Tip & How-To about Hand Tools
Crankshaft damper turning tool
In a pinch, don't have the right tool, take an old serpentine belt,
cut it to fit around the damper plus about 4inches on each side,
take some welders c clamp pliers and pinch the serpentine belt
close to the damper, now you have a handle to turn as well as
leverage. good luck!
Hand Tools Logo
where to place jack and stands to replace water pump and serpentine belt on 98 grand am gt
Put a peice of wood on the jack saddle and jack the vehicle on the passenger side pinch weld if you are using a floor jack. If using factory jack... It fits over the pinch weld right below the rocker panel. Put jack stand under lower control arm
Apr 11, 2015 | 1998 Pontiac Grand Am
serpentine belt pattern, belt won't fit
A serpentine belt (also known as a multi-vee or multi-rib belt) is a single, continuous belt used to drive multiple peripheral devices in an automotive. ---------------------------------------------------------------------------
Car Diagnostic Tools
Dec 08, 2012 | 1989 Mercedes-Benz 300-Class
the belt came off my record player how do i put it back on
take out the plate. there is a small wheel that turns and a big wheel below the plate. You should put the belt around them both and then put the plate on it (be careful, it's heavy).
Nov 16, 2011 | Audio Players & Recorders
I can't find the right harmonic balancer for my '86 jeep cherokee. I need one for a v-belt type (it has two belts on the one balancer going different directions). the one i keep finding is for a serpentine belt.
Don't know if you purchase auto parts online, but here is your part. Its about $75. go to jeep4x4centerdotcom and search for Part # 3225201. It is called a Vibration Damper - Harmonic Balancer) w/ V-Belt Hope this solves your problem.
Aug 24, 2011 | Jeep Cherokee Cars & Trucks
how do i take of a pulley and tensioner of a 94 Dodge Caravan 3.0 L V6
You'll need a Serpentine Belt Tool and a socket set.
Rotate the Caravan's serpentine belt tensioner assembly clockwise to relieve the tension on the belt. Slip the belt off the tensioner with your free hand before rotating the tensioner back to its home position. Remove the tool.
Extract the two mounting bolts that hold the serpentine belt tensioner assembly to the Caravan's front engine cover using your socket set. Depending on your physical size and dexterity, you may find this easier to accomplish through the top of the engine well or through the passenger-side wheel well.
Pull the old serpentine belt tensioner assembly out of the Caravan's engine bay by hand. Place the new serpentine belt tensioner assembly on the Caravan's front engine cover and bolt it in using your socket set.
Rotate the new serpentine belt tensioner assembly clockwise with the serpentine belt tool and then place the belt on the pulley by hand. Rotate the new serpentine belt tensioner assembly back into place. Remove the tool and close the hood.
May 19, 2011 | Dodge Caravan Cars & Trucks
831 people viewed this tip
Top Hand Tools Experts
Don Numinen
Don Numinen
Ivan
Ivan
Level 1 Expert
Bill Boyd
Are you a Hand Tool Expert? Answer questions, earn points and help others
