Tip & How-To about Magic Chef CYG3005AWW Gas Dryer
Magic chef manual CYG3005AWW
Do we need to light the pilot light? Where is it? Thanks!
Magic Chef CYG3005AWW Gas Dryer Logo
procom pilot light wont light
Make sure the gas valve is on. The thermocouple may need to be cleaned in order for the pilot to stay lit.
Nov 26, 2013 | Procom Heating & Cooling
Need to adjust pilot light could you explain how? Thanks
Hi there.
Pilot light on Millivolt Gas Valve can be adjusted by removing the screw (with pilot adj mark) just below the gas valve knob and tightening (to increase pilot flame) or loosening (to decrease pilot flame) the screw inside. However, make sure that the gas pressure is sufficient and the pilot assembly is clean before doing this.
Regards.
Jul 21, 2011 | Pitco Frialator 35CS Deep Fryer
I have a Frigidaire gas range, model #FGF316BSA. When I attempt to operate the oven it won't light. The glow bar comes on but nothing happens after that.
Hi
Thanks for using FixYa. From what you have described it seems that possible oven control is not sending gas for the pilot light. The pilot light works but no main burner ignition - possible pilot assembly is dirty and the pilot flame is too small, safety valve and thermocouple is faulty, the bulb from the safety valve is out of position and the pilot flame is not touching the thermocouple bulb. Some ranges use a standing pilot light ( small flame is on all the time ) while others use an spark ignition to light the pilot light flame and the pilot light flame heats up the thermocouple bulb to allow the main gas to flow through the oven burner.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Jan 15, 2010 | Kitchen Ranges
Need to turn on pilot light of Williams 3003622 serial # 400518D
Find the gas valve and turn it to pilot. (Or light) Use a long reach lighter. Light the lighter and press the knob in. Light the pilot and continue to hold the knob in for about 15 seconds. When you release it, the pilot should stay lit. If it doesn't, you need a new thermocouple. That's the small tube that the flame touches when the pilot's lit. They're inexpensive and usually not too hard to replace.
Jan 30, 2009 | Williams 3003622 Ceramic Wall Mounted...
Where is the pilot light located
your unit dioes not have a pillot that would need need relighting, it instead uses a glow bar ignitor. auto pilot.
Dec 15, 2008 | Frigidaire FGB24L2A Gas Single Oven
1,003 people viewed this tip
Top Magic Chef Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Charles T Nevin
Charles T Nevin
Are you a Magic Chef Dryer Expert? Answer questions, earn points and help others
