Tip & How-To about Office Equipment & Supplies
EPSON PRINTER INKPAD RESET COUNTER
There are issues on printers especially with epson is the dreaded error " PARTS INSIDE YOUR PRINTER IS AT THE END OF ITS SERVICE LIFE"
This error is caused by a full ink pad or the ink pad reset counter needs to be reset.
to resolve this, for north american customers you can download a program called the inkpad reset counter. this is the site: http:www.epson.com/ipr
from there just fill out the required spaces then submit. install and follow the wizard. make sure that your printer does not leak because it means you need to replace the ink pads. and its another question.
hope this works and help you out
"Parts inside your printer are
Probably need to have the ink pads replaced in your printer, I would call Epson for support.
Jun 16, 2011 | Epson STYLUS R230 InkJet Photo Printer
Screen showed message that "parts
The message that you received indicates the ink pad absorbers are full and prevents the printer from running because unchecked it would leak ink everywhere including outside of the unit. To fix this you need to replace the pads with new ones and reset the counters to let machine know you have changed the pads. On top of that you must download a utility program for your model that will allow you to set up the counters so the printer will run. I strongly recommend replacing your printer especially when it is a refurbished item, even Epson feels it is better to replace.
Jan 08, 2011 | Epson Stylus Photo RX700 All-In-One InkJet...
" parts inside your printer are at the end of their service life.
This usually happens when the waste pads become full and need to be replaced.
You can try to do it yourself like this guy did on his printer:
http://www.hm2k.com/posts/parts-inside-your-printer-are-at-the-end-of-their-service-life
you can actually just use the software to reset the printer but eventually the pads will overflow and start to leak.
The last option is too take it to Epson and ask for a quote.
May 14, 2009 | Epson Office Equipment & Supplies
417 people viewed this tip
jasbo
jasbo
