Tip & How-To about Linksys Wireless-G WRT54GR Router
Linksy WRT54GR Router - Invalid Wireless MAC Address [EN] [FR]
[Englisch]
i have been troubled with the configuration of the linksys router WRT54GR when trying to add my wireless devices to the wireless client table.
First I found following hint:
http://forums.linksys.com/linksys/board/message?board.id=Wireless_Routers&message.id=46517
then did the following which solved my problem!
I entered the MAC addresses of my wireless devices into the client table and made sure that all remaining entries where not of kind 00:00:00:00:00:00.
Apart from my valid MAC addresses (2 devices) i just had to enter 00:00:00:00:00:03, 00:00:00:00:00:04 and so on! The last entry in my table is
00:00:00:00:00:16.
That's it. Cheers
[French]
Bonjour,
la solution: pour mon problem est la suivante:
Apres les inscriptions des votre adresses MAC vouz entrez dans les lignes qui rester
adresses MAC qui sont different que 00:00:00:00:00:00.
Donc, si vous avez 2 adresses MAC la troisieme sera 00:00:00:00:00:03,
la prochain 00:00:00:00:00:04 .... juste a la dernier 00:00:00:00:00:16.
Voila!
Linksys Wireless-G WRT54GR Router Logo
WRT54GR not connecting for wireless
To connect to your wireless router, the router's wireless settings needs to be configured with the SSID, encryption etc. and also the wireless cards in all the laptops/computers needs to be configured with these router's wireless settings. Then the laptops/desktop computers can communicate with your wireless router.
Connect a LAN cable from the Linksys to the LAN port on your computer.
Open a browser and enter the Linksys configuration URL
http://192.168.1.1
The default login = admin
The default PW = admin
You can protect your router by changing the default admin PW (write it down and put it in a safe place)
Go to the wireless configuration and set up the SSID and WPA or WPA2 encryption.
Now apply these settings to the wireless card in your laptop/computer.
To secure your wireless network from unauthorized access, please click on this link and follow my instructions :- http://www.fixya.com/support/r3559128-wireless_router_security
Sep 04, 2012 | Linksys WRT54GR Wireless-G Broadband...
I want description on how to connect twp linksys wrt54gr routers to the same DSL modem ?
Hi
I understood that , you need to connect router with DSL modem .
1- connect router with pc by cable
2- change your IP address to be DHCP,
3- open internet explorer and type the default IP for the router , usually be 192.168.1.1
4 -it ask you about used ID and Password insert the default one usually be : admin and password : admin or password
5-choose from left menu wlan, and insert your user name and password ,chose the type of connection ppeo broadband .
to this step it must work correctly if you click connect
Apr 25, 2011 | Linksys WRT54GR Wireless-G Broadband...
cannot find security number for router wrt54gr
connect your router to computer with ethernet cable.
Then you can access it with following link.
http://192.168.1.1
or
http://192.168.0.1
type user as "admin" and password as "admin" or blank or "password"
Then you can see configuration page of router.
Clickon wireless security check wep code it is your password to connectinternet .You can also change it there then save and restart router totake effect.
Let me know if you need further assistance.
Thanks for using FixYa.
Dec 25, 2009 | Linksys Wireless-G WRT54GR Router
Linksys WRT54GR-UK Connection Problems
Try changing the default ip address of the router to 192.168.2.1. Sometimes the ISP's modem is set at 192.168.1.1 which will conflict with a router using the same IP.
Jul 06, 2008 | Linksys Wireless-G WRT54GR Router
problem connecting to the net
You router may be set to be DHCP enabled so that it allocates the ip addresses automatically to each pc, so check that the pc's network card with connection problems is set in the properties on the TCP/IP line is set to obtain an ip address automatically. You can also try, Start>run then type ipconfig /flushdns to clear the pc ip address and dns. and restart pc. Lastly if you pc is both network cabled and wireless, ensure one or the other is dissabled as this can confuse the ip adress alocation.
Apr 29, 2007 | Linksys Wireless-G WRT54GR Router
791 people viewed this tip
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
