Tip & How-To about Cell Phones
How to fix blackberry phone errors by Updating the Firmware?
Most Blackberry phones encounter errors due to phone software failure.
Here are some problems and as this definition shown below.
JVM stands for JAVA VIRUAL MACHINE
* JVM Error 501: During memory management, freeing of resources from memory failed as a result of possible corruption
* JVM Error 517: The BlackBerry Device Software encountered unexpected data in a memory location which is used for normal operations
* JVM Error 535: Interaction with the file system has experienced a catastrophic failure
* JVM Error 547: While writing data to the file system, a failure was detected
* JVM Error 548: While erasing data from the file system, a failure was detected
Some can be fix by Hard reset,but most phone need to flash the frimware to be recover.
Here are the step by step procedure on how to fix your phone by updating the Firmware.
* You need a good working USB cable
* Battery is Fully charged.
1. Download Blackberry Desktop Manager and install it. : HERE
2. Download Flasher blackberry Tool : HERE
3. download & install flash file : CLICK ME
4. Delete the vendor.xml file located in c:program filescommon filesesearch in motionapploader
Open flasher blackberry Tool shown on this illustration
5. Go Next
6. You can see usb pin number if your phone is connected to your computer. go next
7. This is very important, don't forget check the box all apps you need and Go next.
8. Wait the application loader flashing in progress ...
9. you're almost there and wait when update is successfull ...
Done....
I hope this method simple helps you.
Cell Phones Logo
jvm 545 error in blackberry bold 5
There is a problem with the Java virtual machine. This is software in the phone. You need to re-install the phone software.
Dec 21, 2013 | RIM BlackBerry Bold 9900 Cell Phone
my phone shows app error 523 and i cannot do any other thing
The blackberry phone is a very dynamic phone that requires regular software and system update.
The 'App Error 523' means that the phone encountered a Java Virtual Machine(JVM) application problem and as such is unable to continue running.
To Solve this Problem, Kindly ensure that your Blackberry is running the most current version of the blackberry device software.
Also, perform a reboot on your blackberry by removing the battery and reinserting it to reset it.
If after all of theses,the error is still showing, please contact your wireless service provider or BlackBerry® Technical Support Services for further review and support.
thanks
Sep 16, 2011 | RIM BlackBerry Curve 3G 9300 Cell Phone
I have balckberry Bold 9700. I have problem "JUM ERROR 102" Please help me.
i have the same phone. its JVM error 102 and you'll also get uncaught exception java.lang errors more than likely. its caused by a coruption in the software. its nothing you did, the software just failed. you can call your provider and do an exchange but it takes forever!! if you have a computer you can run the application loader and it will 100% FIX the issues. it saves all your info, wipes the old software, and reloads all the brand new software. this is from tmobiles website t-mobile.com/forums
Most JVM errors on a BlackBerry, can be fixed by simply reloading and updating your device software. For instructions on how to reinstall or upgrade your BlackBerry software, please see: HOW TO: Install New Software and Update (Application Loader) - BlackBerry®
There are some JVM errors that can not be fixed in this method, if you do encounter one of the below JVM errors, please call customer care at 1-800-937-8997 or 611 from a T-Mobile phone for further troubleshooting.
  • JVM Error 501
  • JVM Error 517
  • JVM Error 535
  • JVM Error 547
  • JVM Error 548
Didn't find an answer to your problem? Post about it in our BlackBerry Forums
Help us improve this article, please leave a comment.
Take me back to the BlackBerry Knowledge Base
***This link will show you how to reload new software with screen shots and a video!!!
http://forums.t-mobile.com/t5/BlackBerry-General-All-Devices/HOW-TO-Install-New-Software-and-Update-Application-Loader/ta-p/306005
***when this helps please give me credit and rate me appropriatlly, please!*****
Jan 03, 2011 | Cell Phones
some one tried to get on my phone password failed now it says jvm error 513 what do i do help please
this happens when the password was incorrect more then 10 times. here is a link below straight from blackberry webstie on how to fix it.
http://www.blackberry.com/btsc/search.do?cmd=displayKC&docType=kc&externalId=KB13003&sliceId=SAL_Public&dialogID=96016977&stateId=1%200%2096020207
Resolution The BlackBerry® Device Software must be reloaded on to the BlackBerry smartphone. For instructions, refer to KB11320.
Note: Due to the Java Virtual Machine (JVM) error, the BlackBerry smartphone will not show a Connected state in the BlackBerry® Desktop Manager. Proceed to reload the BlackBerry Device Software using the Application Loader.
if this has given you the answer on how to fix your phone, and was helpful in telling you what the error message means, mark this has fixya and please rate me. and if it has been really helpful please recommend me.
Nov 16, 2009 | RIM BlackBerry Pearl 8100
I screwed up my phone
Cause All of the data and applications on the BlackBerry smartphone have been deleted.
Aug 12, 2009 | RIM BlackBerry Curve 8310 Smartphone
2,290 people viewed this tip
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
