Tip & How-To about Sony Alpha DSLR-A580 Body Only Digital Camera
No Blue Screen Canvas in FCP-Enjoy HD video editing in FCP with AVCHD to ProRes 422 conversion
No More BlueScreen Unrendered Message in Canvas Window in Final Cut Pro
AVCHD to ProRes No Blue Screen Message-Edit ProRes files in FCP without rendering
Do you ever face the error Blue Screen Message in Canvas Window saying that the file is unrendered, even if you have already use Aunsoft Final Mate for Mac to convert the AVCHD footage to MOV or Apple ProRes 422? Some of the customers have reported about the issue of files need to be rendered in FCP when they bring the output MOV files to the timeline.
Actually, it could be done by making the sequence settings in Final Cut Pro the same as that of the MOV file. Then you could import the MOV files from AVCHD to ProRes conversion by Final Mate for Mac, and edit HD videos in FCP without rendering.
The guide below will show you the simple steps for converting AVCHD to Apple ProRes 422 for Final Cut Pro 6 or 7, so that there is No more Blue Screen Unrendered Message.
Step 1. Import AVCHD files to Aunsoft Final Mate for Mac.
With Final Mate for Mac, you can import files with camcorder connected to iMac/MacBook, or AVCHD folder from hard drive. You will get pop-up message for camcorder wizard if camcorder is connected. Follow the wizard to import files. Alternatively, go to the Resource tab, and click the Add file path button to browse the AVCHD folder with .mts or .m2ts clips.
Step 2. Select files for AVCHD to Apple ProRes conversion.
Select the files from the Camcorder tab or Resource tab, drag and drop to the Movies tab, and you will face the message asking you to create one movie, or one movie for each clip. Choose "Create A Single Movie", if you want to join and merge the files. Choose "Create A Movie for Each File", if you would like to keep the number of files.
Step 3. Choose Apple ProRes 422 format with 1920x1080 for FCP.
Click the Export button, and go to the third button for editing software. Choose Final Cut Pro > Apple ProRes 422 as the output format. Choose 1920x1080 from the drop-down list of the output video size.
You can also change the output folder for the ProRes files if you like. Then click the OK button to start MTS/M2TS to ProRes 422 conversion.
When the conversion is done, just click the Browse for Export Path button on the Conversion window, and you will find the ProRes files for FCP editing without rendering. Run FCP 6 or 7, and choose File > Import > Files to browse the .mov files exported by Aunsoft Final Mate for Mac.
To get rid of the unrendered message, you can use the following method:
1. When you import the file to timeline, FCP shall automatically pop up a message like below asking you to change the sequence settings to match the clip settings or not. Click Yes, and there will be No BlueScreen Unrendered Message in Canvas Window.
2. If you do not get the pop-up message, you can change the sequence settings manually. Just right click on the sequence ID, and choose Settings, you will face the Sequence Settings window. Change the settings to that you choose in the output window of Final Mate for Mac.
For example, click the drop-down box for Aspect Ration and choose HDTV 1080i, choose Square for Pixel Aspect Ration, and choose Apple ProRes 422 Codec. Click OK to save, and import the .mov file to timeline.
You can easily Enjoy the HD video editing in FCP 6/7 with the AVCHD to Apple ProRes 422 conversion from Final Mate for Mac.
Sony Alpha DSLR-A580 Body Only Digital Camera Logo
Convert AVCHD Files to Apple ProRes 422 for FCP with Best Camcorder Software for Mac Do you have problems of importing AVCHD 1080/60p, 1080/50p, 1080/60i MTS or M2TS files to Final Cut Pro and want to find camcorder software on Mac OS X to Transcode AVCHD files to Apple ProRes Codec for editing in FCP without rendering? As the best camcorder software on Mac OS X for Sony, Panasonic, Canon, JVC camcorders, Aunsoft Final Mate for Mac is featured with one most important feature for Mac users-help Convert AVCHD video footage to Final Cut Pro ProRes formats including Apple ProRes 422 Codec, Apple ProRes 422 HQ Codec, Apple ProRes 422 LT, Apple ProRes 422 Proxy, Apple ProRes 4444 Codec. With Final Mate for Mac as the default camcorder software on Mac, you can choose preferable format for editing on Final Cut Pro without rendering. Final Mate for Mac also support converting AVCHD files to Apple Intermediate Codec(AIC)for editing in Final Cut Express or iMovie. The guide will share with you a easy and fast method of Converting AVCHD files to Apple ProRes 422 with featured software for camcorder on Mac. 1.Run AVCHD to Apple ProRes Converter for Mac and add AVCHD files. Launch Aunsoft Final Mate for Mac and add AVCHD files to the program by clicking on "Add" button to browser AVCHD file path on your local Mac computer. Then all AVCHD MTS/M2TS clips will show in Resource Tab of Final Mate for Mac. 2.Join AVCHD files and choose Apple ProRes 422 as output option. Directly drag and drop AVCHD files from Resource Tab to Movies Tab or Timeline to create a new movie and join AVCHD files into one for converting to Apple ProRes 422 Codec. There will be a pop-out window during the process shown as following: Please choose "Create A Single Movie" to merge all AVCHD video footage into one movie. 3. Start converting AVCHD to Apple ProRes 422 Click on Export button and follow Export into Editor > Final Cut Pro > Apple ProRes 422 HQ(*.mov) format to choose your output format for converting AVCHD to FCP supported format. Confirm your settings and click ok to starting conversion. Minutes later, you can access combined Apple ProRes 422 MOV movie by clicking on "Browse for Export Path". Now you are able to edit AVCHD files on FCP without rendering with the help of Final Mate for Mac as the best camcorder software on Mac OS X.. Tip: If you use iMovie or Final Cut Express for AVCHD editing, you may be interested to know how to Convert AVCHD files to Apple Intermediate Codec for iMovie/FCE.
Jun 28, 2011 | Sony Alpha DSLR-A580 Body Only Digital...
1,554 people viewed this tip
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Are you a Sony Camera Expert? Answer questions, earn points and help others
