Tip & How-To about Sony Alpha DSLR-A580 Body Only Digital Camera
AVCHD to FCP X-MTS/M2TS in 50/60 Progressive mode to FCP X for ProRes 422 (HQ)
HD Videos to Final Cut Pro X-Convert 1920x1080p 50/60 AVCHD files to ProRes for Final Cut Pro X Editing
Final Cut Pro X and AVCHD-Import 1080 60p HD Videos to ProRes FCP X Conversion
The new Sony camcorders like Handycam HDR-CX360VE, CX700V, and Panasonic camcorders like HDC-TM900/HS900/SD900, TM700/HS700/SD700 support recording in 1920x1080/50p mode for PAL regions like UK, France, German, or 1920x1080/60p mode for NTSC regions like US, Canada. Even though Final Cut Pro X with the new UI is said to support AVCHD files natively, without transcoding to Apple ProRes, the 1920x1080p 50/60 AVCHD files still could not be detected/imported to FCP X.
To edit the 1080/60p or 1080/50p Camcorder AVCHD Videos to Final Cut Pro X, the conversion from MTS/M2TS in 50/60 Progressive mode to FCP X ProRes 422 (HQ) or to Apple ProRes 422 is necessary. Aunsoft Final Mate for Mac is the recommended AVCHD to ProRes converter for Final Cut Pro X. It keeps better color than compressor. What's more, it can keep 50fps and 60fps in Apple ProRes.
The guide below shows you how to Convert and Edit 1920x1080p 50/60 AVCHD files to ProRes in Final Cut Pro X.
Step 1. Import 1920x1080p 50/60 AVCHD files to Aunsoft Final Mate for Mac.
Run Final Mate for Mac as the best Final Cut Pro X and AVCHD, which can import files from AVCHD camera and the separate .mts files on Mac hard drive. For files from camera, just use USB cable to connect camera to Mac, and you can select files to download to Final Mate for Mac with the wizard. Otherwise, go to the Resource tab, and click the Add file path button to browse the AVCHD folder with .mts or .m2ts clips.
Step 2. Choose AVCHD files to FCP X ProRes conversion.
Select the files from the Camcorder tab or Resource tab, drag and drop to the Movies tab to create movie for conversion. You can choose the files to be joined as a movie, or create single movie for each file. In terms of joining as a movie, the files would play seamlessly.
Step 3. Choose Apple ProRes 422 (HQ) with 50fps or 60fsp for FCP X.
Click the Export button, and go to the third button for editing software. Choose Final Cut Pro > Apple ProRes 422 (HQ)(*.mov) as the output format. Choose 1920x1080 from the drop-down list of the output video size, and choose 50 or 60 as frame rate according to your camera mode.
Wait for the conversion, and you can then import 1080 60p HD videos to Final Cut Pro X through the direct import and enjoy editing in FCP X.
Tips:
If you face the problem that the resulting ProRes files have no video just sound in FCP X or QuickTime, just make sure you install the related ProRes codec for FCP X, or go to the guide: Solution to ProRes Video Issue in FCP X on aunsoft.com.
Sony Alpha DSLR-A580 Body Only Digital Camera Logo
Transfer/Convert Sony HDR-CX150 AVCHD MTS Movie to Apple ProRes for Final Cut Pro on Mac Sony Handycam HDR-CX150 is listed as one of the best home movie camcorders by Lori Grunin, senior editor from CNET.com. However, people are not giving a high credit for this camcorder. Just like Lori puts it in her review for Sony CX150: "Its small size and attractive price might draw you to the Sony Handycam HDR-CX150, but this bare-bones camcorder just barely delivers on the promise of HD quality." For many Mac users, editing AVCHD footage on Final Cut Pro is not very pleasant with many problems & frustration, though Final Cut Pro 6.0.1 claims to give native AVCHD support. In the guide, I will share with you how to batch convert AVCHD MTS/M2TS videos to Apple ProRes format for smooth editing in FCP without rendering. Featured Camcorder Software for Mac OS X - Aunsoft Final Mate for Mac Aunsoft Final Mate for Mac, a useful camcorder software program for Mac OS X, make it easy to capture AVCHD videos from camcorder, edit in Timeline for joining/cutting/splitting MTS/M2TS files, AVCHD lossless output for HD memories on TV, export to Final Cut or iMovie with provided Apple ProRes codecs & Apple Intermediate Codec, or share the fun online. Highlights of Aunsoft Final Mate for Mac - Full HD support for AVCHD, TOD, MOD camcorders - Support merging/spitting AVCHD without conversion - Convert camcorder footage to Apple ProRes, AIC, Avid DNxHD Codec How to Transfer/Convert Sony CX150 AVCHD to Apple ProRes on Mac OS X Learn how to convert AVCHD MTS or M2TS files to Apple ProRes codec via Aunsoft Final Mate for Mac with Sony CX150 as an example in the guide. Step 1. Import AVCHD MTS from CX150 to program. There are two ways to import AVCHD videos to Aunsoft Final Mate for Mac. - Capture AVCHD videos from CX150 camcorder If you choose to import videos directly from camcorder to the program, first of all, please turn on Sony CX150 and connect it to your Mac via USB cable. Launch Aunsoft Final Mate for Mac and follow camcorder wizard to import videos to the program. Imported Sony mts files will be shown on Camcorder Tab of the program. - Import AVCHD videos from computer If you have already transferred video footage from camcorder to your computer, you can browse the file path through "Add" icon. Then all AVCHD videos in the folder will show in Resource Tab of Aunsoft Final Mate for Mac. Step 2. Join MTS clips into one for conversion. In order to join AVCHD mts clips of Sony CX150 into a complete movie, all you have to do is to drag & drop AVCHD videos from Camcorder Tab or Resource Tab to Movies Tab. During the process, a pop-out window will show as below: Choose "Create A Single Movie" to merge Sony CX160 MTS clips into one movie. Step 3. Convert AVCHD Movie to Apple ProRes. Click on Export and then choose "Export into Editor". In the panel, please follow Final Cut Pro > Apple ProRes 422 to confirm your output format to Convert Sony CX160V AVCHD Movie to FCP ProRes format. Step 4. Transfer output ProRes MOV to Final Cut Pro. Import exported ProRes MOV movie from Aunsoft Final Mate for Mac to Final Cut Pro and start your smooth editing without rendering. If you love video making on Mac OSX, Aunsoft Final Mate is highly recommended as a practical Camcorder Software on Mac. Tip: You may also want to know how to convert AVCHD to Apple Intermediate Codec for iMovie/FCE or merge AVCHD without re-encoding to preserve original quality. Tags: best camcorder software for Mac OS X, Convert MTS/M2TS to Apple ProRes, AVCHD Joiner/Converter on Mac, Convert AVCHD to Apple ProRes 422 HQ
Jun 28, 2011 | Sony Alpha DSLR-A580 Body Only Digital...
1,828 people viewed this tip
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Are you a Sony Camera Expert? Answer questions, earn points and help others
