Tip & How-To about Cell Phones
Motorola Secret Codes
Motorola L6:
hold * 65512890 for reset
hold * 5806 sw version
hold * 487989 NS lock menu
hold * 482896 CP
hold * 574243 NS
hold * 967678 SP
hold * 362628 IMSI
hold * 787090 Lock net level
hold * 787292 Lock net level
Reset L7 security code without any cable
press menu button enter 6 time 0 and then press ok
*#06# IMEI
in permament test mode
(* hold 2 sec)
***113*1*[OK] net monitor
T205/T19x (ACER)
*#300# OK List the Software and Hardware version
*#301# OK Full Keypads functional Test
*#303# OK Set Default Language to English
*#304# OK Set OFF engineering mode
#304*19980722# OK Set ON engineering mode
*#305# OK Location: 1 OK
*#307# OK Engineering Test Mode
*#311# OK Phone code changed to default code
*#400# OK ADC, Cal val*
*#402# OK Adjust Display Intensity / Contrast
*#403# OK List the Manufacturing Informations
19980722 OK Master Unlock code for Phone and Sim Lock
*#302# OK Acoustic test*
7.1 Greeting
7.2 Main VlmGain
7.3 Input Cal
7.4 Output Cal
7.5 Side In Gain
7.6 Vox Gain
7.7 Min Mic Engy
7.8 More
(a) In Vlm Gain
(b) Aux Vlm Gain
(c) Silence Prd
(d) Supp Prd
(e) In Volume
(f) Out Volume
(g) Icon
(h) Image
(i) Animation
*3370# EFR ON (enhanced full rate)
#3370# ERF OFF
*#72837726# OK Confirm ?, Data saver
1234 OK Phone code default
*#0000# OK Setting saved, restore set phone do default language
*#0048# OK Fast change polish langpack
*#0007# OK Fast change russian langpack
MOTOROLA 3xx
*#06# and quick 'menu-key' and 048263* (Push the key quickly!)
and entering at field "OPTCODE" you must try several times.
If not working try with MOTO TEST CARD inserted.
Security code - 32*118*1*0*0
Model - 32*279*1*0*8
Flex ver - 32*383*1*0*0
Master Reset - 18*0
Master Clear - 18*1
Set band GSM 900 - 10*0*3
Set band DCS 1800 - 10*0*4
Set band PCS 1900 - 10*0*5
Set dual band GSM 900/1800 - 10*0*6
Read band - 10*1*0 => 3-GSM, 4-DCS, 5-PCS, 6-GSM/DCS
User code - 32*116*1*0*0 /coded:00310032003300340000 - 1234/
Read imei - 32*4*1*0*0 "OK" /coded:083a05092700247709 - 350907200427799/
47*4*1*0*9*081A32547698103254 => IMEI=123456789012345
it is possible to change IMEI
ENJOY
Cell Phones Logo
i want l6 reset code
hi,
Go To Settings -> Initial Setup -> Master Reset-> Code is 000000
esle try 1234
thank you for using fixya have a nice day:-)
Jul 24, 2010 | Motorola Mobility L6 Cellular Phone
MOTOROLA CODES
how should i use tihs code wat do u mean by hold * and code , pls help me
Feb 09, 2008 | Motorola Mobility L6 Cellular Phone
i have motorola l6 phone i want to restore it but its unlock code
Manually reset for L6 Phone
hold * 482896 CP
hold * 574243 NS
hold * 967678 SP
hold * 362628 IMSI
here my little trick!
default code is 1234
press menu until the line show 6 digits and enter 000000
done!
Apr 07, 2009 | Motorola Mobility L6 Cellular Phone
Unlocking Key Pad
Motorola L6:
hold * 482896 CP
hold * 574243 NS
hold * 967678 SP
hold * 362628 IMSI
to unlock the keypad press menu then *
Oct 08, 2007 | Motorola Mobility L6 Cellular Phone
1,100 people viewed this tip
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
