Tip & How-To about Sony Alpha DSLR-A580 Body Only Digital Camera
Convert Canon MXF files to ProRes 422 for Final Cut Pro X Editing and QuickTime Playback
Canon XF Plugin not work for FCP X-MXF files Import to FCP X for Convert MXF to ProRes
Best Canon XF video converter on Mac-Canon XF100 to ProRes for FCP X
I have a Canon XF100 and would like to get the videos to FCP X. However, there is no Log and Transfer option, and the iSight runs when I click the camcorder button on FCP X. I googled and noticed that there is Canon XF plugin for FCP 7, but Canon XF plugin not work for FCP X yet.
As Canon XF Plugin does not work for FCP X, I have to look for the workaround for editing Canon MXF files on Mac. I find Aunsoft Video Converter for Mac as a great tool to make the videos compatible to Final Cut X. It would Convert Canon .mxf files to ProRes 422 and ProRes 422 (HQ), so that I can import into Final Cut X, export ProRes 422 at the same settings as the original and play it with QuickTime.
Below is the simple step-by-step guide to convert Canon MXF files to ProRes 422 for Final Cut X editing and QuickTime playback.
First, download Canon XF100 videos to Mac with Canon XF Utility. You will get the folder with files like .CIF, .THM, .MXF and .SIF.
Second, import .MXF files to Aunsoft Video Converter for Mac. Just run it as best Canon XF video converter on Mac, then click the Add button to import .mxf files or drag and drop the files to the application UI.
Third, choose Apple ProRes with 1920x1080 output. Click the format option to choose Final Cut Pro > Apple ProRes 422(*.mov) as output format. Click the Settings button to choose 1920x1080 as video size.
Fourth, click the convert button under the preview window to start converting Canon XF100 files to ProRes for FCP X.
Soon after the conversion is done, you can import the ProRes files to Final Cut X and enjoy HD video editing and playback.
Tips:
If you are using iMovie, Final Cut Express, just choose Apple Intermedia Codec as output format for HD video editing.
Sony Alpha DSLR-A580 Body Only Digital Camera Logo
Best Mac MXF File Converter-Import/Edit Canon MXF Files to ProRes 422 MOV to FCP MXF file format comes from like Panasonic HVX200/HPX300, Canon XF300/XF305, Sony EX camera, etc. It is not compatible with many programs just like Apple Final Cut Pro. So Convert MXF file to FCP MOV Video is a necessary step to do if you want watch your video from your camcorder which export mxf file. And we know that Apple ProRes 422 , Apple ProRes 4444,introduced in Final Cut Studio, was advertised to one of the codecs to result in less compression and higher data rate/higher quality files for HD editing in Final Cut Pro. Below is the step-by-step guide for you to quickly Convert/Edit MXF to Apple ProRes 422 (*.mov) Final Cut Pro on Final Cut Studio,Final Cut Pro 7 on Mac. Step 1. Add MXF videos to Aunsoft MXF Video Converter for Mac. Connect your MXF Camcorder to iMac with USB 2.0 cable or use card reader to transfer the .mxf files to Apple hard drive disk. Run Aunsoft Video Converter for Mac as the best Mac MXF to FCP Apple ProRes Converter . and click the "Add" button to load .mxf videos. Step 2. Choose Apple ProRes codec for Final Cut Pro. Click the "Format" option, choose the Final Cut Pro > Apple ProRes 422 (*.mov) and navigate to the Final Cut Pro group, you will notice that there are profiles with Apple ProRes 422, Apple ProRes 422(HQ), Apple ProRes 422(LT), Apple ProRes 422(Proxy), Apple ProRes 4444. Here we choose Apple ProRes 422(HQ) (*.mov) as output format. (The Apple ProRes 422 (Proxy) codec is intended for offline editing and contains 30 percent of the data rate of Apple ProRes 422, and I recommend you to select Apple ProRes 422(HQ), Apple ProRes 422(LT) MOV for outputting.) Step 3. Merge Canon MXF files. (Optional) Tick the checkbox for "Merge into one file", and the Mac MXF Video Converter will join and combine the video clips into a single file as output. Step 4. Convert MXF to Apple ProRes MOV for Final Cut. Click the convert button under the preview window, the Mac MXF Video converter starts converting MXF videos to Apple ProRes MOV, and joining the MXF files for editing in Final Cut Studio. After Converting and Merging the MXF files, just import the output Apple PreRes 422 .mov files to Final Cut Pro 7 or Final Cut Pro 6 for editing and the video .Optimize your workflow and save time with the Apple ProRes compression for Final Cut Pro. You can also import the output videos to Final Cut Express (FCE) 4 for editing in full HD.
Jul 13, 2011 | Sony Alpha DSLR-A580 Body Only Digital...
1,753 people viewed this tip
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Are you a Sony Camera Expert? Answer questions, earn points and help others
