Tip & How-To about Computers & Internet
How to Convert 2D Video into 3D MP4 Video If you want to convert a video into MP4 format, you'll definitely know how to. What about converting a 2D video into a 3D MP4? If there's an easy way for you to do that, then you can create your favorite 3D videos for pleasant enjoying. Yes, there is an easy way, and professional, and flexible. That is DVDFab 2D to 3D Converter, which can convert a 2D DVD, Blu-ray, and video into 3D videos available in various formats. Well, let's head over onto the detail about 2D video to 3D MP4 conversion. 2D Video to 3D MP4>Step 1: Fire up DVDFab 2D to 3D Converter Before running 2D to 3D Converter, you need to start up DVDFab, and navigate to Video Converter>to MP4, then load in the source video. After the video is imported in and selected by default, your time to enable 2D to 3D Converter arrives. Just check the "2D to 3D" option. 2D Video to 3D MP4>Step 2: Customize output at your whim You need to specify a profile for the video. Then you can freely do settings or customization. Click "Video Effect Settings" button, then you can decide to output 2 separate files or a side-by-side file or top/bottom file, you can choose the output video frame size as 100% or 50%, and you can set your favorite 3D visual depth as showed in the below interface. You can crop the 3D video play region automatically or manually. You can resize the source aspect ratio, frame resolution, etc. Click "Edit" button, and a lot of video and audio parameters and more things are under your choice. 2D Video to 3D MP4>Step 3: Start to convert 2D to 3D Just click "Start" button on the main interface to start conversion. During the process, you can monitor progress with detailed info and you can also set auto shutdown for your computer. Very soon, the process will be completed successfully. OK, that's all there is to it. Learn more about DVDFab 2D to 3D Converter, please go to
Computers & Internet Logo
How to Rip and Convert 2D DVD to MP4 3D Video You really love the great effect that 3D videos bring to you, but don't have enough 3D resources? Then create 3D yourself! Use DVDFab 2D to 3D Converter, you can convert a 2D DVD to 3D videos for playback on PC with specific player software such as NVIDIA 3D Vision Video Player or Stereoscopic Player, or you can view them on a compatible 3D TV. In this tip, you'll learn how to convert DVD to MP4 video with 3D effect, just read on. Required tool: 2D DVD to 3D Converter Rip 2D DVD to MP4 3D Video>Step 1: Fire up 2D to 3D Converter DVDFab 2D to 3D Converter is embedded in DVD Ripper, Blu-ray Ripper and Video Converter for different tasks as a "2D to 3D" option. For this task, we need to use DVD Ripper. Just run DVD Ripper, choose "to MP4" mode. Then import in the source DVD, and check the "2D to 3D" box to enable 2D to 3D Converter. Rip 2D DVD to MP4 3D Video>Step 2: Set up for conversion Now let's set things for conversion. At first you need to choose one or more titles for conversion (longest movie title is always selected in default), and choose your favorite audio tracks and subtitles, and if your want to choose only a segment of a title for conversion, you can select the title's start and/or end chapter to specify the segment via "Title Start/End Settings" button. One neat thing is that you can preview movie title in real time to check previous settings. Now let's go further to click "Video Effect Settings" button to set for the output 3D video effect in the following windows, you can see all things in detail from there. Click "Edit" button to pop up below window. You can set lots of parameters for video, audio, etc. Rip 2D DVD to MP4 3D Video>Step 3: Start conversion Alright, now hit "Start" button on the main interface to trigger conversion process. When everything is being converted, you can view detailed progress status with data and pictures, and you can choose to go away to relax by setting auto shutdown for your computer, then return to collect your output MP4 3D video. OK. The process will be completed quickly, and you'll successfully create your own 3D MP4 videos out of a normal 2D DVD. It's fantastic. Enjoy yourself.
