Tip & How-To about Cell Phones
Nokia codes and tricks
Most Popular and Useful Nokia Codes How its done: Go to standby mode (the state where your wallpaper, clock, and operator logo are displayed at the same time - press the red button on your keypad),then press the secret code. Example: if you press Quote: *(asterisk) #(number sign) 0(zero) 6(six)#(number sign) it will show you your phone's IMEI/serial number. The CODES: *#06# - displays the unique serial number or IMEI number *#0000# - shows the firmware or software version details *#2820# - Bluetooth (BT) device address press and hold the ZERO (0) button - brings you to the homepage of your wap/gprs press and hold the MENU button - launch thephone's task manager. you can then switch between active programs or terminate a running application by press the CANCEL/DELETE (c) button. *#7780# - restores user defined settings to factory default settings. programs, calendars, and contacts are unchanged. you will be ask to input your security or lock code to proceed with the restoration. *#7370# - reprograms your phone memoryto factory default. all files will be deleted. you will be ask to input your security or lockcode to proceed with the phone memory format. backup your messages, contacts, and other important data before proceeding. NOTE: this is equivalent to hard format for Nokia Series 60 1st edition phones (N7650, N3650/60, N-Gage/QD). If you are using Nokia Series 60 2nd and 3rd edition phone (N6600 and above), this code will not fully format your phone memory, you need to do the hard format (3-keys combo code) instead. turn ON your phone while holding together the green (call) button, *, 3 - reprograms your phone memory to factory default. all files will be deleted. you will be ask to input your security or lock code to proceed with the phone memory format. backup your messages, contacts, and other important data before proceeding. NOTE: applicable only to Nokia Series 60 2nd edition and above phones (N6600 and up). *#7370925538# - reprograms your phone's wallet application. all information on your wallet will be erased and the wallet code will be removed.
Cell Phones Logo
i need master code for nokia 3310 but i don't have imei number
Nokia 3310 Secret codes *#06# To find IMEI
*#7780# Restores Factory Settings..(Memory, language, counters not included)
*#3110# For checking the software (SW) - called firmware revision information.
*#746025625# [*#sim0clock#] To check if the Sim-Clock can be Stopped (Sim-clock-stop is a kind of standby mode which will save battery time)
*#92702689# [*#war0anty#] Phone asks 'warranty code:'
6232 (OK) Displays the Month and Year of Manufacture
9268 (OK) Displays Serial Number
7332 (OK) Displays the date of the last repairment - if found
7832 (OK) Displays (if found) the date where the phone was purchased
37832 (OK) Set the Purchasing Date MMYY (This date can be set only once!)
87267 (OK) Transfers ALL phone numbers, Logo's, and ringtones from other gsm phones
Posted by bulletproof
May 01, 2011 | Nokia Lands Phones
locked out
The setup Security Code can be done when the
<Demonstration mode Setting> (page 50) is set as OFF.
• When the Security Code function is activated, the code
can’t be changed and the function can’t be released.
Note, the Security Code can be set as the 4 digit number
of your choice.
1 Enter Standby
Press the [SRC] button.
Select the "STANDBY" display.
2 Enter Menu mode
Press the [MENU] button for at least 1 second.
When "Menu" is displayed, "Security" is displayed.
3 Enter Security Code mode
Press the Control knob for at least 1 second.
When "Enter" is displayed, "Security" is displayed.
4 Select the digits to enter
Push the Control knob to [4] or [¢].
5 Select the Security Code numbers
Push the Control knob to [FM] or [AM].
6 Repeat steps 4 and 5, and complete the
Security Code.
7 Confirm the Security Code
Press the Control knob for at least 3 seconds.
When "Re-Enter" is displayed, "Security" is
displayed.
8 Do the step 4 through 7 operation, and
reenter the Security Code.
"Approved" is displayed.
The Security Code function activates.
• When the wrong Code is entered in steps 4 through 6,
repeat from step 4.
Press the Reset button and when it’s removed
from the battery power source
1 Turn the power ON.
2 Do the step 4 through 7 operation, and enter
the Security Code.
The unit can be used.
In Standby mode
Touch Sensor Tone
Setting the operation check sound (beep sound)
ON/OFF.
Display Setting
"Beep : ON" Beep is heard.
"Beep : OFF" Beep canceled.
In Standby mode
Manual Clock Adjustment
• This adjustment can be done when the <Synchronize
Clock> (page 43) is set as OFF.
1 Select Clock Adjustment mode
Select the "Clock Adjust" display.
2 Enter Clock Adjust mode
The clock display blinks.
3 Adjust the hours
Adjust the minutes
4 Exit Clock adjustment mode
Press the [MENU] button.
