Tip & How-To about Computers & Internet
How to Backup registry
Make sure before modifying your system Registry that you back it up. The Registry contains all information about how your system runs. This backup will help you to restore the Registry in case any problem occurs after modifying.
You can backup the whole Registry and\or Registry subkeys.
Click Start type regedit in Run box and click Ok.
Here you can export the whole Registry or you can locate the required subkeys that contain the information that you want to edit.
Go to File--menu-- option then click on Export to create backup. Save it on any system drive with the .reg extension. You can restore this backup by going to File-- menu and using import option.
Computers & Internet Logo
error 28000 cisco vpn win xp
I suggest that you follow the below article that will give you information on How to Uninstall Manually and Upgrade the Cisco VPN Client that I found on the Cisco Support website: http://www.cisco.com/en/US/products/sw/secursw/ps2308/products_tech_note09186a0080094b7f.shtml Important: This section, method, or task contains steps that tell you how to modify the registry. However, serious problems might occur if you modify the registry incorrectly. Therefore, make sure that you follow these steps carefully. For added protection, back up the registry before you modify it. Then, you can restore the registry if a problem occurs. For more information about how to back up annd restore the registry, click the following article number to view the article in the Microsoft Knowledge Base: 322756 (http://support.microsoft.com/kb/322756 ) How to back up and restore the registry in Windows Thanks, Irfan H, Microsoft Answers Support Engineer
Aug 06, 2012 | Cisco Computers & Internet
problem of error c0000005 to access the tally9.exe
Hi Arvind,
This issue is caused by the DelFin Media Viewer.
Resolution as follows;
Important This section, method, or task contains steps that tell you how to modify the registry. However, serious problems might occur if you modify the registry incorrectly. Therefore, make sure that you follow these steps carefully. For added protection, back up the registry before you modify it. Then, you can restore the registry if a problem occurs. For more information about how to back up and restore the registry, click the following article number to view the article in the Microsoft Knowledge Base: 322756 (http://support.microsoft.com/kb/322756/ ) How to back up and restore the registry in Windows(Do not miss on this)
To resolve this issue, follow these steps:
  1. Remove DelFin Media Viewer from your computer according to the DelFin Media Viewer's manufacturer's instructions. For help with removing DelFin Media Viewer, contact the manufacturer, the DelFin Project, Inc. To do this, visit the following DelFin Web site: http://www.delfinproject.com (http://www.delfinproject.com)
  2. Click Start, click Run, type regedit, and then click OK.
  3. Locate the Run registry key in the following location: HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion
  4. Delete the Pgmonitr.exe string value. It may also be listed as Del Fin Media Viewer in the Run list.
  5. Quit Registry Editor.
  6. Restart your computer.
Dec 23, 2010 | Computers & Internet
my windows installer will not allow me to to install or uninstall certain thing and says that windows installer service could not be accessed .... plz help
  1. Log on to your computer as an administrator.
  2. Click Start, and then click Run.
  3. In the Open box, type cmd, and then click OK.
  4. At the command prompt, typemsiexec.exe /unregister, and then press ENTER.
  5. Type msiexec /regserver, and then press ENTER.
  6. Verify that the SYSTEM account has full control access permissions to the HKEY_CLASSES_ROOT hive in the Windows registry. In some cases, you may also have to add Administrator accounts. To do so:Important This section, method, or task contains steps that tell you how to modify the registry. However, serious problems might occur if you modify the registry incorrectly. Therefore, make sure that you follow these steps carefully. For added protection, back up the registry before you modify it. Then, you can restore the registry if a problem occurs. For more information about how to back up and restore the registry, click the following article number to view the article in the Microsoft Knowledge Base: 322756 (http://support.microsoft.com/kb/322756/ ) How to back up and restore the registry in Windows
    1. Click Start, click Run, type regedit in the Open box, and then click OK.
    2. Click the following registry hive: HKEY_CLASSES_ROOT
    3. On the Edit menu, click Permissions.
    4. If SYSTEM is not listed in the Group or user names list, click Add, make sure that the local computer name appears in the From this location box, type system in the Enter the object names to select box, click Check Names, and then click OK.
    5. Click SYSTEM in the Group or user names list, and then select the Full Control check box under Allow in the Permissions for SYSTEM box.
    6. Click Apply, click OK, and then quit Registry Editor.
  7. Restart the computer. If the problem is not resolved, repair Windows XP
Nov 20, 2008 | Computers & Internet
299 people viewed this tip
David Payne
David Payne
