Tip & How-To about Video Cameras
Web cam
1.always connect your web cam behind the cpu.your front ports are open for fregular use.
Video Cameras Logo
does the web cam supposed to come on when you click on the icon? When I click on the camera it takes me to Logitech VID.
unplug the web cam and plug it in the back side of cpu in usb port and try to use. if not working then uninstall and reinstall webcam driver then it will work fine.
Mar 31, 2010 | Logitech Webcam
i connect my cam in my pc how its open and start it now
When the camera won't let you connect it with the computer, always use an AC adapter when downloading directly to a computer. Check with the camera manufacturer (try its Web site) to make sure you have the latest version of the necessary software drivers. If your camera connects via a serial (COM) port, check for serial-port conflicts. If you're using a FireWire cable to connect to the computer, turn the computer on, turn the camera on and then connect the cable between the two. Don't turn off the camera while the cable is still attached. If the camera won't recognize the media, make sure media is inserted correctly (this isn't always obvious with SmartMedia, for instance). Make sure media hasn't been write-protected.
Dec 23, 2009 | Cameras
need instuctions for using Acer Crystal Eye web cam
Like with most laptop web cams the supplier doesn't always install usable software. As long as it opens and you can see yourself the cam will work with any of the know messaging programs. To use it independently of the internet, go into the control panel and system and then hardware and find the manufacturer of the web cam device itself, ie logitec. Then go to that companies web page, and most have some free web cam software that you can download and use for creating video on the laptop.
Dec 04, 2008 | Acer Aspire 5610-4648 Notebook
cant connect to servers with alot of players though netgeat but can directly off cable modem
You need to open the appropriate ports so your console can bypass your NAT... If you goto your console manufacturer's web site they will almost always list the ports that you have to open to allow your console to function properly behind a NAT.
Once you find the ports you need to open you can call netgear's tech support and they can walk you through opening those ports. Or you could come back here and we'd most likely be able to help ya.
Sep 17, 2008 | Video Game Consoles & Games
web cam
Most of the Web cams dont have build in mic, but if you had it with your cam, try to plug in the red plug at the back of your CPU in the red plug in beside the green plug in. use plug and play wizard that helps you to try the mic of your cam if it really works.
Feb 27, 2008 | Dell Microsoft Windows XP Home Edition
2,641 people viewed this tip
Top Video Cameras Experts
Are you a Video Camera Expert? Answer questions, earn points and help others
