Tip & How-To about Microsoft Computers & Internet
Driver updates
Sometimes after a fresh install of a new operating system, the system won't recognize a certain device. If this happens then you need to update drivers in device manager.
click start,right click computer,click on manage,click on device manager,look for yellow ? and ! symbols,right click,update driver.
(note) you have to be connected to the internet for the update to work.
Hope this helps.
Computers & Internet Logo
Dell Inspiron 1420 is not able to read empty cds or DVDS. My I go to properties it shows empty space as 0. When I try to burn a Cd it says " Insert a blank CD"
Stephen buddy, we need to talk. I do NOT understand anything you are trying to describe. Okay, so you installed a FRESH Operating System and now it is NOT recognizing your DVD-rom, right? Okay, restart the computer and let Windows load up fully. Check Control Panel and check your list of Devices. Sometimes, when you re-install and O.S., you may have to update the firmware or drivers for certain devices.
Feb 05, 2014 | Dell DVD-rom DVD Drive
my xperia x8 won't start up
the problem is as a result of software corruption. Your phone operating system is corrupt for one reason or the other. The phone operating system might have gotten virus through bluetooth transfer, internet browsing or via the memory card.
To solve the problem, you need to flash the phone . Flashing the phone means reinstalling the phones operating system software files. The phone will be fully formatted and a fresh operating system files will be reinstalled.
You can use software updater to flash the phone. Download software updater from sonyerricon.com. Install it on your computer, open the software updater, connect the phone via usb cable to your computer. Allow the computer to recognize the phone, then click update. Follow all direction from the software updater application. And your computer must be connected to the internet.
I hope you understand this.
Good luck.
Nov 07, 2011 | Sony Ericsson XPERIA X8 Cell Phone
I bought a new hardrive for my m2000 and when i load it it is giving me a "media test failure" response..... how do i load it properly?
If you bought a new hard drive (meaning the internal hard disk), it won't have anything on it. If you just install it and try booting your computer, there won't be an operating system to load. The BIOS (the operating system built into the motherboard) is set up to try loading the operating from connected devices in a certain order. Usually it tries the optical drive first, then the hard drive, and finally it tries to boot over a network connection. The media test failure message means it tried that last resort and still didn't find an operating system, and it's telling you that maybe you have a bad network cable.
You'll need to reinstall your operating system and applications so that the computer will start normally. If your computer came with a restore disc set, or you made a set yourself, you'd use those. If you don't have restore discs, you can do a fresh installation of Windows from CD. You need to find the disc for the version that came installed on your computer, since you'll need to use the product key from the sticker on the bottom. Drivers and utility programs you can download from Compaq's (HP, actually) support and drivers website.
Once you've got a bootable Windows system on the new drive, you won't get that strange message any more.
Jun 03, 2011 | Compaq Presario M2000 Notebook
computer won't recognize the store-it drive external hard drive
You may have a problem with your drive or the usb ports so we need to check both. The green light usually just means the device is getting power.
The first thing to do is unplug the drive and reboot the computer. Make sur eit has finished booting up completely. Then plug it into a different usb port NOT the same one. If it detects and works it was just the operating system or motherboard not recognizing whats called a legacy usb device.
Next we want to try a different usb device in the computer to make sure the ports are working.
And we want to try the drive in another computer to make sure it is working.
At this point you will know if the problem is your drive or the port. If it is the drive you can get it runnning again sometimes by taking the actual drive out an dputting it into a new external drive enclosure kit.
Jul 09, 2009 | Pexagon Store-It 80 GB USB Hard Drive
USB port problems with hp printer
There are few things to remember using USB.
  • If your System is in hybernation mode, don't remove any attached USB device, because it will damage your USB driver. This is one of the known problem from microsoft.
  • If you have to remove any USB device use 'Safely Remove Hardware'.
To remove currepted USB drivers its not enough to remove your printer drivers.
  1. You should un-install the 'Universal Serial Bus Controllers' from Device Manager.
  2. Then re-boot to clean registry.
  3. Install the 'Universal Serial Bus Controllers' using XP Setup CD.
  4. Then check the Mass storage, PDA etc, it should recognized by XP.
  5. Then install printer driver (don't attach printer to system untill setup finish or setup says to connect).
I think it will fix.
Please let me know your feed-back.
Thanks
Iqbal
Apr 15, 2008 | HP Photosmart C3180 All-In-One InkJet...
1,009 people viewed this tip
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
