Tip & How-To about Computers & Internet
My required cable ( cat5 or cat6 )
If you need to transfer data at less then 300 MB/S then use cat5 cable and insert the switch at minimum after 300ft. length.
if data rate is in gaga Bytes then use the cat6 other wise don't waste money on cat6.
Computers & Internet Logo
Whose company give CAT5 cables which give better result for high speed data sharing?
Tripp Lite:
Features
  • Cabling for category 5 (Cat5) and 5e (Cat5e) applications
  • Length: 3- Ft. color: black connectors: RJ45 male
  • Feature molded connectors with integral strain relief
  • Snagless design protects the locking tabs on the RJ45 connectors from being damaged or snapped off during installation
  • PVC 4-pair stranded UTP
  • Rated for 350MHz/ 1Gbps communication
  • Meets most current industry standards including IEEE 802.3ab, IEEE 802.5 ANSI/EIA/TIA 568, ISO/IEC 11801 and ETL (category 5e draft 11)
  • Available in other colors and lengths
  • Also available without the snagless feature (N002 series)
  • Also available - Cat6 cables (N201 series)
Power Protection Power Distribution Cabling Tripp Lite
Feb 04, 2015 | Computers & Internet
i face a problem to connect a to office with a 95mtr cat5e cable.switch is not blink on both hands.
95 meters is simply too long. No way of getting a signal on the other end without the use of a repeater. The maximum distance for CAT5e and CAT6 is 295ft, which is roughly 90 meters, but even that only works in an ideal environment. Often the max distance is announced with "300ft = 100m", but that is not true (and 300ft are only 95 meters anyways.)
The best option is fiber optic cable, but that is very expensive.
Read also this article - it has some good explanations and comments.
I would buy a cheap router (WRT54G i.e.) and modify it with some third-party firmware as repeater. That would cost you not more than 25-50$. (Tip: google "Router as Repeater", and you will find many results.)
If you have any more questions, just come back here and leave a comment - I'm happy to help.
Jun 01, 2010 | D-Link DES-1008D 8-Port Ethernet Switch...
What is UTP CAT 5e cabel?
This 1000 foot, spool-boxed roll of grey Cat5e bulk cable is a must-have for extensive networking. This unterminated and UTP (unshielded twisted pair) cable is perfect for a plethora of networking applications.
Cat-5e, enhanced Cat-5 cable, is the standard for modern networking - enabled for far end crosstalk and compliant with up to 1000BASE-T standards. This unshielded cable comes in its own spool box and is connector free, giving the user the freedom to customize the length, wiring, and application.
This cable is 1000 feet long and are marked at every foot (marked 0001 - 1000 at each foot).
Wire the cable as either a patch or a crossover cable, use it for Ethernet or any other data transfer applications. Sewell Direct works hard to bring you affordable Cat5e bulk cable solutions.
Jan 13, 2009 | Intellinet Active Networking CAT5e UTP...
1,472 people viewed this tip
David Payne
David Payne
