Tip & How-To about Vornado Circulating Fan
VORNADO FAN BROKEN BLADE DONT REPLACE!!!!!
My dog knocked off my vornado which then broke a blade off my favorite fan. I was going to use epoxy to try to get the blade to stick back on. This would not work. The fan spins to fast to use glue. I sat and thought about it for awhile and came up with a solution rather then spending 39.99. I used epoxy to get the blade where it should be and let it dry..... then took a hot nail and poked a hole through each blade close to the center of the shaft.... and then took a zip tie and connected each zip tie to each other forming a ring around the shaft. This works very good and if you need to balance out the fan just place a small zip tie on the center and clip off close to the lock. Now you can use the LOCK as a balance for the fan. GOOD LUCK
Vornado Circulating Fan Logo
where can I purchase a Vornado fan replacement blade for a Type 530 Vornado fan?
Hi carim.
I think this one NuTone S99020165 Ventilation Fan Blade Fits. Anyway, contact the vendor before buying it.
I hope it was helpful.
Enjoy
Jun 03, 2011 | Vornado (CR1-0073-06) Fan
Vornado Circulating Fan - motor will run but blades will not turn.
Does the motor spin, but the blade is not turning?
The motor has a D shaped shaft. If the hole in the blade that the shaft goes in is rounded, then the blade will spin. In that case you need a new blade. Vornado can supply that.
Jun 27, 2010 | Vornado Circulating Fan
Opening Vornado fan (model EH1) for cleaning
How do I open vornado fan (model eh1)so I could clean fan blades?
Jul 03, 2009 | Vornado Circulating Fan
2,199 people viewed this tip
Top Vornado Dryers Experts
Steve
Ian Summerfield
Ian Summerfield
Mack Baxter
Are you a Vornado Dryer Expert? Answer questions, earn points and help others
