Tip & How-To about Computers & Internet
How To Connect to home computer from Another Location
Using the Remote Desktop feature, you can connect your home computer (host) from any other remote computer (client) and can access all computer resources (installed programs, data and any network resources). You can run any computer application on the remote computer as if you were actually sitting in front of your home computer.
Follow the given steps to configure your computer to connect with remote computers:
To use this feature, you will need to be logged into your computer with administrative rights. Make sure both computers are connected to the internet.
First you have to configure the host computer to allow users to connect to it remotely. On the host computer, right click on "My computer" and click on Properties option.
Under the Remote tab, select the option "Allow users to connect remotely to this computer" and click Ok button.
Now get the IP address of host computer (type the "ipconfig /all" on the command prompt of host computer to find IP address).Start--Run--type "CMD" then hit enter for command prompt.
Now make a connection on remote or client computer, click on Start button, go to All Programs> Accessories, and Communications, then click on Remote Desktop Connection, option. A Remote Desktop Connection, dialog box will appear.
Click on Options button for detail configuration, under the General tab, type the IP address of host computer in the Computer box and also type username and password of host computer then click on Connect button to make a connection to remote computer. If your username and password is correct then a remote desktop windows will appear.
Computers & Internet Logo
Is there any software by which i can work on my computer when i am away from my home ?
Hello,you can work with your pc even away from it without a software.. In Windows, Remote Desktop allows you to access your computer from a remote location. To enable Remote Desktop, you must have administrative rights on the computer you want to use as the host (i.e., the computer to which you will connect from a remote location), which must be running one of the following versions of Windows: Windows 7 Professional, Enterprise, or Ultimate Windows Vista Business, Enterprise, or Ultimate Windows XP Professional The Remote Desktop Connection client software (for the computer from which you want to connect) is installed by default on all computers running Windows 7, Vista, or XP. Enable the Remote Desktop feature on your host computer From the Start menu, select Control Panel (or Settings, and then Control Panel). Double-click System. In Windows 7 and Vista, click Remote settings. In the "Remote Desktop" section, select one of the two options to allow connections from other computers. In Windows XP, select the Remote tab. Select Allow users to connect remotely to this computer. To choose which users will have remote access, in 7 and Vista, click Select Users... or in XP, click Select Remote Users... . Typically, all administrators of the computer will have access by default. Each user must have a password before you can allow remote access. When you are finished, click OK. Your computer will now be able to accept incoming Remote Desktop connections. Open a connection If you have configured your computer to accept remote connections, to establish a Remote Desktop connection: Depending upon your network configuration and system requirements, you may first have to establish a VPN connection to your host computer's network. From the Start menu, select Programs or All Programs. Select Accessories, and then Remote Desktop Connection. In the space next to "Computer:", type the name or IP address for your host computer. Click Connect. Note: If you would like to adjust any of your connection settings such as screen size, login information, availability of local hard drives and printers, or keyboard and sound behavior, click Options before clicking Connect. In the Log On to Windows dialog box, type your username, password, and domain (if required). Click OK. Once you are connected, you can use your remote computer as if you were sitting in front of it. When you are finished, in the Remote Desktop Connection window, select Start, then Shut Down. In the Shut Down Windows dialog box, from the drop-down menu, select Log Off username, where username is your username on the remote computer. Click OK. goodluck!don't forget to rate,thanks'''''****
Feb 21, 2011 | ViewSonic VG2230WM LCD Monitor
Port Forwarding On Linksys RV016
it's a rather lenghty explanation so please go to this site and follow the instructions...
http://portforward.com/english/routers/port_forwarding/Linksys/WRT54G/
Robert
Please rate this solution ... thanks
Sep 08, 2008 | Linksys RV016 Router
418 people viewed this tip
David Payne
David Payne
