Tip & How-To about General Electric Advantium SCB1000M 975 Watts Convection / Microwave Oven
Change lightbulb in Advantium SCB1001 KSS01
I was also told that I would have to pay a technician to come out to replace the interior light bulb in my Advantium speedcook microwave, but after reading the instructions from the tip below, I was able to take care of it myself.
I ordered the parts online and , after unplugging and removing the unit from the cabinetry, I was able to follow the instructions as suggested by UNCLEMOE.
The only difference was that there were many more screws holding the cover in place. I removed all of the screws around the top and sides at the front edge of the microwave as well as the screws along the bottom of the sides and around the top and sides of the back panel. There is one additional screw that must be removed before the cover can slide back. This screw is on the right side of the microwave in a silver dollar sized indentation.
Oh, don't forget not to touch the halogen light bulb with your bare hands to avoid shortening the life of the bulb.
http://www.fixya.com/support/r650818-change_bulb_ge_microwave_jes1289sk01
It's crazy that GE should expect customers to pay a technician $100 each year to replace a simple lightbulb, but thanks to FIXYA.com I was able to do it myself in about 40 minutes with a little help to lift the unit.
as a side note, one of the screws was in so tight that the screw was stripped in an attempt to remove it. A little thing called GRABIT and a power drill took care of that problem in no time. check it out at 4GRABIT.com
General Electric Advantium SCB1000M 975 Watts Convection / Microwave Oven Logo
240V Advantium - Halogen Speedcook Not Working
If purchased "new" 6 months ago, it should still be under warranty. Call repair service....
Oct 18, 2014 | Microwave Ovens
how to change nightlight bulb on ge advantium 120 oven
Advantium - Interior Light Operation While Microwaving
The Advantium 240 oven interior (cavity) light will illuminate anytime the door is open. However, due to the dark tint on the oven door, there is not a light on while cooking since the food would not be visible using the interior lamp.
Food may be viewed during a microwave cycle by pressing the Microwave/Oven Light pad.
One of the Upper Level Speedcook lamps will come on for 5 seconds. The Microwave/Oven Light pad can be pressed up to 5 times during a microwave cooking cycle. The limit of 5 times is to prevent excessive heat on microwave cookware from the Speedcook lamp.
The Advantium 120 oven cavity is illuminated anytime the door is opened and while the unit is in the microwave only mode. As a result it will not have the Microwave/Oven Light pad.
Aug 25, 2012 | GE Microwave Ovens
2,447 people viewed this tip
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
vince
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
