Tip & How-To about Computers & Internet
How to Convert 2D Video to 3D Video Ever imagined that a normal 2D video can be magically turned into a 3D video which can be played by compatible software player on your computer or 3D TV? Using DVDFab 2D to 3D Converter, you can achieve this smoothly with success. 2D to 3D Converter is robust, quick, and easy to use. Required Tools: 2D to 3D Converter 2D Video to 3D Video>Step 1: Run 2D to 3D Converter in Video Converter 2D to 3D Converter is embedded in Video Converter as the option of "2D to 3D", which is convenient for users to use both of the two products to finish this 2D to 3D conversion task. So we need to run Video Converter at first. Then choose a compatible mode from multiple supported ones ("to AVI", "to MKV", "to MP4", "to FLV") and import in the source video we want to convert. After the source video is loaded in, the "2D to 3D" option is ready to be selected with a check box in front of it, just check it. 2D Video to 3D Video>Step 2: Click Video Effect Settings button, and Edit button Click Video Effect Settings button to customize the 3D format, video frame size, source aspect ratio, frame resolution, play region, etc. for the output 3D video. All right, now click Edit button on the main interface to set up a lot of video/audio parameters for the conversion. 2D Video to 3D Video>Step 3: Click Start button to convert 2D to 3D Now we've finished all the settings, just head over to click Start button on the main UI to start converting. Just sit back and relax, and no long time later you'll get your terrific 3D videos Now we've finished all the settings, just head over to click Start button on the main UI to start converting. Just sit back and relax, and no long time later you'll get your terrific 3D videos
Computers & Internet Logo
How to convert MKV/AVI/WMV/FLV/VOB/MTS/TIVO to 3D and transfer them to the HTC EVO 3D HTC EVO 3D is really an amazing android cellphone which features 3D video playback and record. And we would like to share you a good tool to play 2D or 3D videos on HTC EVO 3D. This 2D to 3D Video Converter enables u to convert any 2D Video formats or DVD movies to 3D without breaking the bank. This 3D Video Converter offers a range of 3D modes - Stereo, Anaglyph, Anaglyph Gray, and more - so you can choose the one that best suits you, your monitor, and your glasses. 3D Depth, Shift and Perspective are the parameters making the magic of adding 3D 'volume' to 2D videos. Experiment with different values to get the maximum depth perception. Thanks to the real-time preview feature, you'll see the results immediately. Wanna know how to convert videos to 3D format for playback on HTC EVO 3D? Add 2D video files or DVD movies onto this video software and choose output video format as following. Before conversion, you can set 3D mode, 3D Depth, Shift and Perspective. Then click "Convert" to start conversion. Once the conversion is done, mount your EVO 3D on to your computer via USB Once mounted, create a folder named Video in the root folder on the EVO 3D Copy converted file into the Video folder That's it! The converted video can now be played on your EVO 3D using the Gallery app. It should look fantastic on the EVO 3D's screen as long as the original source was of good quality. A few things to keep in mind when converting video: 1. The EVO 3D does not like video file sizes over 2GB (the settings in Step II should help insure that the file size is kept under 2GB) 2. Your converted video will only be as good as the source video 3. If your source is over 960 x 540, you must be sure to set the width and height to a maximum of 960 x 540
Jul 05, 2011 | Computers & Internet
How to Create MKV 3D Video Out of 2D DVD Is this your dream that you have some kind of magic that you can turn a 2D movie to 3D movie with fantastic 3D effect? It comes true now with the powerful tool - DVDFab 2D to 3D Converter. 2D to 3D Converter is the world's first full-featured 2D to 3D conversion app which can convert a normal 2D DVD/Blu-ray/video to 3D video available in various formats including MKV. Next is a step by step tutorial on how to convert 2D DVD to 3D MKV video. Required tool: 2D DVD to 3D Converter Rip 2D DVD to 3D MKV>Step 1: Trigger "2D to 3D" option Make sure that you have DVDFab installed on your computer. Start it up, navigate to "DVD Ripper --> to MKV" option. Now you're under the mode for ripping DVD to MKV video. Then you need to import the source movie via inserting DVD disc, or clicking DVD folder or image file icon. After the movie is in, check the "2D to 3D" box. OK, now 2D to 3D Converter is ready to work. Rip 2D DVD to 3D MKV>Step 2: Prepare and set for conversion Choose the title(s) you want to convert, note that the longest movie title is always selected for you in default. Then choose audio and subpicture streams for movie title. If you don't want to convert all content of a title, you can arrange its start and/or end chapter to extract a segment via "Title Start/End Settings" button on the main interface. In the left bottom corner of the UI, is a built-in player for you to preview title in real time. You can further edit the output effect by clicking "Video Effect Settings" button with a pop up where the 3D Format, Video Frame Size, Visual Depth, play region, etc. can be customized freely. You are allowed to change a lot of default parameters of the video and audio if you like. Just click "Edit" button to open Conversion Settings window. Rip 2D DVD to 3D MKV>Step 3: Start conversion When you're ready, click "Start" button on the main interface. You can view detailed progress info, preview source movie, and set auto shut-down for your computer. OK. That's all for this tutorial. Create 3D MKV out of 2D DVD is just so easy.
