Tip & How-To about Cameras
LENS ERROR - - DIGITAL CAMERA.
If you hear a noise from the lens when you try to take picture or During turn on/off time then it's a lens guide pin problem OR Somehow its jammed or damaged. It's happens when the camera pressed or drop down during turn on mode or long time not use.
For the solution you need to follow the steps.
1. Turn off the camera and remove the memory card and clean the external body of the camera and make sure in place of the lens there is no dust or damaged sign.
2. Now turn on the camera without memory card & make sure the battery are fully charged.
3. If the lens not moving then give a little shake or thrust by hand ( carefully very slow) and then wait for a moment. If no changes then turn on the camera and give a little twist an anti clock side and leave for few second. It is risky ( Do it slowly at your own risk)
4. If nothing change then reset the camera setting from the menu option.
After following all steps, if the camera does not start working then you need to visit service center for replacing the Lens or Repairing. If you have any more questions ask me I fell happy to answer your question. Thank you.
HOW TO REPAIR IT AT HOME
If you have any more questioned you can ask me. If you happy with my service then before leave please accept my answer so i paid by you. Positive feedback & Bonus appreciated. Thank you.
Cameras Logo
CAMERA SAYS LENS ERROR
b> If you hear a noise from the lens when you tryto take picture or During turn on/off time then it's a lens guide pin problemOR Somehow its jammed or damaged. It's happens when the camera pressed or dropdown during turn on mode or long time not use.This problem happens because of long time no using/ Dust or Lensguide pin damaged. If the lens guide pin damage then there is no chance forrepairing . Only solution is replacing the lens.For the solution you need to follow the steps.1. Turn off the camera and remove the memory card and clean theexternal body of the camera and make sure in place of the lens there is no dustor damaged sign.2. Now turn on the camera without memory card & make sure thebattery are fully charged.3. If the lens not moving then give a little shake or thrust by hand( carefully very slow) and then wait for a moment. If no changes then turn onthe camera and give a little twist an anti clock side and leave for few second.It is risky ( Do it slowly at your own risk)4. If nothing change then reset the camera setting from the menuoption.After following all steps, if the camera doesnot start working then you need to visit service center for replacing the Lensor Repairing. But before repairing ask service center the approx cost. if theytold you to replacing the lens then do not do that. Because a new lens &service charge cost you near about a new camera price. So best is buy a newcamera. If you have any more questions ask me I fell happy to answer yourquestion. Thank you.
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html- - - Do it your self lens fix
Jun 04, 2012 | Kodak EasyShare Cameras
not open camera lence
Ifyou hear a noise from the lens when you try to take picture or During turnon/off time then it's a lens guide pin problem OR Somehow its jammed ordamaged. It's happens when the camera pressed or drop down during turn on modeor long time not use.This problem happens because of long time no using/ Dust or Lensguide pin damaged after drop down. If the lens guide pin damage then there isno chance for repairing . Only solution is replacing the lens.For the solution you need to follow the steps.1. Turn off the camera and remove the memory card and clean theexternal body of the camera and make sure in place of the lens there is no dustor damaged sign.2. Now turn on the camera without memory card & make sure thebattery are fully charged.3. If the lens not moving then give a little shake or thrust by hand( carefully very slow) and then wait for a moment. If no changes then turn onthe camera and give a little twist an anti clock side and leave for few second.It is risky ( Do it slowly at your own risk)4. If nothing change then reset the camera setting from the menuoption.After following all steps, if the camera does not start working thenyou need to visit service center for replacing the Lens or Repairing. Butbefore repairing ask service center the approx cost. if they told you toreplacing the lens then do not do that. Because a new lens & service chargecost you near about a new camera price. So best is buy a new camera. If youhave any more questions ask me I fell happy to answer your question. Thank you.
May 23, 2012 | Samsung L210 Digital Camera
1. turn camera on 2. lens expands 3. lense immediately retracts 4. lens error
Jul 08, 2011 | Nikon Coolpix 5700 Digital Camera
cannot open camera lens. it says "lens error 1511 or 1211
Jul 06, 2011 | Cameras
it cannot be turn off
Jul 06, 2011 | Canon PowerShot A480 Digital Camera
431 people viewed this tip
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
