuum
#6: Repeatedly tap the padded/rubber usb cover on a
hard surface with the intent of dislodging any particles that may be
jamming the lens. Other variations include hitting a side of the camera
against the palm of your hand.
Comment by dileep007, posted on Aug 28, 2008
#7: Try forcing the lens. More people have reported success with this method than with any of the other methods.
Variations include gently pulling, rotating, and/or twisting the lens
barrel while hitting the power button. Attempt to gently straighten or
align the barrel if it's crooked or twisted. Another variation includes
looking for uneven gaps around the lens barrel, and then pushing on the
side of the lens barrel that has the largest gap (note pushing the lens
barrel all the way in is NOT recommended as it may become stuck there).
While doing any of the above, listen for a click that indicates that
the lens barrel guide pins may have reseated in their guide slots. If
you hear this click, immediately stop and try the camera
any doubts you can reply me
i am always here to assist you
thank you
bye
please rate the tips
Was this helpful?24 people thought this was helpful
Comment #1
posted on Aug 23, 2009
By
shavoc
Rank: Apprentice
Rating: 0%, 0 votes
This totally worked for me. So thanks, I started gentle and then worked my way up to some twisting and pushing and now it works great.
thanks
Comment #2
posted on Aug 06, 2009
By
Crack Fox
Rank: Apprentice
Rating: 0%, 0 votes
Thanks for the great tips - my camera is back in action!
To all the ppl leaving negative feedback here, you may just be a bit dense. This advice is for resolving lens errors caused by grit jamming the lens. GENTLY tapping the camera will help to dislodge the grit. All makes sense to me. Manufacturers won't take any responsibility for this problem, and if your camera doesn't work it's worth nothing. I think it's worth trying these simple tips before going to a repair guy, who will probably do the same thing and charge like a wounded bull.
Peace out kids.
Comment #3
posted on Aug 01, 2009
By
t00nz
Rank: Guru
Rating: 91%, 1985 votes
If you wish to see the original site where these tips were cut and pasted from, along with a forum of peoples experience in fixing lens errors with additional tips,
please visit this link.
Comment #4
posted on Jul 17, 2009
By
kadem
Rank: Apprentice
Rating: 0%, 0 votes
dileep,
no luck
I have an olympus tough 6000 and as of yesterday it beeps everytime I want to swith it on. It only accepts the play-mode but as soon as I want to take pictures, in any other mode, it beeps. I already took the battery out for 24 hours (suggestion of help desk olympus) but it still doesn't work.
Any more ideas ?
Comment #5
posted on Jul 04, 2009
By
300diesel
Rank: Apprentice
Rating: 0%, 0 votes
I've picked up several cameras at tag sales lately. Some of these suggestions do work. Always start
at the least invasive/destructive. If the device is valuable to you, get an expert to repair it. In my case
I now have several functioning cameras for almost nothing. The first was an Olympus C-740. Cost
5 bucks. Time to fix about 30 minutes. Lens stuck out. First try vaccuum. Second try compressed air, light tapping while turning on. What worked. I shot some electronic cleaner solvent around the lens base. A no residue GCBATH. While GENTLY twisting the lens back and forth. This is now my favorite camera as it takes regular, not proprietary batteries.Yeah it's big but works for me. The point is to get rid of the grit holding the lens out. So far I've fixed a few including a FREE Canon SD300, a Sony I gave away, a co workers Nikon, and a Canon A530 that I got for 10 bucks. The only death so far was a Canon SD850 that had been dropped hard. The lens was extended when dropped, not a dirt problem.
Took it apart and found a "sproinged" part I could not identify shaking around in the case.
Always assess and decide
what the device is worth to you vs pro repair. I GAVE that Sony away after I fixed it because a charger was too expensive, and my friend had one already. My point is that pro repair costs more
than most of these cameras are worth. Cripes try anything you can, IF you can afford to kill it. Start
slow and gentle. Sucking first, blowing next, solvent next, then the physical stuff.
Comment #6
By
JELSEYLU
Rank: Apprentice
Rating: 0%, 0 votes
Are you kidding me? haha... this **** made my camera sooo much worse. You'd rather throw your camera into a wall and hey maybe it'll work. Hammer it? Force the lens? Do what you do [: and for the guy who even wrote this, duck my sick :]
Comment #7
posted on Mar 15, 2009
By
dsorceress
Rank: Apprentice
Rating: 0%, 0 votes
Yanno, all the smart remarks about how these tips are a great way to break your camera for service guys to get more service are not real helpful. Sometimes you need a camera NOW and you don't have time to go to the store or take it to the shop; and if it needs service anyway, chances are you are not going to lose much if you take a chance on self repair, since the alternative is repairing an older camera which generally will cost almost as much as just buying a new one with better features. I am NOT going to spend money on my 4 yr old camera; if I break it trying to fix it then so be it but rather than spend money on repair I'd just go buy a new one because in 4 yrs time they have advanced enough that I can buy more camera for half of what I paid for this one. I found the tips above fixed my camera perfectly. No one advocated taking a hammer to it; but if gently tapping it against the palm of my hand is going to hurt it then it is not going to survive long anywa; first time it gets dropped it is going to fail, and I don't care how careful you are, cameras get dropped. If you can't be helpful beyond 'take it to a shop' or 'don't follow these tips because you will ruin your camera' then tell ya what: take out an ad for camera servce but leave those of us who want simple solutions alone. I tried gently tapping the camera and doing the on-off several times, then took the batteries out while the lens was extended and put a fresh pair back in, then turned the camera back on. Voila! no more "focus error." Was it risky? Perhaps, but I don't really think so. THANK YOU to dileep007 for the advice!
