Tip & How-To about Computers & Internet
Ways to make your computer perform faster
Have you noticed that your computer runs slower than before. Or just slow in general? Read on to learn some tips to make it go faster.
Tip 1: Remove any programs that you do not use and delete any files that you really will not be needing again, otherwise back it all online to a free service like Dropbox.
Tip 2: Prevent any unnecessary programs from starting when the computer boots. This can be done in the program options, or by altering msconfig.
Tip 3: Keep Hard Disk Free Space anywhere above 15%.
Tip 4: Do a Disk Cleanup and Disk Defragment.
Tip 5: Install additional RAM into your Computer.
Tip 6: Check your computer for any Disk Errors.
Tip 7: Install a great Spyware Scanner and Anti-Virus Software. Research them before installing them.
Computers & Internet Logo
HP pavilion dv5000 running very slow
Go to www.acebyte.com this program is a all around utility and free, this will help with performance and speed even with a slow computer.
Apr 07, 2012 | HP Pavilion Computers & Internet
system booting very slow,system performance very slow
just install ccleaner avail download 4 free and run cleaner and it removes all unwanted files and corrupts in disks and right click on c: properties>tools>defragmention process which removes bad cluster on ur disk which makes ur system slower
Jun 28, 2011 | Computers & Internet
my gx270 PC runs very slow after installing anti virus. what might be the problem?hat might be the reason?
Some anti virus software can use up a lot of system resources and noticeably slow down a computer. The newer and faster computers don't suffer from this problem as much, but on an older computer like your's it can be a problem. I've used Avira (free) on older computers without a problem:
http://www.avira.com/en/support-download-free-antivirus
I don't usually recommend Microsoft products, but Microsoft Security Essentials is not only a very good product and free, but it runs well on older, slower computers:
http://www.microsoft.com/security_essentials/?WT.srch=1
AVG is a good free anti virus also, but it sometimes can slow down a computer a bit. I'm running it on some Netbooks with an Atom 1.6GHz. processor and it does OK. Only way to find out is to try it:
http://free.avg.com/us-en/homepage
Remember that you should only run _one_ anti virus software at a time, so don't forget to un-install the existing anti virus first.
If you purchased an anti virus product and you're stuck with it, this tip may help you speed up your computer:
http://www.fixya.com/support/r3760943-fix_slow_computer
Also, your may be able to increase your performance with a memory upgrade. If your not sure how much or what kind of memory that you have, download and run this:
http://www.gtopala.com/siw-download.html
Scroll down to the SIW Without Installer (English-Only) version. After it's running click on "memory" in the left margin.
Nov 18, 2010 | Dell OptiPlex GX270 PC Desktop
software work to slow and it shot down
Software Installation : Installing more and more software can make the computer slow down. The reasons for that are that installation of a software will make entries in registry and that is somewhat bad. The software may be running in the startup. The software will install various files on the computer and an overloaded hard disk makes the computer slow.
Free up disk space : Try to keep your hard disk space free. You’ll always notice that a computer with free space on hard disk will always run much faster than the one which is loaded with extra stuff.
* Remove Unwanted Items From Startup : Well, if you’ll remove the unwanted softwares from the startup then your computer will boot up much faster and the memory (RAM) will also remain free and thus that will again result in better computing experience
Run hard disk maintenance utilities : Always run the utilities like Disk Defragmentation or Disk checking utilities regularly, around once in 2 weeks
Run Registry Cleaner : Right, this one is related to first tip. In case you’ve already installed and uninstalled various softwares before reading this tutorial then you can go ahead and run various registry cleaning softwares
Oct 14, 2009 | Computers & Internet
379 people viewed this tip
David Payne
David Payne
