Tip & How-To about Computers & Internet
How to Convert 2D Video to 3D AVI? If you have a slew of videos and want to convert them to 3D videos, for example in AVI format, you can definitely use DVDFab 2D to 3D Converter to do it smoothly and successfully. It is easy to use, allows you to freely customize everything, and gives you the feeling that you're a master at this. Now let's experience the whole 2D video to 3D AVI conversion together, with DVDFab 2D to 3D Converter. 2D Video to 3D AVI>Step 1: Run DVDFab Video Converter, enable "2D to 3D" option Run DVDFab Video Converter since 2D to 3D Converter is contained in it. Choose "to AVI" option then load in the source video. After the video is in, the "2D to 3D" option is enabled for you to choose. Just check it. 2D Video to 3D AVI>Step 2: Customize to make your own 3D video You can easily change its profile since all profiles are optimized and preset in the drop down menu. And the video can be previewed in real time to help you avoid any setting mistake. You can set the 3D video effect via "Video Effect Settings" button. Set 3D format, video frame size, visual depth, and so on. Crop the play region to your heart content. Resize source aspect ratio, and frame resolution. Click "Edit" button, then you can set a lot of video/audio parameters if you like. 2D Video to 3D AVI>Step 3: Start to convert 2D to 3D If you are ready, click "Start" to start conversion. No time later, you will get your output AVI video in 3D effect. By the way, you can set auto shutdown for your computer but considering the conversion will be finished with super fast speed, there's no need to do this. OK, that's all.
Computers & Internet Logo
CONVERT 2D TO 3D
If you just need the basic 2d to 3d conversion, I think a high definition video converter is a great and helpful tool, which can satisfy your demand of 2d to 3d conversion.
Jan 31, 2012 | Computers & Internet
How to Rip and Convert 2D DVD to 3D AVI Video DVDFab 2D DVD to 3D Converter is a good hand to help out for one to convert a normal DVD, Blu-ray or video in 2D effect to 3D videos in various formats for playback on computer with some specific 3D player software, or on 3D TV. Next, I'll show you how to use 2D to 3D Converter to convert 2D DVD to 3D AVI. Read on. Rip 2D DVD to 3D AVI>Step 1: Run DVD Ripper, enable "2D to 3D" option Run DVDFab DVD Ripper at first, choose "to AVI" mode. Then import the source DVD: insert DVD disc into DVD drive, click DVD folder icon or image file icon. You'll be asked to specify a region code for the movie, just do it. Then "2D to 3D" option is ready to be selected, just tick the check box to enable 2D to 3D Converter. Rip 2D DVD to 3D AVI>Step 2: Flexible settings and customization Choose one or more movie titles for conversion, and select audio tracks and subtitles. Specify a profile for movie title. Click "Title Start/End Settings" button to arrange the start and end chapter to select an accurate section for conversion. Go to preview title in real time if you want to make sure that you haven't made any setting flaws. Click "Edit" button to set lots of parameters for conversion, such as bit rate, frame rate, frame resolution, aspect ratio, channel, volume, etc. Click "Video Effect Settings" button, then go to freely set up 3D format, video frame size, visual depth, play region, etc. Rip 2D DVD to 3D AVI>Step 3: Begin converting process Click "Start" button if everything is OK. During the process, you'll be updated with detailed progress info and source movie preview. And you can also set your computer to auto shutdown when necessary. OK, done. It's really easy and wonderful, right?
Jul 05, 2011 | Computers & Internet
How to Convert 2D Video into 3D MP4 Video If you want to convert a video into MP4 format, you'll definitely know how to. What about converting a 2D video into a 3D MP4? If there's an easy way for you to do that, then you can create your favorite 3D videos for pleasant enjoying. Yes, there is an easy way, and professional, and flexible. That is DVDFab 2D to 3D Converter, which can convert a 2D DVD, Blu-ray, and video into 3D videos available in various formats. Well, let's head over onto the detail about 2D video to 3D MP4 conversion. 2D Video to 3D MP4>Step 1: Fire up DVDFab 2D to 3D Converter Before running 2D to 3D Converter, you need to start up DVDFab, and navigate to Video Converter>to MP4, then load in the source video. After the video is imported in and selected by default, your time to enable 2D to 3D Converter arrives. Just check the "2D to 3D" option. 2D Video to 3D MP4>Step 2: Customize output at your whim You need to specify a profile for the video. Then you can freely do settings or customization. Click "Video Effect Settings" button, then you can decide to output 2 separate files or a side-by-side file or top/bottom file, you can choose the output video frame size as 100% or 50%, and you can set your favorite 3D visual depth as showed in the below interface. You can crop the 3D video play region automatically or manually. You can resize the source aspect ratio, frame resolution, etc. Click "Edit" button, and a lot of video and audio parameters and more things are under your choice. 2D Video to 3D MP4>Step 3: Start to convert 2D to 3D Just click "Start" button on the main interface to start conversion. During the process, you can monitor progress with detailed info and you can also set auto shutdown for your computer. Very soon, the process will be completed successfully. OK, that's all there is to it. Learn more about DVDFab 2D to 3D Converter, please go to
Convert DVD, AVI, WMV, MP4, 3GP, MPG and TS to 3D In the movies nothings works anymore without 3D; now the technique enters the home cinema and even the PC. Engelmann Software presents the world premiere Windows-Software MakeMe3D, which will be released soon. This software can convert existing 2D-videos automatically into the third dimension. The new 3D-videos are compatible to the known Anaglyph 3D glasses and to the new Stereoscopic 3D Hardware. 3D is currently 'the one' new technique. What was hardly conceivable a few months ago has become reality long since. The audience in the cinema put on the 3D-glasses to watch movies in a completely new dimension. And a lot more is happening: the industry is busy tinkering with the 3D-Blu-ray Disc, the 3D-TV and the 3D-computer. This undoubtedly marks only the beginning of a new 3D-boom, which will keep entertainment electronics and IT-sector busy for the next ten years. This 2D to 3D Video Converter is extremely easy to operate: new technology does not necessarily have to be complicated. The program supports the import of 2D-videos and others in formats Video-DVD, AVI, WMV, MP4, 3GP, MPG and TS, to mention only the most important. The program stores the converted 3D-videos in formats AVI, MPG, MP4 and WMV. It is possible to select from numerous target profiles. For example, the video resolution is automatically adjusted to the parameters for iPad, PlayStation PS3 or Xbox 360. When converting a large number of 2D-videos the batch mode is an option. This mode converts all videos of a list and saves user precious time. For 3D-conversion we use our self-developed object recognition and motion analysis. We can force vertical or horizontal output, realize page- or frame flipping, have the brightness adjusted automatically and set the depth effect completely variably.
May 21, 2011 | Computers & Internet
228 people viewed this tip
David Payne
David Payne
