Tip & How-To about ASUS K8U-X Motherboard
Mother board over voltage
My problem this mother board K8U-X is over voltage...
ill try buy a new power suppply but the same problem..
what is solution this problem?
thanks....
alpha
ASUS K8U-X Motherboard Logo
Gaggia Titanium machine computer control malfunctioning
AN EXPENSIVE ELECRONIC MACHINE LIKE THIS ONE IS REQUIRED TO BE PLUGGED IN INTO A DEDICATED OUTLET WITH ITS OWN CIRCUIT. BROWN-OUTS, SPIKES, UNDER-VOLTAGES COMMONLY PRESENT IN ANY HOUSE WOULD CERTAINLY AFFECT THE MACHINE SENSITIVE POWER SUPPPLY AND ONCE IT FAILS THEN THE MOTHER BOARD , TOO.
Sep 05, 2014 | Gaggia Titanium Espresso Machine
facing problem with motherboard and power suppply in my acer aspire 4520.wat to do.
Might as well think of the cost of a new PC if there is severe damage on the board and the power suppy. If there is damage on the power supply alone , the SMPS can be replaced but if the mother board is also faulty then it is possible that a new board might be necessary.
Estimate
Feb 08, 2011 | Computers & Internet
asus K8U-X motherboard,which ram memory , and processor support?
hi..for this mother board model asus K8U-X only same brand Processor u can oly use.Like if u use Sempron made by AMD only AMD Processor for that board.Memory support is DDR1 PC400 1gig up to 2gig...good luck and Have a Nice Day..
Jun 14, 2009 | ASUS K8U-X Motherboard
p35-153-11z9 mother board need network adapter driver ?
Hi Paul, there isn't a separate driver for the Realtek 8201CL 10/100 Mbps Ethernet Controller. The driver is part of the chipset software & should have been installed when you installed the Asus motherboard support CD software. (Asus K8U-X).
Double check your bios settings. Check that the onboard LAN controller is set to Enabled. See page 2-19 in your Asus manual.
Link to Asus; http://support.asus.com/download/download_item.aspx?product=1&model=K8U-X
Link for manual; http://dlcdnet.asus.com/pub/ASUS/mb/sock754/K8U-X/e2010_k8u-x.pdf
Realtek wants people to use Driver Detective to help in finding drivers from RealTek, see the link posted; http://www.driversupdated.com/exact/realtek.php
(I do not know what the these mean from your post, P35-153-11z9)
If your LAN is set to enabled in the bios, try reinstalling your Asus CD software, (Chipset drivers). If the drivers still fail to install it is possible the LAN controller is defective.
Thanks for using FixYa Paul!
Need more help? Post here.
Mike
Mar 14, 2009 | ASUS K8U-X Motherboard
ASUS K8U-X OVER VOLTAGE?
Define over voltage. If you have the skill level to do it, go into the bios and check the voltages. Have you been trying to overclock the cpu by chance. Also have a look at the capacitors on the board. are the tops rounded ?
Robert
Aug 27, 2008 | ASUS K8U-X Motherboard
2,339 people viewed this tip
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
