Tip & How-To about Compaq Presario 5000 PC Desktop
Model # for Presario 5000
Model # can be found BEHIND the 2 disc holders inside the front of the case! Mine is 5UVME2...good luck
Compaq Presario 5000 PC Desktop Logo
Is Part # 3850A20500F one of this model? my unit
I found the model # on my Goldstar DH304 at the top of a sticker on the inside of the unit behind the bucket. Mine has stopped working too. I'm awaiting an answer to my problem but after some research it seems that unless the filter and/or coils simply need cleaned, there is lttle that can be economically repaired. Good luck.
Sep 01, 2010 | Goldstar DH304 Dehumidifier
Code DL then F What does this mean?
i just finished fixing this problem on mine. DL = Door Latch. i am guessing you hear 6 clicks (processor trying to latch door) then the error. while i was poking around inside the unit i found a service manual inside (behind the bottom cover, remove 3 screws to gain access). the service manual reminded the tech to always try unplugging and replacing the connectors on the processor since oxidation is a major problem. the manual also noted the connector numbers (DS3... i think). i removed the top cover (3 screws on the back, slide back, lift off), found the processor, unplugged and reseated the connectors (did some others just for good measure), plugged the unint back in (ALWAYS UNPLUG BEFORE WORKING ON IT), and it worked. in case that doesn't fix it, you couldtry replacing the latch assy for about $50. good luck
Sep 17, 2008 | Kenmore Elite 45986 Front Load Washer
two issues with this system
Hi eshort
When you press the buttons to operate the Cd drawers, do you still feel a click under your fingertip the same as the rest of the buttons. If not, the plastic piece may have broken away from behind the front panel assembly preventing the switches from operating be from the front panel. It may as you have already diagnosed be a part broken off the transport also.Only further investigation will determine this:) Can you still operate the unit from remote control?
The LCD display will use an incandescent lamp to back light it. this lamp will have failed. These are replaceable, the degree of difficulty varies from model to model. Pop the lip off and check if it is easily access. The worst cases need to have the LCD display removed to replace the lamp. Good Luck, thanks for checking with FixYa
regards
Graeme
Mar 11, 2008 | JVC HXD7 5-disc Home Stereo Theater System...
xbox360 game cases
i have mine in plasty pockets, try that.
Sep 13, 2007 | Microsoft Xbox 360 Console
broken ps2 slimline , sounds like the disc is catching sumthin, any help? could it be the draw, still isnt working, help??
ok the problem i had was the disc would not read and it sounded like struggling to read. 1/ if under warranty-use it 2/if not you need a small phillips screwdriver and a flathead screwdriver. Take the back soft pads off and unscrew x2.then use the flathead and unclip hard plastic (not rubber)front ones x3 and x1 back. Carefuly remove the top avoid touching the laser lens at all cost(this will cost you) Now to the problem The lens slides back and forth on the steel rods, i found that mine was sticking in a spot i put some crc on a tissue and cleaned the steel rods. Too test while still open put the leads in and (power last) and turn on .In order to fool the machine to think it is shut there are 2 trigger point to push down 1 next too the on button and the next is white and in mid-back when done together the disc will start to spin.(hopefully that was your problem as mine went back too whisper quiet and all my discs worked again) and just go in reverse to put back together Good luck and enjoy the experience
Apr 02, 2007 | Sony PlayStation 2 Slimline Console
2,593 people viewed this tip
Top Compaq Computers & Internet Experts
Abhinandan  Patil
Abhinandan Patil
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
