Tip & How-To about Computers & Internet
Long wires
1. if your connection wires are over long spiral them in a zigzag way and round them with a rubber band .
Computers & Internet Logo
leaking
I think your rubber band is not round your drum proper youve got toun plug it pull it out un screw lidput your hand down front of washer insideand feel round rubber and if it feels like its come away then you have a metal loop that may need puttin back proper so you will have unscrew it and movethe metal rim and putthe rubber back into slot again all the best
Dec 30, 2012 | Cars & Trucks
what are he different feet used for?
The main types of feet are:
1. ZigZag foot. This has a wide gap for the needle to move from side to side and the two pointy ends of the feet curve upwards. This is used for ZigZag and decorative stitches,
2. Straight Stitch foot. This has a small round gap and one side is usually wider than the other. It's used for straight stitching.
3. Rolled-Hem foot. This has a spiral in the middle and is used for rolling and sewing hems neatly.
4. Zipper Foot. This has no gap as the needle goes to one side or the other of the foot. It usually has two attachment points for snapping on to the shank, depending on which side of the zipper you are sewing.
5. Invisble Hem foot. Used for making invisible hems. It's hard to describe how it looks. Mine has extra white plastic parts around it and some kind of screw to make adjustments as to width etc.
6. Buttonhole foot. My buttonhole foot is white and has numbers along one edge. The size of the buttonhole can be altered, using the numbers as a guide.
7. Edging foot. This has a strip of springy metal on the left side and is used to guide the material into the path of the needle in order to sew close to the edge to prevent fraying.
8. Rolling foot. This has rollers and is useful for sewing thicker materials or quilts etc. It is similar, but not as good as a walking foot.
9. You might also have a Teflon ZigZag foot, it's the same as the zigzag foot but made of white plastic. It's used for sewing vinyl and leather materials.
I think that's it, hope this helps!
Nov 16, 2010 | Singer Quantum XL-1000 Computerized Sewing...
2000 dodge durango horn wont work fuse good ,cant find relay ,tried remomeing air bag and grounding wire still inop
your horn is connected to the spiral which ibelive is cut just change your spiral check continuity on the wires if the spiral to confirm
Oct 30, 2010 | 1999 Dodge Caravan
How do I replace the rubber watch band?
Get the screwdriver and start to unscrew all the screws relating to band and rubber casing. Then undo springbars. Then unscrew caseback screws, take out the rubber gasket, unscrew the battery contact screws and take out the battery. Buy exactly the same one and replace it, then do all the operations in the same way other way round. Rate me, please.
Jun 24, 2010 | Casio Wave Ceptor WV57HA-1AV Wrist Watch
A round band came loose during a wash. It is a think black rubber-type band. The band is in tact it just need to be put back on, however i dont know where it came from. Dishwasher is a small version if that makes a difference.
That sounds like it came off of your small apliances (blender, food prosecer...) there is not any rubber washers on the inside of 99.9% of dishwashers becauss thay can melt in the heat.
Sep 12, 2009 | Dishwashers
257 people viewed this tip
David Payne
David Payne
