Tip & How-To about Computers & Internet
How to create your own Run Command for any specific application?
Today tip will help you to make your own Run Command (program shortcut) to run a program or a document directly. No more need to navigate the location of a program or document to run it, simply click on Start button to open Run box and type the programs shortcut name to open it directly.
Follow the given steps to disable the save settings functionality for desktop:
To use this feature, you will need to be logged into your computer with administrative rights.
  • Click Start button and type regedit in Run option then press Enter for next.
  • HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\App paths
  • Now right click on App Paths and select New > Key, title the key and name it whatever you want your run command to be. In this case, we will try to create a run command for SecueCRT application.
  • New > Key > SecureCRT.exe
  • Now select the SecureCRT.exe folder and click right on (Default) string value then click Modify at the right hand side panel.
  • Here enter the path of the program that you want to execute in the value data field. In our case, the path of SecueCRT application will be C:\Program Files\VanDyke Software\SecureCRT \SecureCRT.exe.
  • Now again in right side panel, click right to create a new String value with the name SecureCRT and its values as C:\Program Files\VanDyke Software\SecureCRT\SecureCRT.exe
  • Now close the registry editor and restart your computer after any changes to go into effect.
Computers & Internet Logo
What do I have to press for it to be command prompt, because I'm not sure?
open cmd run-> Cmd or you can run the dos one by creating a shortcut the shortcut name is command.com
cd ( command)
for ex: cd/ gets u into the main hard disk page
dir to make your cmd read files and info that hard disk contain
other ex: when you dir the file yo can enter them by this command
cd File Name
ex 2 : cd program files
that will get you into program files
Ex3 aND its the most IMPORTANT To Change the hard disk ( the hard disk were you are ) Hard disk Name:
Ex 4 there is a way you cant write and save your reminders etc.
By Typing edit
a window will pop up
Hint You can write help to get all of the commands can use
I Hope its helpful
Jun 15, 2013 | Computers & Internet
I upgraded my computers operating software from Windows Vista to Windows 7. When opening the HP Solution Center/Scan Document, I lost the Scan Shortcut: "Document to E-mail". My question is, how do I get the "Document to E-male" Shortcut back?
Hello;
hope only shortcut lost not the program, click windows start>then pointing all programs(you can see all programs installed in your machine) navigate to hp solution>right click the scan document>click sendto>then select desktop(create shortcut)..goodluck!!
note;in other programs when you right click is diffirent,(click the create shortcut)
Feb 21, 2011 | Computers & Internet
I have a '95 Scrabble game and Upwords which I played on an old pc and I can't play them on my 2000 Aspire 3680.Can someone help me please.olddear
Follow the directions to enable Compatibility Mode in Windows 2000 and try running your application in compatibility mode for windows 95.
  1. Log on as Administrator.
  2. Click Start, and then click Run.
  3. In the Open box, type the following command, and then click OK, where %SystemRoot% is the drive and folder in which Windows is installed (eg C:Windows): regsvr32 %systemroot%apppatchslayerui.dll
  2. Right-click the shortcut (for scrabble), and then click Properties.
  3. Click Compatibility.
  4. Click to select the Run in Compatibility Mode check box to enable Compatibility-mode support for the program.
  5. Click Windows 95 compatibility mode in the drop-down box.
  6. Click OK to save the changes.
  7. Double-click the shortcut to run the program.
Good Luck!
Feb 06, 2010 | Acer Computers & Internet
281 people viewed this tip
David Payne
David Payne
