Tip & How-To about Office Equipment & Supplies
Use of a water bottle
1.get a water bottle.
2.pierce on its circumference with a screw driver.
3.enlarge the holes to suit your pen
4. you can use this as a pen stand.
What do I do with my plastic water bottles?
There are so many creative ideas to reuse the most dangerous waste product i.e. plastic bottles:
1. You can use it to make a bottle vase and you can also wrap a cloth around the vase for a more attractive look.
2. You can use it as a watering can for watering the indoor plants in your house.
3. It can be used to make a hydroponic garden if you have a window with a huge amount of sun rays.
4. You can also use it as a jewelry stand a yarn holder.
Jan 04, 2017 | Green Living
how to recharge air conditioner in 2000 tacoma?
Connect the charge line to the new bottle of AC Freon but be sure the piercing pin is screwed all the way out away from the container seal. Connect the other end to the charge line(covered by a cap like on your tire air fill), this will only fit one of two fittings. They're set up that way so there's no mistakes. The other is larger. After connection is complete, start the engine and turn the AC on so the compressor will suck the Freon into the system from the can, then screw the piercing pin all the way in to open the seal, then screw it back out to release the Freon from the can. To be sure ALL the Freon is removed, have a bucket of hot water there to set the Freon bottle into, and it will empty completely with the bottle in the hot water while engine and AC running. That's a good trick I learned long ago. Once the Freon bottle is empty, disconnect from the charge line fitting first, replace the cap you didn't lose, remove the can from the fill hose and put it where you can find it again, and your good to go.
Jul 01, 2014 | Vehicle Parts & Accessories
i can't remove the stand off the tv
Hi, i have instruction on removing your base stand.
Removing the Pedestal Stand
1) Carefully lay the front of the unit face down on a flat,
cushioned surface such as a quilt or blanket. Leave the stand
protruding over the edge of the surface.
Note: Extreme care should always be used when removing
the pedestal stand to avoid damage to the LCD panel.
2) Remove the jack pack cover on the back of the TV to expose
the pedestal stand screws. The jack pack cover can be removed
without tools.
3) Remove the four screws shown in the diagram below. This will
allow removal of the pedestal stand.
4) Once you have removed all four screws holding the pedestal
stand in place, remove the pedestal stand from the TV by
sliding the pedestal stand away from the TV.
Feb 12, 2011 | Toshiba REGZA 52RV530U LCD TV
1,902 people viewed this tip
k24674
