Tip & How-To about Plumbing
Is your shower head too high? Is your shower head too low?
Hello. There are few things in life that feel as good as a great shower. Morning, noon or night....there is nothing like a perfect shower to put a smile on your face!! Is your perfect shower a dream because your shower head is way too tall... or way too low???
If so, did you think about calling a plumber but you didn't want to have to auction off your first born!!! Well I have some great news for you. A fix is just around the corner, you can do it yourself and it will only take a few minutes. You don't even have to shut off the water supply. Here is how:
This is the 11" "S" shower arm by Danco available at most hardware stores, Home Depot, Lowes, etc. All you do is unscrew the old shower arm, put teflon tape on the threads of this new arm and install it. Five minutes tops!
Enjoy your new and improved shower!!
Plumbing Logo
Compressor needs few jumps to start when is expose to the sun at noon. Work perfect at night and morning because the shade of the house. Booster was install and new 7/8 and 3/4 cooper lanes to the coil but problem still.
The capacitor is bad and the motor will not start against the higher head pressure from the heat... replace the cap. and it should work...
Here is a tip about troubleshooting your air conditioner...
There are many things that can cause your air conditioner not to cool...
Air Conditioner Trouble - Review the Possibilities
heatman101
Sep 26, 2010 | Haier HC48C1VAR Central Air Conditioner
Garmin 305 wont power on, wont charge on cradle
Same thing happened to mine. Put the unit in the cradle (just like you are going to recharge it) and press the reset and mode button at the same time for 3 seconds. This will "wake" the unit up.
Mar 30, 2009 | Garmin Forerunner 305 GPS Receiver
I can't change from night service to normal service
Are the keys not working? These phones have a common problem with the keypad locking up. If so, the keyboard membrane would need to be replaced. Temperature and humidity effects this problem greatly. You could try putting the phone in a freezer for a few hours to see if you can temporarily get the buttons working to put your system back into day mode. You will still need to get the phone repaired.
Feb 25, 2008 | Lucent Merlin Legend MLX-20L Phone
1,539 people viewed this tip
Top Plumbing Experts
Donni Steen
Tom Chichester
Are you a Plumbing Expert? Answer questions, earn points and help others