Comment #8
posted on Mar 10, 2009
By
MATUGG
Rank: Apprentice
Rating: 0%, 0 votes
Before finding this site my digital kodak easyshare lens was stuck. I tried myself jiggling it around and now I am sure it is jammed anymore? Any advice now? Best Buy told me it would cost more to fix it than what I paid for it, which is obviously a lie since it would probably take them 2 minutes to repair. Should I take it a part myself? Can I send it somewhere else for less expensive repair? Thanks for any advice!
Comment #9
posted on Mar 07, 2009
Busy, busy, busy.
Yes folks listen to all the important tips and tricks posted on here for breaking, sorry, repairing your camera.
Your camera is an expensive piece of equipment and full of easy to break parts so go ahead and "Bang it" why not stamp on it too! might make you feel better. Won't do the camera any good tho.
I've read a lot of tips, tricks and what not on here about how to fix a camera and all I can say is....... keeps me busy repairing them! So I guess I should say a BIG thank you to all the experts for giving me sooo much work, lol
Comment by daveward712, posted on Mar 28, 2009
Chances are that if you have damaged your lens then "yanno" it won't be a quick fix if you need your camera right now.
Your camera is a delicate piece of precision and is full of small easily damaged parts that are hard , if not impossible, to repair.
It all depends on how much damage has occurred as to whether or not a quick fix will be suitable.
1 simple but effective solution to most common accidental cases of lens problems is to purchase a sturdy case for your camera and always remove your battery so as to prevent accidental power up.
If you do decide to attempt your own repair then please remember that whilst your camera is switched off and the battery removed the FLASH will still be charged and this can give you quite a shock. Try to avoid touching the circuit board or any other component parts that have solder joints.
Another thing to remember is that your camera was assembled in a clean enviroment and operators will normally be wearing gloves to prevent damage caused by finger prints. The salt and grease in finger prints will corrode electronic parts and circuitry and reduce the life expectancy of your camera. It's not great to finally have your camera reassembled after hours of repair to discover a lovely finger print on the inside of your lens or sensor and have to strip down and clean again!
Comment #10
posted on Jan 18, 2009
By
simonvelo
Rank: Apprentice
Rating: 0%, 0 votes
I have a Panasonic DMC-FZ5GC. It had been sideswiped by our 2 year old off a table onto the floor. The camera was still working but the lens would not retract. With nothing to lose I thought I'd have a go at gently forcing / twisting the lens while repeatedly pressing the power button on and off. After a few goes ... FANTASTIC ... this actually worked. No problem with the lens falling out, the camera is working fine again. Faced with exorbitant repair costs (you may as well buy another camera these days) I was about to take it all apart but thankfully this worked. Thank you all at FIXYA!
Comment #11
posted on Dec 21, 2008
By
punkyb
Rank: Apprentice
Rating: 0%, 0 votes
I also have an SD800is with the lens error. I don't remember dropping it or having any
other damage, but it's possible that it may have gotten hit while in my
car or gotten some sand in it.
Essentially the lens is fully extended and the camera will not
function. When I power on the camera, I get the clicking noise as if
the lens is trying to extend/adjust, then a black screen on the LCD
saying "Lens Error, Restart Camera". Then it immediately shuts off.
Removing the battery/memory card has not helped. Gentle proding/blowing
in an attempt to dislodge any particles has not helped. My camera is no
longer under warranty. Any ideas???
Comment #12
posted on Dec 02, 2008
By
e511
Rank: Apprentice
Rating: 0%, 0 votes
On the Nikon D90 with the 18-105 lens, if you get the F-- error (lens not seen by the camera electronically) simply and carefully clean the lens and camera contacts with a new pencil eraser. When doing this on the camera point the opening DOWN so any small flakes from the eraser will fall out. This solved the problem completely with my camera. There may have been some slight oil reidue left ont he contacts from the manufactoring process.
Comment #13
posted on Oct 29, 2008
By
trevorag
Rank: Guru
Rating: 86%, 66 votes
As far as GE digital cameras, DO NOT bang on the camera or rotate, twist, or otherwise force the lens. You will only break the inside lens barrel. Call the manufacturer.