How to Convert 2D Video into 3D MP4 Video If you want to convert a video into MP4 format, you'll definitely know how to. What about converting a 2D video into a 3D MP4? If there's an easy way for you to do that, then you can create your favorite 3D videos for pleasant enjoying. Yes, there is an easy way, and professional, and flexible. That is DVDFab 2D to 3D Converter, which can convert a 2D DVD, Blu-ray, and video into 3D videos available in various formats. Well, let's head over onto the detail about 2D video to 3D MP4 conversion. 2D Video to 3D MP4>Step 1: Fire up DVDFab 2D to 3D Converter Before running 2D to 3D Converter, you need to start up DVDFab, and navigate to Video Converter>to MP4, then load in the source video. After the video is imported in and selected by default, your time to enable 2D to 3D Converter arrives. Just check the "2D to 3D" option. 2D Video to 3D MP4>Step 2: Customize output at your whim You need to specify a profile for the video. Then you can freely do settings or customization. Click "Video Effect Settings" button, then you can decide to output 2 separate files or a side-by-side file or top/bottom file, you can choose the output video frame size as 100% or 50%, and you can set your favorite 3D visual depth as showed in the below interface. You can crop the 3D video play region automatically or manually. You can resize the source aspect ratio, frame resolution, etc. Click "Edit" button, and a lot of video and audio parameters and more things are under your choice. 2D Video to 3D MP4>Step 3: Start to convert 2D to 3D Just click "Start" button on the main interface to start conversion. During the process, you can monitor progress with detailed info and you can also set auto shutdown for your computer. Very soon, the process will be completed successfully. OK, that's all there is to it. Learn more about DVDFab 2D to 3D Converter, please go to
How to Convert 2D DVD to 3D Video The brand new DVDFab product 2D to 3D Converter is able to convert a 2D DVD to 3D video(s) with great 3D effect. The output 3D videos can be played on computer, compatible 3D TV, or other compatible 3D display devices. And it's very easy to fulfill this 2D to 3D conversion. Just follow me to see how to. Required Tools: 2D DVD to 3D Converter 2D DVD to 3D Video>Step 1: Import source DVD into DVD Ripper, enable "2D to 3D" option In order to convert 2D DVD to 3D video, we should firstly start up DVD Ripper, and 2D to 3D Converter is embedded in DVD Ripper as a "2D to 3D" option. Import the source 2D DVD into DVD Ripper, choose one support mode on the left navigation pane of DVD Ripper. Here we'll choose "to AVI" as example, by the way, the other support modes are: "to MKV", "to MP4", and "to FLV". Then choose "2D to 3D" option to active 2D to 3D Converter. 2D DVD to 3D Video>Step 2: Some settings for the conversion Just like usual in DVD Ripper, one can set subtitles, audio tracks, and profile for the output video. And can click Edit button on the main UI to make more settings. Now, particularly note that one can also set video effects for the 3D output just like in DVDFab Blu-ray 3D Ripper. Just click the "Video Effect Settings" button besides "2D to 3D" option to customize as follows: 2D DVD to 3D Video>Step 2: Start converting DVD to 3D Now that everything is OK, we can hit Start button on the main interface to start the converting process. During the process, we can view detailed information, preview source movie, and set auto shutdown for the computer if we need. OK, that's all about it. Convert a 2D DVD to 3D videos is just a matter of 3 steps
255 people viewed this tip
David Payne
David Payne