Jul 05, 2011 | Computers & Internet
How to Rip and Convert 2D DVD to 3D AVI Video DVDFab 2D DVD to 3D Converter is a good hand to help out for one to convert a normal DVD, Blu-ray or video in 2D effect to 3D videos in various formats for playback on computer with some specific 3D player software, or on 3D TV. Next, I'll show you how to use 2D to 3D Converter to convert 2D DVD to 3D AVI. Read on. Rip 2D DVD to 3D AVI>Step 1: Run DVD Ripper, enable "2D to 3D" option Run DVDFab DVD Ripper at first, choose "to AVI" mode. Then import the source DVD: insert DVD disc into DVD drive, click DVD folder icon or image file icon. You'll be asked to specify a region code for the movie, just do it. Then "2D to 3D" option is ready to be selected, just tick the check box to enable 2D to 3D Converter. Rip 2D DVD to 3D AVI>Step 2: Flexible settings and customization Choose one or more movie titles for conversion, and select audio tracks and subtitles. Specify a profile for movie title. Click "Title Start/End Settings" button to arrange the start and end chapter to select an accurate section for conversion. Go to preview title in real time if you want to make sure that you haven't made any setting flaws. Click "Edit" button to set lots of parameters for conversion, such as bit rate, frame rate, frame resolution, aspect ratio, channel, volume, etc. Click "Video Effect Settings" button, then go to freely set up 3D format, video frame size, visual depth, play region, etc. Rip 2D DVD to 3D AVI>Step 3: Begin converting process Click "Start" button if everything is OK. During the process, you'll be updated with detailed progress info and source movie preview. And you can also set your computer to auto shutdown when necessary. OK, done. It's really easy and wonderful, right?
How to Convert 2D Video to 3D AVI? If you have a slew of videos and want to convert them to 3D videos, for example in AVI format, you can definitely use DVDFab 2D to 3D Converter to do it smoothly and successfully. It is easy to use, allows you to freely customize everything, and gives you the feeling that you're a master at this. Now let's experience the whole 2D video to 3D AVI conversion together, with DVDFab 2D to 3D Converter. 2D Video to 3D AVI>Step 1: Run DVDFab Video Converter, enable "2D to 3D" option Run DVDFab Video Converter since 2D to 3D Converter is contained in it. Choose "to AVI" option then load in the source video. After the video is in, the "2D to 3D" option is enabled for you to choose. Just check it. 2D Video to 3D AVI>Step 2: Customize to make your own 3D video You can easily change its profile since all profiles are optimized and preset in the drop down menu. And the video can be previewed in real time to help you avoid any setting mistake. You can set the 3D video effect via "Video Effect Settings" button. Set 3D format, video frame size, visual depth, and so on. Crop the play region to your heart content. Resize source aspect ratio, and frame resolution. Click "Edit" button, then you can set a lot of video/audio parameters if you like. 2D Video to 3D AVI>Step 3: Start to convert 2D to 3D If you are ready, click "Start" to start conversion. No time later, you will get your output AVI video in 3D effect. By the way, you can set auto shutdown for your computer but considering the conversion will be finished with super fast speed, there's no need to do this. OK, that's all.
How to Convert 2D Video to 3D Video Ever imagined that a normal 2D video can be magically turned into a 3D video which can be played by compatible software player on your computer or 3D TV? Using DVDFab 2D to 3D Converter, you can achieve this smoothly with success. 2D to 3D Converter is robust, quick, and easy to use. Required Tools: 2D to 3D Converter 2D Video to 3D Video>Step 1: Run 2D to 3D Converter in Video Converter 2D to 3D Converter is embedded in Video Converter as the option of "2D to 3D", which is convenient for users to use both of the two products to finish this 2D to 3D conversion task. So we need to run Video Converter at first. Then choose a compatible mode from multiple supported ones ("to AVI", "to MKV", "to MP4", "to FLV") and import in the source video we want to convert. After the source video is loaded in, the "2D to 3D" option is ready to be selected with a check box in front of it, just check it. 2D Video to 3D Video>Step 2: Click Video Effect Settings button, and Edit button Click Video Effect Settings button to customize the 3D format, video frame size, source aspect ratio, frame resolution, play region, etc. for the output 3D video. All right, now click Edit button on the main interface to set up a lot of video/audio parameters for the conversion. 2D Video to 3D Video>Step 3: Click Start button to convert 2D to 3D Now we've finished all the settings, just head over to click Start button on the main UI to start converting. Just sit back and relax, and no long time later you'll get your terrific 3D videos Now we've finished all the settings, just head over to click Start button on the main UI to start converting. Just sit back and relax, and no long time later you'll get your terrific 3D videos
161 people viewed this tip
David Payne
David Payne