Comment #14
posted on Oct 22, 2008
By
echase
Rank: Apprentice
Rating: 0%, 0 votes
As a competent amateur who tries to fix almost anything I have repaired 2-3 zoom lenses and I found that about the only way is to completely dismantle the lens to find the problem. On a Fuji it had sand in the lens and I dismantled it to clean it all out. It worked for 2 years but has now jammed again. This time I just paid UK£30 on eBay for a camera with broken screen and cannibalised the 2 together.
On a Casio some years ago one of the 3 pins that guide the lens fell out and was lost. Using a small screw from old spectacles I filed the head down to the right shape and screwed it in.
You have to be pretty competent to try this though as it’s very easy to accidentally rip a ribbon cable or break a plastic latch. Not to mention dropping the small bits on the floor and never finding them again or getting dust/fingerprints in the lens/CCD. I have had to solder up ripped ribbon cables, including one ripped by a ‘professional’ repair firm who had ‘repaired' the sand jammed ‘Fuji’ for >£100 but their repair only lasted 3 months.
Am currently attempting a Sony DSC S80, see question elsewhere here, but it’s not a mechanical jamming problem. May be a failed motor. But I looked on eBay for one to use in cannibalisation and none are listed today.
Comment by echase, posted on Oct 22, 2008
And by the way carefully mark the position of all the lens parts relative to each other or you could never get them back in right position. E.g. if there are 3 pins the lens parts may go back in 3 different orientations but only one is correct.
Comment #15
posted on Oct 13, 2008
I have spent the last several years running a successful online digital camera repair business and I would tell you DO NOT ATTEMPT #5, #6 or #7 unless you don't care if you end up doing MORE damage to your camera.
Blowing compressed air in the camera will either do nothing, or it will move the dirt to another location where it will either jam up the gears again or possibly short out the camera and cause it to no longer turn on.
Banging on the camera repeatedly will either break your LCD screen, or cause the dirt to do the exact same as #5.
Forcing your lens by twisting it, banging it, pressing on it etc. will only cause more damage to the lens and maybe destroy something that used to be fixable.
There is only one type of jammed lens that responds to pressure, and you have to do it just the right way and you are LUCKY if it works and if not you will break the lens barrel and the lens is then useless. I won't tell you how to do it, I don't want you to break your lens if you don't have to.
If you want to repair your digital camera don't listen to anybody that tells you to bang on it, and don't bother going to a store, they know nothing about repair and will only send the camera to the manufacturer and charge you more than what you could pay the manufacturer yourself to do the repair.
I run a successful, affordable online digital camera repair business, and have done so for 4-5 years now. We can probably help you with your repair, even if we can't feel free to contact us for advice.
Good luck from Darntoothysam com
Thomas
Comment #16
By
hot198
Rank: Apprentice
Rating: 0%, 0 votes
my lens got stuck && i tried 1 of ur tips && it worked.
but the problem is that my lens fell out..so now i need help puttin my lens back in
i tried shoving it in but it wont stay in place...help?
Comment #17
posted on Oct 02, 2008
By
linsiesk
Rank: Apprentice
Rating: 0%, 0 votes
I have a Sanyo 7.1 Mega..Nothing to special but its been fine for a few months except my shutter wont close all the way which wasent bothering me too much because I have a case. Now when I press the power button it will light up and flash green then start flashing red and the screen turns off I have taken the batteries out, replaced them, I have taken my memory card out and put it back in..Vaccumed around but its giving me a lens error when I connect to my computer
Lens Error: 1511?
Any help would be greatly appriciated...
Thanks everyone!
Linsie
Comment #18
posted on Sep 13, 2008
By
jsaltman74
Rank: Apprentice
Rating: 0%, 0 votes
Thanks for the tips. I too had the same problem with my camera. I dropped it last time I was at the beach and it seemed to worked fine until about 2 weeks later. The optical zoom got stuck and the camera would not turn on but for about a second.
I tried all the troubleshooting methods from the manual and none seemed to work. I gently tapped the zoom while turning the power on, not it seems to be working. I haven't taken any pictures so far but it seems to be shutting off and on.
I will give some updates if the same comes up again later on or if the camera starts acting up and not normal as before.
Regards..
Comment #19
posted on Sep 12, 2008
By
photo_love
Rank: Apprentice
Rating: 0%, 0 votes
i accidenly dropped my camera...
i tried some of these tips, and i got it to work twice, but the view was all blurry. when i tried zooming in and out, the view moved, even though i wasn't moving the camera.
then once i turned it off it just got stuck again.
any tips?
should i send it in?
or is my camera doomed?
Can you Help with these Digital Cameras problems?
Canon Digital Rebel XT / EOS 350D Digital...
what is err02 and how do i fix it I have tried 2 different...
lightning bolt and will not snap picture.Can't focus
.busy is on my screen and camera has froze . I have Canon...
My picture button broke , to take pictures , i can press...
auto focus is not working all the time
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Camera & Camcorder Repair
(888) 435-5080
Worldwide AFFORDABLE digital camera repair &...
(214) 951-9731
Digital Camera repair and sales,trade,salvage.
