Tip & How-To about Nokia N900 Smartphone
Solution for problem in sign in Yahoo messenger in N900
Copy the Link down side. or change the setting in server as (scsc.msg.yahoo.com )
you can change the 4th letter in server as (scsa or scsd) you see in the Link down side.
I try this already in my Nokia N900 itts working rigth now. you can email at kakoimarlon@yahoo.com if work for your N900
http://support.actiance.com/index.php?x=&mod_id=2&id=2208
Nokia N900  Smartphone Logo
Hi ..I can't connect to my yahoo messnger..And it says here's the problem..hope u can help me.. Checking virtual IP servers... [VIP Raw] Resolving host name vcs1.msg.yahoo.com... [PASSED] [VIP Raw] Connecting to Virtual IP server 98.136.48.32... [FAILED] *** 'COMPONENT_TYPE_WININET' value: '12017' *** [VIP Raw] Resolving host name vcs2.msg.yahoo.com... [PASSED] [VIP Raw] Connecting to Virtual IP server 67.195.186.241... [FAILED] *** 'COMPONENT_TYPE_WININET' value: '12017' *** [VIP Raw] Resolving host name 98.136.48.100... [PASSED] [VIP Raw] Connecting to Virtual IP server 98.136.48.100... [FAILED] *** 'COMPONENT_TYPE_WININET' value: '12017' *** [VIP Raw] Resolving host name 98.136.48.110... [PASSED] [VIP Raw] Connecting to Virtual IP server 98.136.48.110... [PASSED] [VIP Raw] Sending HTTP request to the server... [PASSED] [VIP Raw] Receiving response... [FAILED] *** 'COMPONENT_TYPE_WININET' value: '12017' *** [VIP Raw] Resolving host name 67.195.187.228... [PASSED] [VIP Raw] Connecting to Virtual IP server 67.195.187.228... [FAILED] *** 'COMPONENT_TYPE_WININET' value: '12017' *** [VIP Raw] Resolving host name 67.195.187.229... [PASSED] [VIP Raw] Connecting to Virtual IP server 67.195.187.229... [VIP Raw] TIMEOUT Checking HTTP virtual IP servers... [VIP Http] Resolving host name httpvcs1.msg.yahoo.com... [PASSED] [VIP Http] Connecting to HTTP Virtual IP server 98.136.48.229... [FAILED] *** 'COMPONENT_TYPE_WININET' value: '12017' *** [VIP Http] Resolving host name 216.155.194.137... [PASSED] [VIP Http] Connecting to HTTP Virtual IP server 216.155.194.137... [VIP Http] Resolving host name httpvcs2.msg.yahoo.com... [PASSED] [VIP Http] Connecting to HTTP Virtual IP server 98.139.61.47... [FAILED] *** 'COMPONENT_TYPE_WININET' value: '12017' *** [VIP Http] Resolving host name 98.136.112.142... [PASSED] [VIP Http] Connecting to HTTP Virtual IP server 98.136.112.142... [FAILED] *** 'COMPONENT_TYPE_WININET' value: '12017' *** [VIP Http] FAILED *** 'COMPONENT_TYPE_YCP' YCPError: 'FND.0203' ***
can you get an internet connection?
click start control panel internet options you will see a home page box To Create Page Tabs type each adress on its own line (type in yahoo.com)
check your firewall settings make sure yahoo is allowed
click start type in cmd press enter
you should have a black screen you are in dos mode
type in ipconfig
you should see all of your connection details
type in your default gateway adress into your browser (search engine)
hope this helps you
Oct 18, 2011 | Yahoo Messenger
i have nokia c3 i used messenger since two month but yesterday i tried to login but it login in so please solve my problem so that i can use massenger on my phone
Set manually :
- Go to Communication > IM > Option > Setting > Servers
- Server name : imps.msg.yahoo.com
- Access point in use : Your Default
- Web address : http://imps.msg.yahoo.com
Hope this help
Feb 02, 2011 | Yahoo Messenger
Checking virtual IP servers... [VIP Raw] Resolving host name vcs1.msg.yahoo.com... [PASSED] [VIP Raw] Connecting to Virtual IP server 98.136.48.32... [FAILED] *** 'COMPONENT_TYPE_WININET' value: '12029' *** [VIP Raw] Resolving host name vcs2.msg.yahoo.com... [PASSED] [VIP Raw] Connecting to Virtual IP server 67.195.186.241... [FAILED] *** 'COMPONENT_TYPE_WININET' value: '12029' *** [VIP Raw] Resolving host name 68.180.217.15... [PASSED] [VIP Raw] Connecting to Virtual IP server 68.180.217.15... [FAILED] *** 'COMPONENT_TYPE_WININET' value: '12029' *** [VIP Raw] Resolving host name 76.13.15.38... [PASSED] [VIP Raw] Connecting to Virtual IP server 76.13.15.38... [FAILED] *** 'COMPONENT_TYPE_WININET' value: '12029' *** [VIP Raw] FAILED *** 'COMPONENT_TYPE_YCP' YCPError: 'YMSG.ColoSelectionFailed' *** Checking HTTP virtual IP servers... [VIP Http] Resolving host name httpvcs1.msg.yahoo.com... [PASSED] [VIP Http] Connecting to HTTP Virtual IP server 216.155.194.34... [FAILED] *** 'COMPONENT_TYPE_WININET' value: '12029' *** [VIP Http] Resolving host name httpvcs2.msg.yahoo.com... [PASSED] [VIP Http] Connecting to HTTP Virtual IP server 98.136.112.56... [FAILED] *** 'COMPONENT_TYPE_WININET' value: '12029' *** [VIP Http] Resolving host name 216.155.194.137... [PASSED] [VIP Http] Connecting to HTTP Virtual IP server 216.155.194.137... [FAILED] *** 'COMPONENT_TYPE_WININET' value: '12029' *** [VIP Http] Resolving host name 98.136.112.142... [PASSED] [VIP Http] Connecting to HTTP Virtual IP server 98.136.112.142... [FAILED] *** 'COMPONENT_TYPE_WININET' value: '12029' *** [VIP Http] FAILED *** 'COMPONENT_TYPE_YCP' YCPError: 'YMSG.ColoSelectionFailed' ***
1) Clear your browsers out
Download 'ccleaner' and use it daily. Run it through a couple of times,using the factory settings and the 'Run Cleaner' control until 0 bytes are seen to be cleaned following a scan
Run the 'Registry' from the left hand toolbar but 'Save' any changes after opting to 'repair' errors.Never make changes to your Registry without saving the information.
