Tip & How-To about Pool & Spa
Keep your swimming pool water clear
Did you ever wonder how some pools stay so clear? Here is a tip that has worked for years with our family. We add three boxes of baking soda every month and only use a chlorine tablet in the floating tablet holder and thats it! Just pour the baking soda into the pool water. No other chemicals! The pool stays clear all summer long. Dont mess with all those chemicals! You will be saving money and making your pool duties much more simple. Try it. I promise you will be thanking me later :)
Pool & Spa Logo
what to do if too much alkaline in pool
if PH too low add soda ash or baking soda if PH too high add acid muriatic or powder if alkalinity too low add Alk up or soda ash if alk too high add muriatic acid but check PH after PH should br between 7.2 and 7.6 alk should be 80 to 120
May 25, 2014 | Intex Automatic Salt Water System for ...
gas smell in coleman cooler
Clearly someone used the cooler to dump gasoline that was probably old. That odor is extremely difficult to get out. First try this: Let it air out indirect sunlight, tilting the cooler so the sunlight gets to the inside, Do this for at least three days and as much as a week. After you've done that, there will likely still be some of the gasoline smell still there but it should be a lot less noticeable.
Next, get a large box or even a bag of baking soda. Make sure the drain plug is in and dump at least two cups of baking soda in the bottom of the cooler.
Add enough water to make a paste of the baking soda. The paste should be thick enough to smear and stick to the walls of the cooler. Do that...smear it on, completely covering the walls, bottom and inside of the top of the cooler.
If you run out of paste make a little more but make sure that every part of the inside of the cooler is covered with paste. Leave the paste on for a minimum of 24 hours but preferably 48 hours or more. Shut the lid to slow down drying of the paste.
After 24 hours or more, check to see if any odor remains. If it does, wait another 24 hours. After 48 hours, the baking soda will likely have done as much as it's going to do. Rinse the dried baking soda off the walls bottom and top, letting the residue collect in the water that is filling the cooler.
Add the remaining baking soda in the box or bag to the water stirring it until it has dissolved. Fill the cooler to the top with water and close the lid. Wait 24 hours then drain the cooler. If you're lucky the odor, or most of it, will be gone.
This is a slow tedious process but it can work. I've never tried it on gasoline odor but I used it forplastic pickle buckets and it's never gotten the odor completely out but it has gotten enough out to make the bucket usable. Good luck!
Apr 02, 2014 | Coleman 54qt Classic Steel Belted Cooler
1,458 people viewed this tip
Top Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