The Whole manual is here.
http://www.kenwood.net-disp.com/i/05products/kdc_x789/pdf/kdc_x889_x789_mp828_k_english.pdf
Dec 06, 2007 | Kenwood KDC-MP628 CD Player
nokia 2626 formate code . i want to all nokia formate code. avinash
HEY BROTHER THERE IS YOUR CODE.
*#7780#
AND SECURITY CODE IS 12345
*#06#
To check the IMEI.
*#0000#
To check the firmware version and date
*#92702689# *#war0anty#
To check the IMEI. The date when it was purchased
and the date when it was repaired.
*4720# (*hra0#)
To activates the Half Rate.
#4720# (#hra0#)
To deactivates Half Rate.
*#3370# (*efr0#)
To activates Enhanced Full Rate.
*#746085685# (*#sim0clock#)
To check the SIM clock status.
*#7220# (*#pca0#)
To activate the GPRS and Packet Common Control
Channel(PCCCH) supports.
*#7230# (*#pcd0#)
To deactivate the GPRS and Packet common control
channel (PCCCH)supports.
*#7760# (*#ssn0#)
To check the manufacturing serial number.
*#2820# (*#bta0#)
To check the Bluetooth MAC address
(Phone must have a built in bluetooth adapter).
*#7370925538# (*#res0wallet#)
Reset the mobile wallet.
NOKIA PHONE CODES :
Nokia Codes : *3370#
This Nokia code activates Enhanced Full Rate Codec (EFR) - Your Nokia cell phone uses the best sound quality but talk time is reduced my approx. 5%
Nokia Codes : #3370#
Deactivate Enhanced Full Rate Codec (EFR)
Nokia Codes : *#4720#
Activate Half Rate Codec - Your phone uses a lower quality sound but you should gain approx 30% more Talk Time
With this Nokia code you can deactivate the Half Rate Codec
Nokia Codes : *#0000#
Displays your phones software version, 1st Line : Software Version, 2nd Line : Software Release Date, 3rd Line : Compression Type
Nokia Codes : *#9999#
Phones software version if *#0000# does not work
Nokia Codes : *#06#
For
checking the International Mobile Equipment Identity (IMEI Number)
Nokia Codes : #pw+1234567890+1#
Provider Lock Status. (use the "*" button to obtain the "p,w" and "+" symbols)
Nokia Codes : #pw+1234567890+2#
Network Lock Status. (use the "*" button to obtain the "p,w" and "+" symbols)
Nokia Codes : #pw+1234567890+3#
Country Lock Status. (use the "*" button to obtain the "p,w" and "+" symbols)
Nokia Codes : #pw+1234567890+4#
SIM Card Lock Status. (use the "*" button to obtain the "p,w" and "+" symbols)
Nokia Codes : *#147#
This lets you know who called you last (Only vodofone)
Nokia Codes : *#1471#
Last call (Only vodofone)
Nokia Codes : *#21#
This phone code allows you to check the number that "All Calls" are diverted to
Nokia Codes : *#2640#
Displays phone security code in use
Nokia Codes : *#30#
Lets you see the private number
Nokia Codes : *#43#
Allows you to check the "Call Waiting" status of your cell phone.
Nokia Codes : *#61#
Allows you to check the number that "On No Reply" calls are diverted to
Nokia Codes : *#62#
Allows you to check the number that "Divert If Unreachable (no service)" calls are diverted to
Nokia Codes : *#67#
Allows you to check the number that "On Busy Calls" are diverted to
Nokia Codes : *#67705646#
Phone code that removes operator logo on 3310 & 3330
Nokia Codes : *#73#
Reset phone timers and game scores
Nokia Codes : *#746025625#
Displays the SIM Clock status, if your phone supports this power saving feature "SIM Clock Stop Allowed", it means you will get the best standby time possible
Nokia Codes : *#7760#
Manufactures code
Nokia Codes : *#7780#
Restore factory settings
Nokia Codes : *#8110#
Software version for the nokia 8110
Nokia Codes : *#92702689#
Displays - 1.Serial Number, 2.Date Made, 3.Purchase Date, 4.Date of last repair (0000 for no repairs), 5.Transfer User Data. To exit this mode you need to switch your phone off then on again
Nokia Codes : *#94870345123456789#
IDRISH 911
Oct 22, 2010 | Nokia 2626 Mobile Phone
unlock codes of nokia 2610
Once you get the unlocking code you get the unlocking instructions from http://www.mobileunlockguide.com/ .It's useful for you.
Aug 28, 2009 | Lands Phones
Wallpaper
GO TO SETTINGS-general-pesonalisation-standby mode & turn it on now u can c ur theme graphics.tis is the only solution
Apr 28, 2009 | Samsung SGH-i450 Cellular Phone
457 people viewed this tip
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