http://www.filehippo.com/download_ccleaner/
Open Internet Explorer (even if you use another browser as default) > Tools > Internet Options > Connections tab > LAN settings > Uncheck all the boxes and check "Automtically detect settings" > Save > Save
Aug 16, 2010 | Yahoo Messenger
I am having problems setting up outlook 2007 for my yahoo.es address.what are the incoming and outgoing mail settings. when I try to do the auto set up it doesnt seem to recognise my network password for yahoo. Unfortunately I do not know the proper incoming and outgoing mail settings in order to manually configure. thanks in anticipation of solution
Here’s how you can read your Yahoo! Mail Plus email using Outlook 2007:
  1. From the Tools menu, select Account Settings.
    Note: If you do not see Account Settings, place your cursor over the two arrows at the bottom of the list to display more choices.
  2. On the E-mail tab, click New. The Add New E-mail Account dialog box appears.
  3. Select the Manually configure server settings or additional server types checkbox. Click Next. The Choose E-mail Service screen appears.
  4. Select Internet E-mail, and click Next. The Internet E-Mail Settings screen appears.
  5. Complete the fields as follows:
    • Your Name: Type your name as you’d like it to appear when you send an email message.
      E-Mail Address: Type your Yahoo! Mail Plus email address (for example, testing80@yahoo.com).
      Account Type: Select POP3 from the pull-down menu.
      Incoming mail server: Type plus.pop.mail.yahoo.com.
      Outgoing mail server (SMTP): Type smtp.mail.yahoo.com.
    • Select the Remember Password checkbox if you don't want Outlook to prompt you for your password each time you check your mail.
    • Do not select the Require logon using Secure Password Authentication (SPA) checkbox.
  6. Click More Settings. The Internet E-mail Settings dialog box appears.
  7. Select the Outgoing Server tab:
    • Select the My outgoing server (SMTP) requires authentication checkbox.
    • Make sure that Use same settings as my incoming mail server is selected.
  8. Click the Advanced tab:
    • For Incoming Server (POP3), select the This server requires an encrypted connection (SSL) checkbox. The number in the Incoming Server (POP3) field automatically changes from 110 to 995. If it doesn’t, type 995.
    • In the Outgoing Server (SMTP) field, type 465. Under Outgoing Server (SMTP), select the This server requires an encrypted connection (SSL) checkbox.
    • Next to Use the following type of encrypted connection, select SSL from the pull-down menu.
    • If want to keep a copy of your email messages on the Yahoo! Mail server, select the Leave a copy of messages on the server checkbox. If you want to delete your messages from the Yahoo! Mail server after viewing them in Outlook, leave the box unchecked.
    • If you want to save your Yahoo! Mail messages on both the Yahoo! Mail server and on your computer, select the Leave a copy of messages on the server checkbox. If you want your messages to be deleted from the Yahoo! server after Outlook has downloaded them onto your computer, leave the box unchecked.
      Note: After your messages are deleted from the server, we cannot retrieve them.
  9. Click OK to close the Internet E-mail Settings dialog box.
  10. Click Next to continue. The Congratulations screen appears.
  11. Click Finish to close the Add New E-mail Account dialog box.
  12. Click Close to close the Account Settings dialog box.
Troubleshooting tips
If you still can’t send Yahoo! Mail from Outlook 2007, you might be accessing the Internet through an ISP that is blocking the SMTP port. If this is the case, try using port 587 when sending email via Yahoo!’s SMTP server. To make this change:
  1. From the Tools menu, select Account Settings. The Account Settings dialog box appears.
  2. Double-click your Yahoo! Mail Plus account. The Change E-mail Account dialog box appears.
  3. Click More Settings. The Internet E-mail Settings dialog box appears.
  4. Click the Advanced tab.
  5. In the Outgoing Server (SMTP) box, type 587.
  6. Click OK to close the Internet E-mail Settings dialog box.
  7. Click Next to continue. The Congratulations screen appears.
  8. Click Finish to close the Change E-mail Account dialog box.
  9. Click Close to close the Account Settings dialog box.
Feb 11, 2010 | Yahoo Mail
2,488 people viewed this tip
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
