Tip & How-To about Cell Phones
* How to deal with WLAN (WiFi) *
Setting 1:- Go to Menu > Settings > Connectitvity > WLAN > Internet connection > Ask first
- Goto Menu > Settings > Configuration > Default config. settings > myGlobe (or Smart)
- Goto Menu > Settings > Configuration > Preffered access point > myGlobe Internet (or Smart Internet)
- Goto Menu > Internet > Web settings > Configuration settings > Configuration > myGlobe Internet (or Smart Internet)
- Goto Menu > Internet > Web settings > Configuration settings > Account > myGlobe Internet (or Smart Internet)
- Select your preferred scanned network, then Connect.
- You will notice a WiFi signal logo ..oo)))) on the top screen indicating you're connected.
- Go to MENU > Internet > Go to address (and enter the website you want)
- Done. Enjoy browsing via WiFi.
Setting 2:- Go to Menu > Settings > Configuration > Personal Settings > Add > Access point (leave others as is) > press back > Option > Activate- Goto Menu > Settings > Configuration > Preferred access point > My access point- Go to Menu > Settings > Connectitvity > WLAN > Internet connection > Ask first
- Go to Menu > Settings > Connectitvity > WLAN > Available WLANs
- Select your preffered connection, then connect.
Note:- Update your phone to the latest firmware, preferrably version 7.20 or higher. Firmware upgrade might solve Web browser bugs and WiFi issues.
- Check your WLAN server, you might have a weak WiFi signal.
Please check your phone sw version from this link and update if necessary.
Please do not forget to back up your phone before you update.
http://europe.nokia.com/support/download-software/device-software-update/can-i-update
The latest sw is 4.60 depending on the sales areas and variant.
Please also become familiar with the FAQs :
http://europe.nokia.com/support/search?comp=Nokia+C3-00&qt=wlan
How do I manage WLAN internet access points on my Nokia C3-00 device?
How can i use always WLAN connection on my Nokia C3-00 phone for Internet instead of GPRS?
I hope this helps.
First of all you delete all current settings, these are for 02 and will not work on giffgaff. To delete settings: Now that you have done that you need to set up the giffgaff settings, I recommend using this method to do it: Now that you've done this set up the packet data settings: Okay so finally for wifi settings: Now you have giffgaff internet and wifi set up on your Nokia C3-00! For any issues you can message me, I will be willing to help! Update: You may be experiencing problems with using wifi with the browser or any other application, do this to fix it: "I had the exact same problem. What I did was that I removed all network Internet settings, GPRS, WAP, etc. because I do not want to use them which is when I lost the ability to select which AP to use. So what I did was I created a personal setting: Settings > Configuration > Personal settings > Add > Web Then go to the main menu > Internet > Web settings > Configuration Settings > Select the personal settings that you created Now try to access the internet and it will ask you to choose, choose Wi-fi Then go back to the personal settings and delete the setting that you created. From now on, you will be asked which connection to use everytime you access the internet If you want to restore your GPRS settings, you can just request it from your network provider and they will send it to your phone." Source http://discussions.nokia.co.uk/t5/Cseries/ANOTHER-NOKIA-C3-WLAN-PROBLEM/td-p/754515
