Tip & How-To about Computers & Internet
Operating systems.
1.keep minimum three drives of 5gb .
2.keep operating system on this each drive.
3. very helpfull for dsifferent softwares and different tasks.
Computers & Internet Logo
install autodesk maya 2010 64bit
Okay the first thing even though your question is very general and we really don't know the specific probably having if you're installing an auto 64-bit you need these operating systems listed below make sure you have one of those operating systems it must be 64-bit you need to check if your operating system is 64-bit before you can stop go to the Run command on your operating system and type winver then enter an then enter and see if and seethe computer is if the computer64bit if it is not 64-bit you need a 64-bit computer first and foremost if you're having other problems you need to give us more details before we can help
If you're having a license key issue you may not actually own software or maybe counterfeit you need to contact Autodesk in that case good luck
The 64-bit version of Maya 2010 software is supported on any of the following operating systems:
  • Microsoft Windows Vista Business (SP1 or higher)
  • Microsoft Windows XP x64 Edition (SP2 or higher)
  • Red Hat® Enterprise Linux® 5.3 WS operating system
  • Fedora™ 8 operating system
The following web browsers are supported for Maya 2010:
  • Microsoft® Internet Explorer® 6.0 internet browser or higher
  • Netscape® 7 web browser or higher
  • Apple® Safari® web browser
  • Mozilla® Firefox® web browser
Hardware
At a minimum, the 32-bit version of Maya 2010 software requires a system with the following hardware:
  • Windows: Intel® Pentium® 4 or higher, AMD Athlon™ 64, or AMD Opteron™ processor
  • Macintosh® computer: Intel-based Macintosh computers
  • 2 GB RAM
  • 2 GB free hard drive space
  • Qualified hardware-accelerated OpenGL® graphics card
  • Three-button mouse with mouse driver software
  • DVD-ROM drive
  • Maya Composite media cache requirements for playback:
  • 10 GB minimum, 200 GB recommended
  • HDD: IDE, SATA, SATA 2, SAS, SCSI
At a minimum, the 64-bit version of Maya 2010 software requires a system with the following hardware:
  • Windows and Linux: Intel® EM64T processor, AMD Athlon 64, or AMD Opteron
  • 2 GB RAM
  • Qualified hardware-accelerated OpenGL graphics card
  • DVD-ROM drive
Mar 22, 2018 | Autodesk Computers & Internet
prints very slowly
After you print a test page and establish a baseline print speed for your HP product, you determine that computer issues cause slow printing. Solution one: Check minimum system requirementsThe most common cause of slow printing is a computer that runs at or near its system resource limit. Follow these steps to make sure that your computer has enough system resources to process timely print jobs. Step one: Make sure that the computer meets RAM requirementsThe amount of available random access memory (RAM) can affect print speed. Follow these steps to make sure that the available RAM exceeds the minimum requirement for the HP product.
  1. Open the computer Properties window:
    • Windows XP : Click Start (c01827528.gif ), right-click My Computer , and then click Properties .
    • Windows Vista or Windows 7 : On the Windows task bar, click the Windows icon (c01364735.gif ), right-click Computer , and then click Properties .
  2. Find the available RAM and make a note of it:
    • Windows XP : Click the General tab, if it is not already selected. Find the amount of RAM in the list with the other Computer specifications.
    • Windows Vista or Windows 7 : Find the Memory (RAM) in the System section.
  3. Check the system requirements for your product, listed in the product manual and on the box, to make sure that your computer has enough memory.In general HP recommends the following RAM:Operating SystemRecommended RAMWindows XP128 MB minimum
    256 MB recommendedWindows Vista512 MB minimum
    1 GB or higher recommended Windows 7 (32-bit) 1 GB minimum
    1 GB or higher recommendedWindows 7 (64-bit)2 GB minimum
    2 GB or higher recommendedc01647276.gif These recommendations vary by product, so if you are not sure of the specific requirements for your HP product, look in the manual or on the box. Or, you can follow these steps to check the product specifications online:
    1. Right-click this link, Product Support Home Page , and then click Open in New Window .
    2. Type your product model in the Locate your product to get support search box, and then click Next . A list of products displays in the search results.
    3. Click your product from the list displayed in the search results. The support page for your product displays.
    4. Click Product information , and then click Product specifications .
Step two: Make sure that the computer hard drive has enough free spaceThe amount of available hard drive space can affect print speed. Follow these steps to make sure that the available hard drive space exceeds the minimum requirement for the HP product.
  1. Open the My Computer window:
    • Windows XP : Click Start (c01827528.gif ), and then click My Computer .
    • Windows Vista or Windows 7 : Click the Windows icon (c01364735.gif ), and then click Computer .
  2. Right-click on the drive containing your operating system, typically (C:) , and then click Properties . The Properties window opens.On the General tab, find the available space, or free space, on the hard drive.Figure 1: Example of hard drive information in the Properties windowc01912502.gifIn general, HP recommends the following free hard drive space:Operating SystemRecommended hard drive spaceWindows XP200 MB minimum
    1 GB recommendedWindows Vista650 MB minimum
    2 GB or higher recommendedWindows 7550 MB minimum
  3. If the free disk space is near or under the minimum requirement listed in the table above, click Disk Cleanup to free up disk space.
Step three: Make sure that the computer meets CPU requirementsIf the computer does not meet CPU requirements, the print speed might be affected. Follow these steps to make sure that the computer meets the minimum CPU requirements.
  2. Find the CPU specifications and make a note of it:
    • Windows XP : Click the General tab, if it is not already selected. Find the computer processor information with the other Computer specifications.
