Tip & How-To about Computers & Internet
Disable Startup programs to increase system speed
One of the great things about our operating systems today is the automated processes that take place in the background. These processes make many programs run faster and make them easier to use. However, this feature can also use resources on programs that you may never use. Some programs use auto updates or even schedulers to regularly check for updates, is this necessary? Not really. I often suggest to people to remove unwanted or unused processes from startup. This can be more difficult than it sounds as there are often many items in the startup that are unknown to most users. I now have a solution to this problem. You can go to http://www.sysinfo.org/startuplist.php this is the largest and most in-depth list of startup items I have ever seen. At first the list will seem very intimidating it is very large. However, once you get started it goes quickly. You can search alphabetically on the site so don't panic. If you run across an entry that is not listed try google and do a search for it. Follow the instructions below to view and disable startup processes. Although it can be time consuming I suggest you check every one of your startup entries and verify if they are in fact necessary. The speed increase is worth the time spent and you may even find hidden malware or viruses you didn't know were there.
Click-Start
In run line or search box (depending on OS) type "msconfig" hit enter.
Microsoft's System Configuration Utility should open.
Select Startup tab
Here you will be able to view and disable\enable startup items. After verifying all startup items you will need to reboot for the changes to take affect. When windows reloads you will get a message that will tell you the startup configuration has been changed and how to change it back. Select the check box in lower left corner "Do not show this message again" to make this go away. If at anytime after you have made changes you have problems with an application simply go back to "Msconfig" and enable the applications startup process. Following these instructions could significantly speed up your system.
Computers & Internet Logo
What is ERP software?
ERP software companies in India provide ERP as a business-management software which is used for all integrated applications such as collection, storage, management and interpretation of data from various business activities. ERP Software Companies In India ERP Implementation ERP Vendors ABSL
Apr 29, 2016 | Computers & Internet
have a bo code heater keeps cycling on and off
BO code is bypass operation. It means that it is set to operate with an external controller. Things like Aqualink, Aqualogic, Intellitouch, EZ-Touch are all types of automation / external controllers. They have their own temperature sensor and allow remote control operation. To truly find the nature of your issue. I'd start by taking it out of bypass operation and see if the unit fires by itself ( without automation hooked up to it ). The fault may lie with the automation system. You never know.
May 24, 2014 | Hayward H-series Electronic Gas Pool...
whenever i turn it on it stays for 5minutes then swiych itself off
You obviously have a lot of processes running in the background. Here is a link for the minimum processes you need for win xp:
http://billmullins.wordpress.com/2009/04/18/the-bare-minimum-processes-needed-to-run-windows-xp/
To see how many processes you have running do this:
1. Place your mouse on the task bar and right click
2. Pick task manager
3. you will see a tab that says processes. Look at the bottom of the page on the left side. It will say Processes : #. Anything over the above links # 10, are programs running in the background that you do not need to have running all the time.
When you install ANY program to your computer, be sure to read every page that comes up when installing. If there is an option/check mark that says something like: "start at windows start up" or "run when windows starts", uncheck it. You do not need to have anything but the operating system files load up when your computer starts. Whatever you download will still be there, it just wont be in the background running taking up memory and resources. When ever you need whatever you downloaded, just go to that program and open it.
With the exception of your virus protection, you should keep these processes as low as possible.
TO CLOSE PROCESSES YOU DON'T NEED;
1. On the processes tab as stated above, right click on the processes you don't need, then hit "end process". You should see the number at the bottom go down. Don:t worry, if it is an operating system file that you should not end, it will not let you.
Next time you start your computer, these will all come back UNLESS, you find out what each process goes to, go to that program and find where the option to start at windows start up is and uncheck it.
This should shut down your computer a lot faster and run faster too. Good luck
Mar 14, 2011 | Computers & Internet
Programes running in background
Press Ctrl, Alt and Del and click on the processes tab, this will show you what processes are running in your computer at the time.
If you want to stop certain processes from starting up with the computer then in the run box type msconfig, this will bring up the system configuration utility, click on the startup tab and you will see what starts up with the computer, in that tab you can disable or enable processes.
Be careful what you are doing as you can mess certain settings up if disable the wrong process.
Regards.
Jul 16, 2009 | IBM Computers & Internet
873 people viewed this tip
David Payne
David Payne
