Tip & How-To about Computers & Internet
My system says I'm connected to the network, but I get "Page Cannot Be Displayed" in my browser
  1. See if you can boot to safe mode with networking (F8 at boot, if you get an operating system choice, press enter then F8) and see if you can access the internet. (This works for Wired network connections and most WIRELESS connections in WINDOWS 7) If you can, go to HTTP://WWW.DOWNLOAD.COM and download Malwarebytes. It will install from the safe mode and you can run it from the safe mode. Have it do a full scan then reboot to the normal mode after any fixes it recommends are run.
  2. If you can't get any pages with your browser, even in safe mode with Networking, then you may have an issue with your router/modem. Power down the system, then power down and unplug power from the Router, then power down and unplug the DSL/Cable Modem. WAIT 5 MINUTES Power on the Modem, wait for it to complete self-test (About a minute for most) then Power on the router and again wait for self-test, the power on the system.
  3. If you are still getting a valid IP address (Start RUN CMD, they type IPCONFIG at the command prompt, in XP, Start CMD, right click CMD on the menu, Run as Administrator in 7) and see if you have a 192.168.xxx.xxx IP address and a default gateway. If you do then the router is working and you may have issues with the cable modem. if you have a 169.254.xxx.xxx IP address and no default gateway then you system is not getting a valid IP address and is assigning one on it's own. In this case, I'd try a system restore to a time when it worked. If that is no go, you may have a NIC failure.
Computers & Internet Logo
boot menu
Your computer's BIOS, or basic input/output system, regulates several important system functions before your operating system loads.
The BIOS can even tell your operating system which device it should load from, whether the computer's hard drive or a USB stick.
You can control this and other options from the BIOS boot menu.
If you own an Acer Aspire One netbook and want to access the boot menu, you can do so by entering the computer's BIOS.
Turn off your Acer Aspire One netbook.
Turn it back on.
Press "F2" when you see the Acer logo appear as the computer boots up.
This will open the computer's BIOS menu.
Press the arrow keys to highlight the Boot option.
Press the down arrow key to highlight specific boot settings to change.
also
Windows operating systems support a variety of boot options on the Windows Advanced Options Menu that allow you boot your computer based on your need.
They support boot options such as Safe Mode, which is generally best for troubleshooting and virus removals; or the Safe Mode with Networking, which allows to use an Internet connection while troubleshooting system problems.
Within seconds, you can access the boot menu and select the option that works well for the task you want to accomplish.
Shut down all currently running programs and restart your computer.
Press "F8" repeatedly before the Windows icon shows up on your screen.
This will bring you to the "Windows Advance Options Menu."
Scroll down and select the boot option you want.
Press "Enter."You can select from "Safe Mode" "Safe Mode with Networking" or your regular booting option.
Choose the boot option based on your need.
For troubleshooting, it is advisable to select "Safe Mode" because only a certain amount of drivers and resources run allowing you to resolve issues.
Jun 28, 2013 | Acer Aspire One D250 (99802378332) Netbook
Please help me with problem starting up windows because of forgotten password
The password first.
Restart your computer repeatedly tapping the f8 key to enter safe mode while the screen is black once in safe mode where the only things working will be your keyboard and mouse allowing you to attempt to repair your computer Windows Advanced Options Menu Please select an option: Safe Mode
Safe Mode with Command Prompt Enable Boot Logging
Enable VGA mode
Last Known Good Configuration (your most recent settings that worked)
Directory Services Restore Mode (Windows domain controllers only)
Debugging Mode Start Windows Normally
Reboot
Return to OS Choices Menu Use the up and down arrow keys to move the highlight to your choice select safe mode with command prompt Click start run type cmd press Enter black screen should open DOS mode this will vary depending on your operating system type in net user username For eg. If you want to change administrator password , type net user Administrator It will prompt you to enter the new password. Enter the new password and the password is changed if this fails you will need to Select safe mode with networking to download you could download all of these or just one save them to a usb drive for later use if one fails to remove the password Windows Password Recovery Basic http://majorgeeks.com/CmosPwd_d239.html A CMOS BIOS password recovery tool Editors note: This tool should only be used by experienced computer users. Please see the enclosed read me if you would like to run it from Windows. Failure to follow instructions (from Windows) will cause your anti-virus to flag this as a virus. http://majorgeeks.com/Dr._Freeware_System_Utilities_d6416.html Dr.Freeware System Utilities which includes data recovery software, data backup, password reset tools for Windows helps you to maintain your system. Dr.Freeware is freeware, you can download and use it for free. Now if you want to reinstall or load another operating system.
Restart your computer during the boot process you will see on the screen to press a certain key to enter setup usually the Delete or F2 key
Press and hold that key during the boot up process to enter BIOS then using the arrow keys scroll down to advanced bios features press enter change your first boot device to cd press escape then press f10 to save to cmos to restart
Note this will erase you operating system you will have to have an operating system disk to load it onto you hard drive or create a partition to load another operating system
Note after you have loaded the operating system you should go back and change the first boot device to failsafe or optimised defaults
after windows has loaded
your computer will automatically restart it might restart 2 times one to finish the installation
the next will be because the operating system is loaded and will boot from your cd
Hope this helps.
Dec 22, 2012 | Computers & Internet
remove virus of my computer
Reboot the computer As the computer is booting repeatadly press the F8 key as the computer is booting If done properly the user should get to a screen similar to the below screen. Select the option for Safe mode command prompt only Windows Advanced Options Menu
Enable VGA mode
Reboot
Return to OS Choices Menu Use the up and down arrow keys to move the highlight to your choice select the safe mode option then run your antivirus if still cant get rid of the virus restart again Use the up and down arrow keys to move the highlight to your choice. select safe mode with networking download anti malware and microsoft security essentials http://www.microsoft.com/en-us/download/virus-malware.aspx?q=virus anti virus and malware http://windows.microsoft.com/en-US/windows/products/security-essentials
Dec 13, 2012 | Computers & Internet
how do i get into the safemode on the gateway 7405gx laptop
For any windows computer its always F8.
But some times there are few boards which are designed to launch Device Boot Menu when you press F8. If you are struck with this kind of screen,
Then Choose the Hard Drive from the List then Press Enter and immediately start tapping F8 you should get the advanced boot menu now. Make you choose the Hard Drive from the list then press enter then immd start tapping F8. That's it
Feb 04, 2011 | Computers & Internet
226 people viewed this tip
David Payne
David Payne