    • Windows Vista or Windows 7 : Find the computer processor information in the System section.Use the following table to make sure your computer meets the minimum CPU requirements:Operating systemMinimum CPU requirementsWindows XP233 MHz Intel Pentium II or Celeron processorWindows Vista800 MHz 32-bit (x86) or 64-bit (x64) processorWindows 71 GHz 32-bit (x86) or 64-bit (x64) processor
  3. Print and time a self-test page again.
  • If these steps resolved the issue , you do not need to continue troubleshooting.
  • If the issue persists , continue to the next solution.
Solution two: Close unnecessary programs and processesFollow these steps to close all unnecessary programs to try to speed up printing.Step one: Close all unnecessary programs
  1. Press and hold the Ctrl + Alt + Delete keys on the keyboard.The Windows Security dialog box opens.
  2. Click the Task Manager button in the Windows Security dialog box. The Windows Task Manager dialog box opens.note.pngNOTE:If the Windows Task Manager dialog box does not open, right-click on the task bar and select Task Manager .
  3. In the Windows Task Manager dialog box, select a software program from the Applications tab, and then click End Task to close the program.
  4. Repeat the previous step until you have closed all unnecessary programs.
Step two: Close any unnecessary processesProcesses run in the background even when no applications are in use. Follow these steps to end unnecessary processes.
  1. Return to the Windows Task Manager that you opened in the previous step.
  2. Click the Processes tab.
  3. Select the process to end, and then click End Process .note.pngNOTE:If another window opens and indicates that the task has stopped responding, click End Task .
  4. Repeat the preceding step to end all unnecessary processes.note.pngNOTE:You cannot end critical system processes.
  5. Print and time a self-test page again.
Solution three: Check the print settingsPrint settings can affect print times. Follow these steps to check the settings for paper type and print quality.
  1. Open the Printers folder:
    • Windows XP : Click Start (c01827528.gif ), and then click Printers and Faxes .
    • Windows Vista : Click the Windows icon (c01364735.gif ), click Control Panel , and then double-click Printers .
    • Windows 7 : Click the Windows icon (c01364735.gif ), click Control Panel , and then double-click Printers & Devices .
  2. Right-click the icon for your product (c01520247.gif or c01514371.gif ), and then click Properties . The Properties dialog box opens.
  3. On the General tab, click Printing Preferences . The Printing Preferences dialog box opens.
  4. Click the Paper/Quality tab.
  5. Click the drop-down list under Media , and then select Plain Paper .
  6. In the Quality Settings section, select Normal .
  7. Click Apply in the Printing Preferences dialog box to save the settings, and then click OK to close the dialog box.
  8. In the Properties dialog box, on the General tab, click Print Test Page . The product prints a test page.
Solution four: Remove and reinstall the HP softwareThere might be a more current driver available for your HP product. HP recommends that you use the latest version to correct printing problems. Follow these steps to remove the HP software, and then reinstall it. Step one: Remove the HP software
  1. Unplug the USB cable connecting the product to the computer.
  2. Open the Windows Control Panel .
    • Windows XP : Click Start (c01827528.gif ), and then click Control Panel .
    • Windows Vista or Windows 7 : On the Windows taskbar, click the Windows icon (c01364735.gif ), and then click Control Panel .
    The Control Panel window opens.
  3. Open the list of installed programs and remove the software.
    • Windows XP : Double-click Add/Remove Programs . In the list of installed programs, click the HP product, and then click Add/Remove .
    • Windows Vista or Windows 7 : Click Programs . In the list of installed programs, click the HP product, and then click Uninstall .
  4. Follow the on-screen instructions to complete the uninstall.caution.pngCAUTION:If asked to remove shared files, click No . Other programs that use these files might not work if you delete the files.
  5. Disconnect the product from the power source, and then restart the computer.
Step two: Download and reinstall the HP softwareIMPORTANT: If you receive any third-party firewall messages during installation (for example, a message from McAfee), click continue , unblock , yes , allow , or permit . Otherwise the software installation fails.
  1. Disconnect the USB cable from both the product and the computer (if you already connected it).
  2. Turn the product on.
  3. Browse to the Get Software and Drivers page: Get Software and Drivers
  4. Check the instructions on the page, and then click the Plus sign (+) next to the correct heading for additional instructions:
  5. Click the Plus sign (c02200813.gif ) next to Driver , and then click the driver that you want to download.
  6. Read through the minimum system requirements and additional instructions. You can also click View directions (c016472760.gif ) for complete download instructions.
  7. Click Download . This option allows you to install the software at any time after the download completes.
  8. Click Save , and then browse to the location on your computer where you want to save the file.
  9. Click Save . The software downloads to your computer.Hint: Make a note of the place that you saved the file, in case you want to install it at a later time.
  10. hope this help : - )
Dec 20, 2012 | HP Photosmart 6510 e-All-in-One -...
low disk space
Windows vista requires minimum 5GB space to install on drive.
First format the drive on which you want to install vista.
Aug 22, 2010 | Microsoft Windows Vista Ultimate Edition
5gb drive
5Gb of HDD space ids just enough for an Operating System with Internet Applications.
You could run Windows XP smoothly on that capacity.
To keep the temporarily storage and cache as low as possible it's better to let Internet Explorer or Mozilla Firefox clear the temp. folder & cache once a few days.
Nov 07, 2008 | Compaq Presario Notebook
Running out of space on C drive
hi, its possible to merge two partitions.
down load a partition changing software like partition magic and install it. Have a look at the help available and and go for merge partition.
thank you
Aug 15, 2008 | Microsoft Windows XP Home Edition
394 people viewed this tip
David Payne
David Payne
