Tip & How-To about Cell Phones
How to Flash/Update Firmware NOKIA MOBILE at home(Only for BB5)
First downloadand install Pheonix. NokiaPhoenix Service Software 2011 - Download secondly Download flash file fromthis link http://adf.ly/2WHa2and install it to C / programme files/pheonix..after finished thisinstallation open pheonix Inside the interface at the> left top File" click there and choose "open file" andthen select the approprait Product type i.e"which is written in theback banel inside the battery of every Nokia(Type RM-000).After doingthis again at the left top count from "File"1..2..3..the 4th one is"Flashing" press there when you click there you'll see threeicon just select the "Firmware Update" again you'll see another interface.Look at the product code there should be blank and put your"mouse tool" at the straight end from the "Product Code"there is a Botton and choose the code which is written in the back side of your phone.e.g CODE:0000000.if the same code does not found, just take one.After this you can see "Dead phone USB flashing"click that box.Now this is the last stage... Connect your phone with the USBto your PC and let the driver install ...wait for a moment.(If your phone working).Lastly after just finished (In case your phone is Dead,unable to switch on in normal mode start from here) Connect the phone to pc without powering...insert good battery and Click the "Referbish" afterthis, a message will prompt you "press power botton" press itand wait untill the phone will Restart automaticlly in normal mode 10-15minutes. If you cannot understand just leave a comment belowthanks for visiting fixya.
Cell Phones Logo
mene apna phone softwear update kar raha tha orachanak hang ho gaya or phone is swich off
OK the last thing is to flash the phone so contact mobile repairing shop or follow the procedure below
First download and install Pheonix from this link. Nokia Phoenix Service Software 2011 - Download secondly Download flash file from this link http://adf.ly/2WHa2 and install it to C / program files/pheonix.. after finished this installation open pheonix . Inside the interface at the> top left <there you see "File" click there and choose "open file" and then select the approprait Product type i.e "which is written on the back panel inside the battery of every Nokia(Type RM-000).After doing this again at the left top count from "File"1..2..3..the 4th one is "Flashing" press there, when you click there you'll see three sub-menus, just select the "Firmware Update" again you'll see another interface. Look at the product code there should be blank and put your "mouse tool" at the straight end from the "Product Code" there is a Button and choose the code which is written in the back side of your phone. e.g CODE:0000000.if the same code does not found just take one which is higher. After this you can see "Dead phone USB flashing" click that box. Now this is the last stage... Connect your phone with the USB to your PC and let the driver install ...wait for a moment.(If your phone working).Lastly after just finished (In case your phone is Dead, unable to switch on in normal mode start from here) Connect the phone to pc without powering...insert good battery and Click the "Referbish" button after this, a message will prompt you "press power botton" etc. insert charger or press it and wait until the phone will Restart automatically in normal mode 10-15 minutes. If you cannot understand just leave a Comment / Click here1. thanks for visiting fixya. Good luck.
Sep 20, 2011 | Nokia E72 Smartphone
NOT ENOUGH MEMORY
Hi its very easy just follow the procedure below.Some hidden files are blocked your phone.
First download and install Pheonix from this link. Nokia Phoenix Service Software 2011 - Download secondly Download flash file from this link http://adf.ly/2WHa2 and install it to C / program files/pheonix.. after finished this installation open pheonix . Inside the interface at the> top left File" click there and choose "open file" and then select the approprait Product type i.e "which is written on the back panel inside the battery of every Nokia(Type RM-000).After doing this again at the left top count from "File"1..2..3..the 4th one is "Flashing" press there, when you click there you'll see three sub-menus, just select the "Firmware Update" again you'll see another interface. Look at the product code there should be blank and put your "mouse tool" at the straight end from the "Product Code" there is a Button and choose the code which is written in the back side of your phone. e.g CODE:0000000.if the same code does not found just take one which is higher. After this you can see "Dead phone USB flashing" click that box. Now this is the last stage... Connect your phone with the USB to your PC and let the driver install ...wait for a moment.(If your phone working).Lastly after just finished (In case your phone is Dead, unable to switch on in normal mode start from here) Connect the phone to pc without powering...insert good battery and Click the "Referbish" button after this, a message will prompt you "press power botton" etc. insert charger or press it and wait until the phone will Restart automatically in normal mode 10-15 minutes. If you cannot understand just leave a Comment / Click here1. thanks for visiting fixya. Good luck.
Sep 06, 2011 | Nokia 7210
my nokia e63 always switch off, how can i fix it?
you can contact the service provider/.........
Sep 05, 2011 | Nokia E63 Cell Phone
i dont know how to flash my nokia 2690 i have J.A.F 1.9862 but in that i don't find RM-635 files please provide te files and procress to flash & my phone is now in dead position while updating software using nokia ovi suite due to power loss it happened pls give solution
First downloadand install Pheonix. NokiaPhoenix Service Software 2011 -Download secondly Download flash file fromthis link Nokiaflash fileand install it to C / programmefiles/pheonix..after finished thisinstallation open pheonix Inside theinterface at the> left top File" click there and choose "openfile" andthen select the approprait Product type i.e"whichis written in theback banel inside the battery of every Nokia(Type RM-000).Afterdoingthis again at the left top count from "File"1..2..3..the 4th oneis"Flashing" press there when you click there you'll seethreeicon just select the "Firmware Update" again you'll seeanother interface.Look at the product code there should be blank and putyour"mouse tool" at the straight end from the "Product Code"thereis a Botton and choose the code which is written in the back sideof your phone.e.g CODE:0000000.if the same code does not found, justtake one.After this you can see "Dead phone USB flashing"clickthat box.Now this is the last stage... Connect your phone with the USBtoyour PC and let the driver install ...wait for a moment.(If yourphone working).Lastly after just finished (In case your phone isDead,unable to switch on in normal mode start from here) Connect thephone to pc without powering...insert good battery and Click the "Referbish"afterthis, a message will prompt you "press power botton"press itand wait untill the phone will Restart automatically. goodluck
Sep 03, 2011 | Nokia 2690 Cell Phone
21,295 people viewed this tip
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
