Tip & How-To about Computers & Internet
Local Area Network is missing on Network Connection for XP
There are time that the LAN icon under network connections are not showing and you cannot get internet connection. These are easy steps to fix the LAN problems: - Click on start- Right-click on My Computer and choose properties- Click on the Hardware Tab- Click on Device manager - Click on network adapters- Then right click on the Ethernet controller under the Network Adpater and choose uninstall- after uninstalling, right click on Network Adapters and choose Scan for hardware changes- then let windows re-install the Ethernet drivers and reboot the computer.- you can now check the internet connection.-Enjoy!
Thank you using this Tip from Fixya.
Computers & Internet Logo
my toshiba laptop does not work on a lan. The icon
When you look at the Manage Network Connections link on the Network and Sharing Center you do not see
Local Area Connection?
Do you see Wireless Network connection?
You need to check the device manager to see if the card has been disabled.
It should show two entries with no red or yellow marks. One for wireless (WLAN) and one for wired (Ethernet)
Apr 11, 2010 | Computers & Internet
Unable to connect two wireless laptop for internt sharing
Make sure your computers are set to DHCP instead of static.
Sep 04, 2009 | Dell Inspiron 6400 Notebook
I HAVE A BUILT-IN NETWORK ADAPTER IN MY COMPUTER FUJITSU, M0DEL FMV 6000CX2 HOW CAN I INSTALL IT AND MAKE IT WORK.
Normally it is automatic enable.
U can see a local network connection (LAN) icon appear under network connection. The icon will show u unplugged if u did not connect to any network or devices.
If u did not see the LAN icon, then u need to check under device manager whether there is any missing driver.
Mar 10, 2009 | Computers & Internet
lan card is not showing in network adpators for dell inspiron 110
hi gangesh click on the start button......connect to.....go to all connections......the choose your lan connection right click and go to properties........then make sure the bottom two boxes are checked...the one that says show icon in the notification are when connected......and the one that says notify me when me i have limited connectition.
this will give the icons in the tasbar.....
now if you want to put in a manual ip address ect...then in that properties page click on tcp/ip then click the properties button....
there put in your ip and subnet mask and gateway and dns.
hope that helps.
Nov 03, 2008 | Dell Inspiron 1100 Notebook
Lan Problem
Goto control panel and work your way through the network Set-up Wizard.
If this is not a separte Icon in control panel then look under "network Connection" Icon.
Feb 26, 2008 | D-Link DFE-530TX+ Ethernet ED100W Network...
1,636 people viewed this tip
David Payne
David Payne
