Tip & How-To about Ingersoll Rand 231C-KS - 1/2" Super Duty Air Impact Wrench Kit With Flip Socket Set And Bit Dr - - Ingersoll-Rand - IR 231C-KS
How to use an Electric Drill
  • First You need to choose which kind of electric drill you are going to use - the cord or cordless. The one who has a cord attached might limit you because it need to have an outlet.although, it powerful then the cordless drill. On the other hand, the cordless drill can be use anywhere without needing an outlet.
  • Choose the wright drill according to your job. For an heavy-duty project purchase a more powerful drill but remember that it run slower and most of them have a cord attached to them. If you have lightweight jobs so you can use a cordless drill.
  • The safest way to use a drill is to make sure that the materials to are drilling are straight ahead of you or down below you. in additional, in case that the materials you are drilling is hard or thick one, in first use a hole punch to start the hole before the drill.
  • When you starting the job, push the drill slightly. start out slowly, and as the hole progresses, increase the speed slightly.
Ingersoll Rand 231C-KS - 1/2" Super Duty Air Impact Wrench Kit With Flip Socket Set And Bit Dr - - Ingersoll-Rand - IR 231C-KS Logo
I have two dewalt 1/2 electric drills and the extension cords are cracked. how can i replace the extension cords?
You will need to lay the drill on a bench then remove all the screws that hold the two halves of the case together, carefully pull the case apart to expose the wire connections
Mar 07, 2010 | Dewalt DC920KA Heavy Duty Xrp 18V Cordless...
how to apply an electric drill? how to used the electric drill?
Please follow the below steps to use a electric drill -
1. Determine which electric drill is best for you, the cord or cordless. The electric drill that has a cord attached needs to have an outlet which might limit you according to what job you are doing. The cordless drill is limitless and can be used anywhere without needing an outlet. Corded drills can be more powerful, where cordless drills are limited to power and can sometimes be a bit bulky.
2. Consider most of the jobs you may use an electric drill for. If you have a lot of heavy-duty projects ahead, you might want to purchase a more powerful drill. They run slower but have the power behind them to get the job done efficiently. The more powerful drills usually have a cord attached to them. If you have a lot of lightweight jobs to use a drill for, then a cordless one may be your best selection.
3. Arrange the work to be drilled either straight ahead of you or down below you. These are the two safest ways to use a drill. The drill is also more secure and won't waver while using it. If the material you are drilling is a hard or thick material, use a hole punch to start the hole before you drill.
4. Push the drill slightly as you are drilling to give a bit of added force. Start out slowly, and as the hole progresses, increase the speed slightly.
Tip -
Secure your work before drilling by using clamps. The more powerful the drill, the slower it drills. The less powerful the drill, the faster it drills.
Warning -
If you are using a cordless drill, charge the power pack before starting a job. Keep the air vents on the drill clean, and clear of any debris so the drill does not overheat.
Good Luck!!
Thanks
Sep 29, 2009 | Black & Decker Grinders
looking for Craftsman Cordless Screwdriver Charging cord
Go to the following link:
http://commercial.searspartsdirect.com/partsdirect/parts/5102970-17/0009/900&pathTaken=partSearch&filterPart=&pop=flush
Sep 12, 2009 | Craftsman 14.4 volt Cordless Drill/Driver...
Need to replace power cord to battery charger of cordless drill
it takes a 24V DC 200mA  The one I have is a Ktec Model KA12D240020034U
Aug 29, 2009 | Coleman Drills
what kind of grip is better for rough work?
Texture and contoured, should aid your grip, some Porter and Cable cordless drills have padded grips which you can choose to match your hand size - useful after an 8 hour shift
Aug 27, 2008 | Dewalt 18 Volt Compact Drill Kit
940 people viewed this tip
Top Ingersoll Air Tools & Compressors Experts
elunsford
John Trevino
Are you an Ingersoll Air Tool and Compressor Expert? Answer questions, earn points and help others
