Tip & How-To about Nokia 6300 Cellular Phone
Water problem with cell phones
When ever a phone drops inside the water, first remove the battery cause the battery life might be damaged,and also in that process the phone is still working because the battery is still inside the phone.
You will need to service the phone for the phone to be free from water,cause if the water dries inside the phone it will damage an IC or a chip inside the phone and it might cause more damage to the phone.
After, disassembling the phone is the next step.
Get a phone screw and unscrew the phone from the back by removing the battery and you will see some screws, unscrew possible screws and open the phone.
Get a methylated spirit and a small brush, remove the board of the phone and deep the brush inside the methylated spirit,brush gently on the board of the phone. After brushing, get a dryer to dry up the board of the phone and live it for a while to dry.
After some minutes,assemble the phone back and fix in the battery. Make sure during the process you are charging the battery of the phone.
I guess that's all you need.
Note: if the battery has stayed too too long on the phone and am sorry after the water splash, it might not come on after this all process, that means you will have to flash the phone because the battery might have damaged the memory of the board of the phone and will not power up the phone because the phone is too weak to power.
Flashing of the phone will restore back the phone memory.
You can visit the web to learn more about flashing of phones.
Nokia 6300 Cellular Phone Logo
how do i get water out from under the touch screen ???
Hi, when ever a phone drops inside the water, first remove the battery cause the battery life might be damaged,and also in that process the phone is still working because the battery is still inside the phone.
After some minutes,assemble the phone back and fix in the battery. Make sure during the processyou are charging the battery of the phone.
You can visit the below link to learn more about flashing of phones.
hubpages.com/hub/How-to-Flash-your-cell-phone
and
unlocktotalk.com/UnlockCodeInstructions.htm.
Hope it helped.
Feel free to pass your comment.
Thanks for using fixya.....
Jun 16, 2011 | Sony Ericsson XPERIA X10 Cell Phone
I dropped my nokia expressmusic 5800 down the toilet, it didnt work for months, i just tried it, it turns on and can be plugged into computers but i cannot see anything on the screen apart from the faint nokia sign when it turns on. Is the backlight broken or is it something else?
For your phone screen not displaying, Water is still inside the screen, might have affected the screen display. You might need to replace the screen....
and
Hope it helped.
Jan 24, 2011 | Nokia 5800 XpressMusic Smartphone
dropped it for 2 seconds in the shower...picked it up right away.....water seems to appear on in the screen....what to do ?
and
Hope it helped.
Jan 21, 2011 | Cell Phones
samsung genie GT-S3650 drop in my drink help
Water problem or drink.
Hi, when ever a phone drops inside the water or drink, first remove the battery cause the battery life might be damaged,and also in that process the phone is still working because the battery is still inside the phone.
and
Hope it helped.
Jan 18, 2011 | Cell Phones
how can i take my lg prime phone aprt so i can let it dry because i dropped it in water
you can use the below link to know how to disassemble LG phones,just type the model of the phone on the search box.
lg-phones.org/lg-optimus-7-disassembly-guide.html
After, disassembling the phone is the next step.Get a methylated spirit and a small brush, remove the board of the phone and deep the brush inside the methylated spirit,brush gently on the board of the phone. After brushing, get a dryer to dry up the board of the phone and live it for a while to dry.
Hope it helped.
Jan 17, 2011 | Cell Phones
2,367 people viewed this tip
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
