Tip & How-To about Computers & Internet
How to Burn a DVD
There are lots of reasons why anyone would want to burn or make a copy of a DVD. One main reason is that DVD discs don't last forever and it's best that you back it up for you can never can tell what will happen. They get scratched and damaged even with proper care and even if you leave store your DVD in a safe place, it will deteriorate over time. Anyway, here, you'll find instructions on how to burn a dvd. So let's get on with it.
DVD Burner enables you to burn a home video DVD to playback in your home DVD player from all modern video formats. The integrated DVD burning engine and the widest range of supported video formats make this best DVD burning software a perfect tool to create personal DVD videos. Just follow these few steps listed below.
Step 1: Select "To DVD" Button.
Want to burn a DVD, the first step is to choose the "To DVD" button on the best DVD burning software main menu of top.
Step 2: Add video files.
Now, we need to import video files that need to be burned onto a DVD. Select/drag the video file into the main interface of best DVD burning software.
Step 3: Burn a DVD.
Now you can convert to DVD disk. Click "Convert" and then select your DVD drive (if you have more than one DVD drive on PC).
That it, with best DVD burning software you can burn videos to DVD and make your own DVD menu by yourself. It's easier and faster than other ways. Moreover, the application also support other common Movie files like AVCHD from Camera, AVI, WMV MPEG MOV MKV, etc, and is fully compatible with Windows 7. Now, just enjoy watching your own made film videos on home DVD player or backup them as permanent collection.
More info:burn vob to dvd, how to burn mp4 to dvd, burn iso to dvd.
Computers & Internet Logo
how do I format a dvd disc
You don't have to. DVD's and CD's are already formatted from factory. But if you are having problems to record on (burn) them probably your computer is not capable for DVD burn, just CD's. But if it is equipped for burning then try this:
See alsoFormat a CD or DVD
Before you can copy files to a CD or DVD, the disc must first be prepared using a process called formatting. There are several ways to format a CD or DVD disc. Your choice of format determines which computers and other devices will be able to read the disc.
  1. Insert a disc into your computer's CD or DVD drive.
  2. In the dialog box that appears, click Burn files to disc.
  3. In the Burn a disc dialog box, type a name for your new disc.
  4. Click Show formatting options, and then click one of the following formatting options:
    • Live File System
    • Mastered
  5. Click Next to prepare the disc.
    Now you can copy files to your disc using whichever method you selected.
Nov 30, 2011 | HP Computers & Internet
Hello,I have been using LG Secure Disc for 1 year.Now when i insert some DVDs in this it doesn't read them however it plays some original DVDs.Can i myself do something that it starts playing those DVDs. Thanks & Regards Rajesh Sharma Email-rajesh.8aug@rediffmail.com
OK, by the information that you provided it appears that the problem you have is with burned DVD copies of original DVD's. There are three possible reasons for this:
1. Your drive just doesn't like burned DVD's. This is the most unlikely of the situations but it does happen. Sometimes a firmware update will resolve that problem and I recommend a firmware update regardless of how your proceed. You didn't provide the model number but this appears to be the firmware update for your model as described. If not, browse LG's site for the exact one.
http://www.lg.com/us/support/product/support-product-profile.jsp?customerModelCode=GE20LU10&matchedModelCode=1000007624&searchEngineModelCode=GE20LU10&initialTab=documents&targetPage=support-product-profile#
2. Bad/Cheap Media: Cheap media is the most common reason for copies not being read by some DVD drives and stand-alone units. Always use higher quality media for your burns. Verbatim is probably the absolute best and most reliable. I also use Sony and TDK as well. Avoid off-brands like the plague.
3. Burning Software: The second most common cause of burned DVD's not working. LG's I believe come with Power DVD OEM now (I know my Blu-Burner did) and they used to come with Nero. But they use to come with Nero and older versions of Nero were notorious for their burns not being compatible with certain drives (the problem was resolved in later releases) so I recommend for your burns that you use either the OEM of the software that came with your burner or a the latest version of Nero.
Now, if we're talking about DVD's of movies (which I assume that you are because you mentioned that the originals "play" and when talking about data, people don't normally use the word "play.") then that means you're using a keybreaker software to break security features and CSS keys and a separate software to burn (or you're using DVDFab which is notorious for failure rates). That's a problem because often the two different programs like that don't play nice. So here's what I recommend. Go to SlySoft and download the two greatest DVD burning products ever made, AnyDVD and CloneDVD2. They are separate products designed for each other and AnyDVD is the best keybreaker in existence and it's constantly updated and in conjunction with CLoneDVD2 it makes perfect 1:1 copies of your DVD's that will NEVER fail (provided you use decent media) in ANY drive. Both products have a 14 day free trial on them with no personal information required so test-drive them for yourself to find out how great they are.
Mar 31, 2011 | LG SecurDisc 20x External Double-Layer DVD...
ATAPI DVD A DH16A3L "LightScribe DVD-RW Burner" on HP Compaq
Try to download Alcohol 120% and that program will burn the image for you on blank DVD ;)
you need to get the image first before you burn the file.
Apr 14, 2010 | HP Smart Buy - HP Compaq dc5800 Small Form...
544 people viewed this tip
David Payne
David Payne
