Tip & How-To about Mag Innovision LT776s 17" LCD Monitor
Setup Menu for MAG LT776 Model 780
I had a blank screen and went through the Setup tips here (in the blind) only to discover it was 3 bad caps on the PCB. I replaced them (tight fit) with more low-profile ones. They were swollen only, not burst or leaking. I put new 220uf 16V ones in, got my screen back.
I realized that it would be helpful if there were an image available for anyone troubleshooting, especially if not familiar with this model, or it's setup. I made the following image, maybe it will help someone in the future.
I see the image is resized for the forum, here is a link to a full size (700 x 850) viewing.
Full size Setup Screen
Mag Innovision LT776s 17" LCD Monitor Logo
Hello!Sony SDM-HS73 power-inverter problem
At this point you may have bad transformers, bad tuning cap, you need to check the frequency of the inverter oscillator to see if both of them are running at the same frequency, the bad one may not be. The Inverter/power supply is not made by SONY, Powernet makes the board. Please see what went wrong with the one I fixed.
http://s807.photobucket.com/albums/yy352/budm/Sony%20SDM-HS73/
One thing to keep in mind, when the board turn into carbon (blacken), it will conduct. The circuits operate at high voltage and high frequency.
Apr 09, 2010 | Sony SDM-HS73/H (Grey) Monitor
Vertical blanking
CHECK C2C52 10 UFD @ 50 V OFF THE BASE OF Q2C51 ON THE SIGNAL PCB. 2. CHECK C2P05 100 UFD 16 V OFF PIN 3 OF IC2P01 AND IC2P01 PART # 270P466020 (9-VOLT REGULATOR). BOTH ARE ON THE SIGNAL PCB.
Dec 06, 2007 | Mitsubishi VS-60705 60" Rear Projection...
The screen is all white
You need to re-seat replace the ribbon cable that is connecting screen to main board. Possibly out place after unit was dropped.
Sep 07, 2009 | Sony Ericsson K510i Cellular Phone
monitor just quits,
you posted to a wrong place, to an empty stop, its not a response post at all. but....
old old VS19 , with CCFL inside, (oops)
the OSD is dead, proving the monitor is dead.
the CCFL laps are bad or the board is a bad.
not all boards (PCB) fail for caps, unless,made in the bad china cap era....
i buy my caps at Mouser ,x10 better quality btw.
there is more to this board than just a cap
photo is of early L1503.
best place to look is get a used board from Ebay.
HP does not sell this board now, its LEGACY.
nor do they sell or offer schematics (lacking that very hard to fix)
those 2 black rectangles below are the CCFL high voltage generators. ether can fail. and CCFL is dead.
use a flash light to the screen yet , while pushing the Menu key there
for the OSD display to show up???? if it does then the CCFL parts
are bad. dead backlight.
Aug 04, 2017 | HP vs19 19" LCD Monitor
mitsubishi HD1080
Good Day;
You may have a bad lamp. What lights show on front panel? Check this when no come on:
1. Red status LED, self-diagnosis error 44, check for open F9A06 on the Power PCB part # 283P128050 on the Power PCB 2. Red lamp LED, self diagnosis error 34. Check for 5-volts DC at J-9 connector pin 1 and 2 on the Engine Driver PCB if missing replace the Power PCB part # 930B921002 3. LED stops blinking after 70 seconds of plug in but will not power on. This model is equipped with a keyboard lock feature, this can be mistaken as a no power condition. To unlock the keyboard press and hold the "menu" button on the front panel for 10 seconds 4. LED stops blinking after 70 seconds of plug in but will not power on. Check for 3.2 volts DC at connector LE pin 3 and 4 on the Control PCB, if low suspect problems with the switches/buttons on the Control PCB part # 935D776001 5. LED stops blinking after 70 seconds of plug in but will not power on. Keyboard is not locked and key inputs at connector LE pin 3 and 4 check good. Suspect the E2P PCB part # 934C121001 6. (LED does not stop blinking after plug in) Disconnect the USB connector from the card reader to the front from the Chassis, if the LED stops blinking after 70 seconds replace the Card Reader part # 299P271010. 7. (LED does not stop blinking after plug in) Disconnecting the USB connector from the Card Reader did not help. Remove connector FC from the FMT PCB and plug the unit in, if the LED stops blinking after 70 seconds with FC removed suspect a problem on the FMT PCB (part # 930B924002), if the LED keeps blinking with connector FC removed suspect a problem on the DM PCB (part # 934C116002). 8. (LED does not stop blinking after plug in) On the DM PCB (part # 934C116002) check C81A2, C81A3, C81B3 and C81B4 (1000 UFD, 16V, 105C), if any are bad, replace all of them with part # 181P734030 (680 uFD, 16V, 105C). See Service Tip VS-78A 9. (LED does not stop blinking after plug in) On the FMT PCB (part # 930B924002) check C8F19, C8F21, C8F22, and C8F27 (16V 1000 UFD 105C), if any are bad, replace all of them with part # 181P734030 (680 uFD, 16V, 105C) See Service Tip VS-78A .
Good Luck, big IRISH.
Sep 10, 2008 | Mitsubishi WD-52525 52" Rear Projection...
2,469 people viewed this tip
Top Mag Innovision Computers & Internet Experts
William Miller
William Miller
Rommel Balcita
Tony
Are you a Mag Innovision Computer and Internet Expert? Answer questions, earn points and help others
