Tip & How-To about HP Officejet Pro 8500 Wireless All-In-One InkJet Printer
HP all-in-one disable sleep mode and other secret menus
Yes, you CAN actually disable the sleep mode on HP all in one printers, set the rings to answer outside the 2-6 ring range and many other tricks and tweaks. These secret modes and settings are pretty heavily guarded because changing them involves accessing modes that contain settings that may BRICK the unit (render useless).
If you need to modify a specific behavior of an HP inkjet like changing the MAC address of the network card for a specific purpose etc, there's a large number of settings that can be accessed.
Send an email to me (Fixya@SuperTech-IT.com) specifying what you need to change and WHY you need to change it, and I will help if there is a way to do it in the machine.
I do charge for this advice, as a preventative measure against consumers posting the information I give out for free.
I also reserve the right to refuse certain services (and would not charge of course in that case) for ethical reasons. For instance, if you want to change a unit's serial number in the firmware, you better have a really good reason for doing it, and I have to believe your reason!
HP Officejet Pro 8500 Wireless  All-In-One InkJet Printer Logo
HP 1217 M1217 nfw MFP won't receive fax
Having the TAM set to four rings seems a bit high to me. Decrease the ring count on the Tam. the fax ring count does not really matter.
Keep your outgoing message to a minimum . if too long the calling machine will time out and drop off the line.
see how that goes. Also are you using the genuine adaptor lead. Does the tam actually ring? I suspect not. there are literally loads of adaptor leads that will fit and look the same but they are wired internally for that make only.
Jan 25, 2014 | HP Hewlett-Packard - LaserJet Pro M1217nfw...
having troubles with fax not dialing out
Disable call waiting is only set to "yes" if you have call waiting, press "menu" then scroll down to "reset all setting" make sure to backup phone entries before doing this . Follow the "fax settings" below:
FAX SETTING FOR 5500 (VOICE MAIL)
- ANS. MODE TO "YES"
- ANS. MACHINE RINGS "3"
- FAX RINGS TO ANS. "4"
FAX SETTING FOR 5500 (ANSWERING MACHINE)
- ANS. MACHINE RINGS "4"
- FAX RINGS TO ANS. "3"
Nov 22, 2008 | Kodak EASYSHARE 5500 All-In-One InkJet...
3,471 people viewed this tip
Clive
Clive
Thomas F. Schneider
