Tip & How-To about Sony Alpha DSLR-A580 Body Only Digital Camera
Mac Canon MXF Converter-Transfer/Convert Canon XF300 MXF export to Quicktime MOV on Mac
Best Way to Convert Canon XF300 MXF files to Quicktime MOV?
Canon continues to innovate and develop image acquisition products for the most demanding professional. The Canon XF300 Professional Camcorder features 50Mbps MPEG-2 4:2:2 recording to Compact Flash (CF) Cards for unsurpassed image quality and efficient, robust workflow at an affordable price. It is ideally suited to match the requirements of electronic newsgathering (ENG) crews, independent filmmakers, documentary producers, event videographers and military agencies.
Utilizing file-based MPEG-2 compression with an MXF File Wrapper ensures the widest compatibility with existing industry infrastructure, metadata and non-linear editing (NLE) systems. And 4:2:2 color sampling provides ultra-fine transitions in tone and color for maintaining the highest quality image for use in advanced post production.
How to Imoprt or Transfer Canon 300 MXF videos to editing software, like: Avid Media Composer 5 ,iMovie 8 (iMovie 9) ,Sony Vegas ,Adboe Premiere ,Final Cut Pro,Final Cut Express.etc?
Follow the step to Convert MXF files to MOV/WMV/AVI .etc on Mac now.
Step 1: Download and install Canon MXF Video Converter for Mac, add your MXF file by clicking "Add" in the File menu or in the main interface.
Step 2: In "Format" drop down list box, you may select output format. The software allows setting different output formats according to different files. For example, I just set the QuickTime MOV as output format of the MXF file.
Step 3: Now let's select the output folder by clicking the "Output folder" icon.
If you want to Trim or Crop your MXF files and get the wanted part or area, if you want to replace original audio and add background music to the MXF videos, if you want to deinterlace, remove interlaces or image noises of the videos, please click "Edit" to get into editor windows and start your DIY process.
Step 4: Finally, click "Convert" in the main interface. After a successful conversion, click "Open" to check the QuickTime MOV files.
The detailed steps with Converting Canon MXF files to QuickTime video format
Tips:
1. For Window users ,you can use Canon MXF video converter.
2. If you want a perfect combination of Mac Blu-ray Ripper and a Mac MXF Video Converter,Please click iMedia Converter for Mac.which can let you easily crack complicated Blu-ray/DVD encryption, backup or rip the full Blu-Ray/DVD to hard drive with original quality and enjoy on a non HDCP monitor or TV set. It can also help you to compress/rip Blu-ray/DVD movie to any other format with smaller size. And you can freely select any chapter to convert, any subtitle language to show on the video, any audio language to hear.
What's more, Mac iMedia Converter supports converting common videos, HD videos, TV shows (*.tivo, *.dvr-ms, *.hdtv, *.tp, *.ts, *.trp), flash videos (*.flv, *.f4v), camcorder recorded videos (*.m2ts, *.mts, *.mod, *.vro, *.mvi, *.tod, etc), to MOV, M4V, AVI, MP4, MKV, MPEG, WMV, 3GP, H.264, MPG, MP3, AAC, AC3, etc to play on iPad, iPod, iPhone, iPhone 4, Nexus one, Xbox 360, HTC series, Droid X, Droid 2, HTC EVO 4G, Samsung Galaxy s ,PSP, PS3, Archos, Blackberry, etc. And its powerful editing functions, perfect audio/audio sync, fast speed, excellent quality will let you have more fun.
Sony Alpha DSLR-A580 Body Only Digital Camera Logo
can't copy old dogs, up in the air or surrogates. are there any software programs that let you try before you buy.
I use DVDFabGold, great software.
There is also DVDFabPlatinium which has more fearures.
Yes you can try before you buy. Go to this link :-
www.dvdfab.com/
Mar 21, 2010 | 321studios DVD X Copy Gold (200095) for PC
Best Mac MXF File Converter-Import/Edit Canon MXF Files to ProRes 422 MOV to FCP MXF file format comes from like Panasonic HVX200/HPX300, Canon XF300/XF305, Sony EX camera, etc. It is not compatible with many programs just like Apple Final Cut Pro. So Convert MXF file to FCP MOV Video is a necessary step to do if you want watch your video from your camcorder which export mxf file. And we know that Apple ProRes 422 , Apple ProRes 4444,introduced in Final Cut Studio, was advertised to one of the codecs to result in less compression and higher data rate/higher quality files for HD editing in Final Cut Pro. Below is the step-by-step guide for you to quickly Convert/Edit MXF to Apple ProRes 422 (*.mov) Final Cut Pro on Final Cut Studio,Final Cut Pro 7 on Mac. Step 1. Add MXF videos to Aunsoft MXF Video Converter for Mac. Connect your MXF Camcorder to iMac with USB 2.0 cable or use card reader to transfer the .mxf files to Apple hard drive disk. Run Aunsoft Video Converter for Mac as the best Mac MXF to FCP Apple ProRes Converter . and click the "Add" button to load .mxf videos. Step 2. Choose Apple ProRes codec for Final Cut Pro. Click the "Format" option, choose the Final Cut Pro > Apple ProRes 422 (*.mov) and navigate to the Final Cut Pro group, you will notice that there are profiles with Apple ProRes 422, Apple ProRes 422(HQ), Apple ProRes 422(LT), Apple ProRes 422(Proxy), Apple ProRes 4444. Here we choose Apple ProRes 422(HQ) (*.mov) as output format. (The Apple ProRes 422 (Proxy) codec is intended for offline editing and contains 30 percent of the data rate of Apple ProRes 422, and I recommend you to select Apple ProRes 422(HQ), Apple ProRes 422(LT) MOV for outputting.) Step 3. Merge Canon MXF files. (Optional) Tick the checkbox for "Merge into one file", and the Mac MXF Video Converter will join and combine the video clips into a single file as output. Step 4. Convert MXF to Apple ProRes MOV for Final Cut. Click the convert button under the preview window, the Mac MXF Video converter starts converting MXF videos to Apple ProRes MOV, and joining the MXF files for editing in Final Cut Studio. After Converting and Merging the MXF files, just import the output Apple PreRes 422 .mov files to Final Cut Pro 7 or Final Cut Pro 6 for editing and the video .Optimize your workflow and save time with the Apple ProRes compression for Final Cut Pro. You can also import the output videos to Final Cut Express (FCE) 4 for editing in full HD.
Jul 13, 2011 | Sony Alpha DSLR-A580 Body Only Digital...
2,386 people viewed this tip
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Are you a Sony Camera Expert? Answer questions, earn points and help others
