Tip & How-To about Computers & Internet
Guide to Reset Password on a Cisco Router
How do I reset the password on my Cisco router?
I bought a Cisco 1700 router from an auction, but there is a password. How can I reset the router to original factory specifications?
Sky sagem wireless router reset password? I just got this sky wireless router second hand and it has a password set on it. i tried to press the reset button at the back but it does not do any thing, it still comes as a password is set.
How to reset password on dlink wireless router? I have a dlink wireless router model number DIR 825 . It works good but I am trying to access internet on my ipod and the password i have set is incorrect , this also happened when i tried to access internet on my laptop. When i first set up my ps3 i dont recall having to put a password in but this was when i first got the router. How do i reset the router password or find out what the password is AND if i reset the password or reset my router will my ps3 have to be reconnected or will it stay?
How to reset password on a router? I recently acquired a linksys router (used) and need to know how to reset the password so that I can use it. Also, is there any way to modify a router to be useful as a cell/wifi blocker, or as a signal booster?
----From Yahoo Answers
To reset password on a Cisco/D-link/Linksys/Netgear router is a very common problem among people who want a secure network environment for surfing on the internet. If you are confused with the complicated procedure to reset or change the password on a router, or if you are trying to configure a Cisco router, but a password is blocking you from enable mode, don't worry, just do the steps as follows, password reset on a router is no longer upset to everyone.
First, be informed that what you need:
.Cisco Router
.Computer
.Internet Connection
.Blue Serial Cable
Guide for You to Reset Password on a Cisco Router:
1. Download a program called Putty from the first resource site below. PuTTy is a terminal emulator application which can act as a client for the SSH, Telnet, rlogin, and raw TCP computing protocols (PuTTy on Wikipedia).http://en.wikipedia.org/wiki/PuTTY
2. Connect one end of the blue serial cable to the Cisco Router and the other to your computer. Open up the Putty program on your computer and select the radio button next to "serial" on the right-hand side of the start window. Click on the "Open" button in the bottom right-hand corner of the Putty start window to open the terminal.
3. Power the Cisco Router on. As soon as the router begins loading in the green and black Putty terminal window, press the "Ctrl" and "Break" keys simultaneously until its going into rommon mode.
4. Once in rommon mode, you have to change the configuration register number to make the router boot from a blank configuration file. For the 2800 series Cisco Routers, the command "confreq 0x2142", changing the register number to 2142, worked. Search on cisco.com for information on your particular Cisco Router Series.
5. Type the restart command in rommon mode, which is "reset". This will boot the router up again. When it is finished, you should be able to type "en" to get into enable mode without a password.
6. Once you change the running-config in RAM and save it to the startup-config in NVRAM, remember to change the configuration register number back to its default (usually 0x2102). This is important if you change anything on the running-config.
Easy five steps help you finish resetting password on a Cisco router. Easy instruction, easy to follow.
Computers & Internet Logo
I bought a cisco valet router used and do not know the password , how do I change the password
On the back of the router is a reset button. Press that in for 5-10 seconds. It will reset to factory specs. Once you reset the Valet Hotspot, all of its customized settings (network name, wireless security, etc.) will be erased and the hotspot's IP address will be reverted back to 192.168.1.1, with a default password of admin and no username.
Jul 30, 2016 | Cisco Computers & Internet
cisco 1760 router had not accept password i think i forget my give me suggesion to recover it
you will have to reset it or recover it. It can be a lengthy process, here's the howto on cisco's site for a 1760 router password reset/recover:
http://ciscosystems.com/en/US/docs/routers/access/1700/1760/hardware/installation/guide/trblsht.html
Apr 01, 2010 | Cisco 1760-V Router
how to check serviceability of cisco 1700 router
Cisco 1700 routers are very useful for the small office or even home, they have an ethernet interface built in an optional module slot normally that has a T1 card or another ethernet interface, it can vary. If the optional interface is not what you require then one can be located via internet.
Jul 17, 2009 | Cisco 1700 Series Router
i have the Dlink 1700 series router i need to add in 2vlan.its possible
Usually you can create VLANs on routers. On cisco 1700 (based on ur image) you can create multiple VLANs.
If you can give me the exact model number on dlink i can help you to fix the problem.
Jun 10, 2009 | Cisco 1700 Series Router
533 people viewed this tip
David Payne
David Payne
